Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 16949434 times)
0 Members and 164 Guests are viewing this topic.
« Reply #63875 on: July 20, 2020, 04:44:29 pm »
If you lurk enough you can get them for not much. Paid £60 for my last one  :-DD   See here: https://www.eevblog.com/forum/testgear/tektronix-tds210-teardown-and-bnc-replacement/
Okay, NOW you're just rubbing my nose in it...  ;)
You deserved it.  >:D :-DD
Aye... I cannae deny it; may as well own it.  ;)
"Loud & proud; the dragon way."
« Reply #63876 on: July 20, 2020, 04:47:47 pm »
The issue. Nothing would remove it.
The fix.
The following users thanked this post: Specmaster, tonyalbus
« Reply #63877 on: July 20, 2020, 05:00:25 pm »
You can see the blue from the previous victim in the top picture  :-DD
« Reply #63878 on: July 20, 2020, 05:04:16 pm »
Yep, and there's going to be more victims.  :P :-DD
Online tggzzz
« Reply #63879 on: July 20, 2020, 05:09:43 pm »
I really cannot see why everybody is on bd's back, OK, it's a Tek, etc, but as he has already stated he does have a reason for his actions and also the TDS210 is perfectly adequate for his stated purpose, audio work, even with its crappy digital display and lack of memory depth. Yes, we all know that analogue scopes have a far better display, I have both a Fluke PM3390B 200MHz combiscope and a Tek TDS210, but the TDS210 gets used most because it is quick to switch on, actually sits on my bench so is right in front of me and takes a very small footprint.
If I had bench space like a lot of you have, then I'd probably use the combiscope more, but space prevents it from being the main go to scope. Yes I'd like a colour display etc. but really cannot justify the cost, so the TDS210 suits me just fine, and I daresay bd can identify with a lot of that as well.  :-+
All this hating on Tek TDS210s just makes me want one more.
Compared to the old Hameg 20MHz analog scopes I used at college and work, it's pretty fancy, as is my TDS420.
A real problem with the 2.5k points is that it can't emulate the traditional dual-timebase technique to zoom in. I know there are sort-of-workarounds, but it took me a long while to realise the TDS340 was unpleasantly deficient in that regard.
« Reply #63880 on: July 20, 2020, 05:14:47 pm »
There must loads of little blue patches around Meds house then from the overspray so it would easy to double check if you had the right house, just look for the tell-tale blue spots on the ground  :-DD
Offline Neomys Sapiens
« Reply #63881 on: July 20, 2020, 05:16:37 pm »
Also freshly in and in fine condition: a Steinmeyer interior micrometer. (5...55mm)
« Last Edit: July 20, 2020, 05:20:36 pm by Neomys Sapiens »
« Reply #63882 on: July 20, 2020, 05:23:39 pm »
Just wait until a new neighbour goes full panic. 'AAAAH, the blue spores! They are everywhere!'
The following users thanked this post: Specmaster, AVGresponding
Offline 25 CPS
« Reply #63883 on: July 20, 2020, 05:26:03 pm »
To be fair to the TDS-210, they're cheap, they're fairly rugged, and they're compact and they do get the basic job done so they do have their uses.  I'd toss mine in a bag with some adapters and cables, and a power cord and take it on the road along with a small HP function generator whenever I was going to buy test equipment or if I was going to be doing test or service work.  I've gotten more than the $60 CDN of use out of mine for that purpose and if anything bad happens to it, it's not the end of the world since I don't have much money in it.  It's only recently that I picked up an inexpensive Agilent u1602b handheld scope that's replaced it for that purpose.
On that note, does anybody have any recommendations for a battery powered portable, ideally similarly ruggedized, function generator to add to the road kit?
