Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 18115648 times)
onsokumaru and 52 Guests are viewing this topic.
« Reply #64525 on: July 27, 2020, 04:25:33 am »
The first thing he needs is a fork lift to move the pallets so that he can lay the concrete floor. Shortly followed by half a dozen friends, all nicknamed 'Björn'.
I bought the fork lift (just one of those "pallet movers"; it won't lift higher than say 80mm) before the lathe. It's in my neighbours garage, though.  My brother-in-law is named Björn.
Offline Neomys Sapiens
« Reply #64526 on: July 27, 2020, 04:31:37 am »
Question:
If you have to choose between a
- Siglent SDG1025 (310 Euro)
- GW Instek AFG-2225 (300 Euro)
which one would you choose and why?
Both are in nearly new condition.
If I was forced towards this choice...
I would consider turning away from electronics.
The following users thanked this post: mnementh, Kosmic
« Reply #64527 on: July 27, 2020, 04:46:00 am »
More progress on the Type 3A74 Vertical plug-in. Now have all 4 channels accounted for with DC balances set and gains properly adjusted. But a new issue has come up. After about 15 minutes or so the scope loses all trigger. Can't get a stable waveform. And the issue is definitely in the trigger circuit in this plug-in and not the Type 3B3 Time Base because it works fine with the Type 3A3 Vertical plug-in. So additional troubleshooting is needed. Tomorrow's project.
Offline Saskia
« Reply #64528 on: July 27, 2020, 06:54:34 am »
The GWInstek is sitting on my shelf, I just could not resist the urge, and I got it as a bargain.
@Mounty if you want to give it a test drive I could send it to you for a loaner, I do not need it right now.
The following users thanked this post: BU508A, mnementh, Specmaster, tonyalbus
« Reply #64529 on: July 27, 2020, 07:02:47 am »
Did some work on the 6206b this morning. Checked out caps - all good. Calibrated and destickered half of the front. Other half still to go. Annoyed about the scratches from the previous idiot owner who used a screwdriver to get a cal label off.
Ugh! The screwdriver-wielding idiots are much too prevalent. I've passed on many TE because of them. :-\
Welcome back, bitseeker. How's the catch-up going?  :-DD
« Reply #64530 on: July 27, 2020, 07:25:46 am »
Thank you for your kind offer, but I don't want to stress somebody because auf this. :)  :-+
I just want to have a nice and relatively cheap AWG for daily average stuff.
I've seen the Siglent and the GW Instek in the German ebay Kleinanzeigen and they looked kind of interesting to me.
There is also another one which is looking interesting, a Wavetek 270 for 200 Euro.
The GW-Instek AFG-2225.
The Siglent SDG1025.
The Wavetek 270.
The thing with the GW-Instek 2225 is: One can get it new at Reichelt for 35.- Euro more. And it comes with all the guarantee stuff which the other don't.
Same goes for tautech's suggestion, the Siglent SDG-1032X.
One can get it at Welectron new for 300 Euro.
Must think over a bit about this. ::)
Thanks for all your offers and reasoning.
« Reply #64531 on: July 27, 2020, 07:43:22 am »
If you've been watching these you should know they can be improved to 60 MHz.  ;)
« Reply #64532 on: July 27, 2020, 07:44:43 am »
Yes I know and I'm aware of this. Will take it into account, of course.  :D
« Reply #64533 on: July 27, 2020, 07:57:05 am »
Just looked up the EU pricing and it's €259.
https://www.siglenteu.com/waveform-generators/sdg1000x-series-functionarbitrary-waveform-generators/
Maybe you should look at other suppliers ?
« Reply #64534 on: July 27, 2020, 08:06:55 am »
That has never stopped me from buying something if the price is right and I needed it. I buy things to use, not look at or put on show  8)
Offline tonyalbus
    • My Channel
« Reply #64535 on: July 27, 2020, 08:08:51 am »
Bloody marriage, relocation to new home and corona....
Tonight I fired up the dragon device for the first time:
(Attachment Link)
(Attachment Link)
So I need to upgrade a few parts and download the prusa slicer and I will serve you soon a FU YOU octopus.
EDIT: I just realized jet every time I print I need to load the gcode on a card? Are we in 2020?  :-// ^-^
octopi
« Reply #64536 on: July 27, 2020, 08:26:43 am »
When I'm clicking on your link and then clicking on "buy it now" then I'm getting an overview where to buy in Europe.
