I actually rather like the newer axial compression-type F connectors, but wholeheartedly agree that the old crimp on or twist on ones were utter caca.
-Pat
I have not seen those axial compression F connectors. Didn't know it existed. As far as I know my cable co still uses crimp on F's but at least they upgraded to RG-6.
I first saw them about ten years or so ago when the cable guy did some repairs and reterminated the drop to the house. He showed me the connector and crimping tool and I thought it was pretty sweet. Bought one a few years later at The Home Despot, and have been using it since. Between one of those clothes-pin strippy things and the compression connectors, terminating RG6 with F connectors is a snap. Clip the stripper on and spin it a few times around the cable, then pull the cut insulation pieces off, fold the shield wires back over the outer jacket and stuff it into the connector until it bottoms. Pop the connector into the compression crimper, squeeze and it's done. The process takes about as much time as it took me to type this out, if not less.
Stripper - preps end of cable stripping 1/4" of all but the center from the end, and an additional 1/4" of the outer jacket.
Stripper detail - the black set of blades preps the cable end. The connector nose fits into the hex recess at the right to hold it steady as the cable is pushed into the point it bottoms.
Compression crimper - the spring loaded actuator is held closed by the bail. The turret that the bail is attached to has several stop depths to do different connectors (I've also done video RCA plugs with it); the knurled screw on the ram adjusts the compression stroke to bottom the connector sleeve when the handle is squeezed shut.
[img height=80https://photos.smugmug.com/Electronics/Misc-test-equipment/i-qSk6LK2/0/c3f096dc/L/2020061700034041-IMG_1469-L.jpg[/img]http://http://Connector (sans cable) in the crimper. It's not currently adjusted to fit this one, but if it were all set up and there was a cable in the connector, a quick squeeze at this point and you're done.
-Pat
Med, Brighthouse now Spectrum here in Flori-DUH has been using compression fittings for quite some time now along with RG-6. I found out about them when we were having a problem with the MTA when we had Internet and phone. The tech came out and re-terminated the cable I installed with the compression fittings. He said that the techs found that crimped connectors were problematic with the phone service. He even gave me some of his stash. I bought the same crimper from Home Depot, already had a similar style stripper. When Rat Shack went out of business, I bought a bunch of connectors--RG-59, RG-6 and RG-6 quad shield. At my age, I have a lifetime supply.
Yeah, those have been around for a couple decades at least; they were developed by the satellite TV industry to make a self-sealing
stem bolt F-connector for RCA/HUGHES/Ku-Band dishes. The malleable plastic bit under the ferrule is made of two inter-fitting cones; when it crushes it locks into itself & forces the sheathing to mold itself to the difference between the metal ferrule and the inner barb, making a weathertight seal. The connectors made for uWave/outdoor use have a silicone rubber seal inside; we'd also wrap the connection with self-sealing silicone tape.
When they were first released, the crimper was made with EXACTLY the right dimensions for the brand of connector; they sold the palm-grip crimper (like yours, only non-adjustable) cheap, like $10-20, to lock you into their brand of connector at ~$1.50 each. Techs soon found they could buy the Paladin adjustable ratcheting pliers-type crimper (which I still have) for ~$40 and do any of them, as well as BNCs and RCAs. Some techs tried to fake it by using the cheapest crimper with washers to shim out for the cheapest fittings; these inevitably deformed the connector causing pull-apart failures left & right. I had regular work for a couple years re-terminating those failed connectors; enough to pay for my first digital camera which became a necessity for documenting the repairs.
The f***ing lightning traps were the worst offenders; they had poor quality machining on the connector stubs and were very hard to get a good seal.