« Reply #63884 on: July 20, 2020, 05:26:55 pm »
Good, I want my neighbors to fear me. That way they leave me alone.  >:D
Gives me an idea. Take a white t-shirt and spray blue spots on it.  :popcorn: :-DD
Offline Saskia
« Reply #63885 on: July 20, 2020, 05:36:00 pm »
if you paint your t-shirt blue, you might be mistaken for Pelosis garden smurf. You sure you want that ?
« Reply #63886 on: July 20, 2020, 05:37:57 pm »
54600 series were best early digital scopes.
Agreed, My 54645D MSO with measurement and I/F module is still my favorite all-round 'scope. Handles like an analog but has digital attributes. Even has a CRT.
« Reply #63887 on: July 20, 2020, 05:38:18 pm »
hah, better hope its not one of us moving in then, because we all that you're really a big old softie underneath, really  :-DD
« Reply #63888 on: July 20, 2020, 05:47:35 pm »
Check the windowing functions. It can indeed do that. I'll set up a demo at some point and youtube it.
Offline SilverSolder
« Reply #63889 on: July 20, 2020, 05:49:32 pm »
If you look at the newer Keysight MSOs, they seem to have a lot of 546xx genetic material in them...
« Reply #63890 on: July 20, 2020, 05:58:38 pm »
I saw a rather basic thing which was build in a multimeter form factor and sold by one of the hobbyist's outlets, like Conrad or ELV over here. But it was almost certainly lacking several features of a basic function generator, as the controls were not sufficient for that. I think one of the older small HPs can be operated on batteries. If not, you have the choice between several popular chips! An energy-efficient output stage will be among the challenges here.
« Reply #63891 on: July 20, 2020, 07:00:21 pm »
That's not overspray... it's Smurf-squeezins:-DD
 >:D
« Last Edit: July 20, 2020, 07:02:20 pm by mnementh »
« Reply #63892 on: July 20, 2020, 07:05:47 pm »
I'll give you $65 for it.  >:D
$75 if it comes with usable probes. :P
« Reply #63893 on: July 20, 2020, 07:16:29 pm »
 :-DD
Put offer on something else. Going batshit this week  :-DD
Edit: oh I need a calibrated voltage reference. What’s currently in vogue?
Edit 2: offer accepted and I own an HP 6206B now which looks considerably less skanky than that last one I bought :-DD
« Last Edit: July 20, 2020, 07:20:37 pm by bd139 »
« Reply #63894 on: July 20, 2020, 07:24:47 pm »
« Reply #63895 on: July 20, 2020, 07:30:04 pm »
Yup but slightly scabbier  :-DD
Needs unstickering. Hopefully not too scratched up.
The following users thanked this post: mnementh, tonyalbus
Online tggzzz
« Reply #63896 on: July 20, 2020, 07:34:56 pm »
Here's the 585A showing a stable trigger on a signal more than twice the datasheet bandwidth for the 585A + type 82 plugin system.  :-+ Yes, it's way rolled off, but it's rock stable.
Here's my 485, nominal bandwidth 350MHz. The astute amongst you will note the timebase is 1ns/div, which means it is triggering on a 1.25GHz and 1.5GHz (just) square wave signals.
Unsurprisingly at 3.5 and 4.4 times the rated bandwidth, the amplitude is somewhat reduced.
And it has a real 50ohm attenuator and input, so TDS{2,3}* can disappear up their own fundaments :)
« Last Edit: July 20, 2020, 07:37:40 pm by tggzzz »
« Reply #63897 on: July 20, 2020, 07:43:43 pm »
Not very good under 50Hz or so though  :-DD
Online tggzzz
« Reply #63898 on: July 20, 2020, 07:44:46 pm »
Use a DVM for DC :)
Nothing interesting happens at DC, unless it involves 8 significant digits.
The following users thanked this post: capt bullshot
« Reply #63899 on: July 20, 2020, 07:47:17 pm »
Plenty of analogue computation happens near DC  :popcorn:
I actually want to test some simple Sallen-key filters i have designed with cut-offs around 20Hz. That's a little low for DMMs and analogue scopes :(
