Welcome to the madhouse!
These might be made to suit your purpose perhaps:
--FOB Power Supplies--
And a 25A load?
Naa, I have a Transmille 3000 series calibrator (22A) UKAS traceable at work.
Yep, that's how it begins.
Sounds like you need some more test gear. That's how it spreads...
Welcome mendip.
You have joined us now. Forget the life you used to have - before TEA. Don't look back because you can never go back. It will never be the same now. All that pre-history will soon be forgotten. That's how I remember it when it happened to me.
Indeed. Welcome mendip! Make yourself at home.
We have several rabbit holes you might care to explore...
I have here at home, 121GW, 2 x AVO8, Decade Resistance, Capacitance Box. Plus various HAM gear, K40 (40W CO2) Laser Cutter, a ton of motorcycles, and a Land Rover Defender. I have a warren to explore if I ever feel the need.
Looking forward to seeing this tester. It's not something I've run across.
Its basically for testing the Ginger Clare Flash testers though I suspect I could use it for any flash tester even them Seaward HAL units. So only enough kV to perk ones senses (5kV) and enough amps (25A) to knock you down if you are foolish. I had a 6kV 150A supply in a few weeks ago that I demonstrated AMPS and VOLTS to the lads at work, they think I am a loon[1], I told them to wait until its 120kV and 3000A then you will see how much fun it can be.
Welcome to the madhouse, or Hotel California as it is sometimes called.
If I go up the road from my house, I can see the Mendips
I will remember to use the Royal Wave next time I am overlooking the commoners down on the levels. ;-)
Thanks for all your welcomes, I plan to annoy people for a while.
[1] I think I ought to order a white lab coat and practice a sinister laugh.