For Germany it is Welectron and your 259.- Euro are excluding the VAT ("Märchensteuer" in German  ;) ).
Including VAT it is 300.- Euro.
« Reply #64537 on: July 27, 2020, 09:38:25 am »
The Wavetek 270.
Note that the Wavetek 270 is not an AWG, just  programmable function (sine, square, triangle) generator. Quite nice (I have one) but power hungry by modern standards
https://82fai3h5wg8220a0l3ilfiz1-wpengine.netdna-ssl.com/wp-content/uploads//2015/09/WAVET_270102943.pdf
« Reply #64538 on: July 27, 2020, 09:56:12 am »
Buy a broken 4 channel DSO. That’s a larger challenge these days  :-DD
Okay. But just 'cuz you sed to.  >:D
Fine, fine, fine... I'll get it's brother too so I can make 4 channels. :-BROKE
Worst case you can strip it for bits and make a lot more than that  :-+
Currently realised I'm screwed on a project. Need to probulate 4 partially analogue, partially digital non repetitive rare events at the same time which are very far apart. Only have a 2 channel scope with 2.5kpts non-segmented memory :--
The question is as always, how much money do I want to spend to fix this measurement gap  :o
« Reply #64539 on: July 27, 2020, 10:04:01 am »
If you'd live next to me I'd lend you my R&S :)
But perhaps as a second option: How about to rent a scope for a few days?
Online tggzzz
« Reply #64540 on: July 27, 2020, 10:07:18 am »
What do you mean by "partially analogue, partially digital"? That will give some info that might allow imagination to save the day.
« Reply #64541 on: July 27, 2020, 10:12:55 am »
Well I need to measure two current ramps using voltage sampling on a series resistor (relative to ground) because I can't afford two current probes. And a voltage ramp. And an inbound trigger pulse. Need to measure rise time of the current ramps, leading time from the trigger pulse and the lag to the voltage ramp.
Current sampling, I'm looking to measure saturation of inductors.
I'm sure you can guess where this is going  :-DD
« Last Edit: July 27, 2020, 10:15:42 am by bd139 »
« Reply #64542 on: July 27, 2020, 10:14:13 am »
I'm moving to Germany  :-DD
By the time I've paid to rent for a month I'm half way to an SDS1104X-E which I can sell again for a lower net loss :-//
Online tggzzz
« Reply #64543 on: July 27, 2020, 10:19:15 am »
Could you:
  • use scope's capture+measure functions to determine the risetime
  • logic analyser or counter/timer to measure the intervals between scope's trigger out and trigger pulse
« Reply #64544 on: July 27, 2020, 10:21:20 am »
Could you:
Could you:
Stop before you kill yourself or loved ones.  :P :-DD
« Reply #64545 on: July 27, 2020, 10:31:06 am »
Could you:
Interesting. Will see if I can wangle that. The bugger is I need to do this for 20-30 things and work out the distribution.
Online tggzzz
« Reply #64546 on: July 27, 2020, 10:41:06 am »
Could you:
Are the signals really non-repetitive? Could you use a scope to measure the risetime after flicking a switch, then subsequently use the scope to measure intervals when you flick the switch a second time?
To me non-repetitive either involves explosions, or at least fractions of a day between being able to repeat the experiment :)
The following users thanked this post: Specmaster, capt bullshot
« Reply #64547 on: July 27, 2020, 10:45:21 am »
Repetitive they can be made but this increases complexity considerably :(
I'm going to look at it from the top down again. I might have overcomplicated this :)
« Reply #64548 on: July 27, 2020, 11:34:00 am »
Ebay have now giving them a ultimatum, send me a prepaid label within 5 days or they will find in my favour, refund me and I get to keep this 2L one, so lets see what happens now.  :rant:
OK, in the sweepstake I take "Specmaster gets a free 2L one". I presume that if I win I get the classic Stan Lee prize?
Sorry but you have lost the sweepstake, the seller has sent me the postage costs direct to my PayPal account, so I won't be getting a free one (not that I wanted it) nor will I be getting the correct item, they are refunding my money.
So now I'm back with my little plastic one, like you until I can find another suitable unit at a realistic price.
Once eBay get notification that it has been delivered they are going to refund me in full.  :palm:
« Reply #64549 on: July 27, 2020, 12:25:49 pm »
Now piss on it before you throw it back in the box  :-DD
