Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17431235 times)
Carl_Smith and 35 Guests are viewing this topic.
« Reply #59525 on: May 27, 2020, 04:11:00 pm »
« Reply #59526 on: May 27, 2020, 04:13:21 pm »
If it's like most companies I've worked for their IPAM will be based on snooting coke in the toilets and counting the dots of blood on the tissue to issue new network numbers.
At my last gig it was determined by a very grumpy Irish lass throwing darts at the door and then measuring how far out of the other side she'd managed to get the points to come. Anybody who has worked at/for that particular enterprise on their network will immediately recognise what corporation it was.
This is the same place that the default root password for Linux machines was "<companyname>%768". (OK, it wasn't exactly that, but it was just as stupid and 'cunningly' constructed to meet Security's password complexity requirements while simultaneously missing them by about the distance between Earth and Jupiter).
The following users thanked this post: Zucca, mnementh
« Reply #59527 on: May 27, 2020, 04:15:17 pm »
... the only real cure is cleaning the carbon pads with alcohol to expose fresh carbon matrix every few years or replacing the silicone membrane itself with a brand-new one.
Not true. As of this morning I have repaired the pads, and in a way that no one has mentioned here, nor did I see the way I did it on any internet search (not to say it doesn't exist out there). The alcohol cleaning did nothing at all because they were already cleaned before as I told you. Nothing else came off the the pad and I scrubbed them very well. Under the microscope they remained as they were before I cleaned them. As well, they did not perform any better when tested after this new alcohol cleaning.
What I have done this morning has fixed them and they should remain so for a long time. They work as new now with barely a touch of the key. I hope this will help others as well.
I will do a write-up and get pics assembled, until then enjoy the drama.
 :popcorn:
No drama here. I'd love to see a simple permanent fix to this problem which has plagued electronics for decades. I just hope no abrasives were involved... that tactic does destroy SOME carbon pads with very little warning and no remorse.
 :popcorn:
« Reply #59528 on: May 27, 2020, 04:20:12 pm »
I never bought one of those, it's like to admit I am dummy.
I always thought that, if you are a dummy, then you wouldn't be smart enough to realize that you need to buy one of those books.  :-//
Those are read by people how are intelligent enough to know that they are an ignoramus when it comes to some particular subject and humble enough to admit it.
« Reply #59529 on: May 27, 2020, 04:23:56 pm »
oops...
Unless you really want the very latest edition, you can get loads of these and other technical books as PDF downloads free here https://www.pdfdrive.com/
« Reply #59530 on: May 27, 2020, 04:29:15 pm »
https://www.eevblog.com/forum/repair/repairrestoration-of-a-tek-type-561b/
Been a fun project so far but every time I fix one thing something else crops up.
I'm going to let it bake for a few hours to see if anything else rears it's ugly head.
Are you suitably prepped?
 :-DD
"You're a riot, Alice"  :P :P :P :-DD
« Last Edit: May 27, 2020, 04:34:47 pm by med6753 »
The following users thanked this post: BU508A, bd139
« Reply #59531 on: May 27, 2020, 04:31:23 pm »
Pffft... amateur. I am a ASE CERTIFIED Munter.  :-DD  And that's just the ones small enough to fit in a drawer.  >:D
Oh aye laddie? Ye dee ken what a munter is, divnae ye?
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #59532 on: May 27, 2020, 04:37:02 pm »
No animals or oscilloscopes were harmed in the recording of this event.  :clap:
Offline Neomys Sapiens
« Reply #59533 on: May 27, 2020, 04:43:15 pm »
After 2 months i'm still waiting for my USB connectors. Look like I will have to change my plan for my Jim Williams pulse generator.
Ha got my connectors in the mail today. Took 103 days to get here from China. Used to take 30 days at most.
Look like 100 days is the new norm for me. Got another one after 102 days.  Was initially ordered in February  :o
My cheap 'genuine' LM3909s from China, which I ordered on the 10.5., were in the Post yesterday.
They look normal, not tested yet.
« Reply #59534 on: May 27, 2020, 04:44:31 pm »
Aye... and so should ye, as 'twere ye what gevv' me me th' name, indirectly at least, so long ago... ;)
https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/msg1874546/#msg1874546
https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/msg1875053/#msg1875053
https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/msg1875128/#msg1875128
And yes, I grok the "beaten with a ugly stick" variant as well; which, honestly, I cannae dispute.  :-DD
« Reply #59535 on: May 27, 2020, 04:55:22 pm »
Klystron on its way. Run for the hills, the sky is falling  :-DD
Noted. Looking for a bigger Klystron.
« Reply #59536 on: May 27, 2020, 05:08:12 pm »
The Tek alignment tools have arrived too. Along with a selection of adaptors extending further my capabilities in the SMC and SSMA sectors. The kit has Tek No. 003-0500-00. They are in very fine condition. The accompanying Tek sheet is marked with a check for completeness by a GAF supply sargeant.
« Last Edit: May 27, 2020, 06:06:40 pm by Neomys Sapiens »
« Reply #59537 on: May 27, 2020, 05:24:50 pm »
This is absolutely normal; a byproduct of oxidation which happens upon exposure to air with ANY baryonic matter to some extent. Carbon is a stable element, but the binders used to keep it on the silicone membrane keypad degrade with age and the surface becomes "glazed".
Add a little electrolysis from the charged PCB contacts and you get this condition which the only real cure is cleaning the carbon pads with alcohol to expose fresh carbon matrix every few years or replacing the silicone membrane itself with a brand-new one. And since they haven't been made in decades, that's pretty hard to make happen; hence the carbon pad repair kits.  ;)
Good luck getting helium to oxidise   :3
Offline Mr. Scram
  • Display aficionado
« Reply #59538 on: May 27, 2020, 05:26:49 pm »
Almost everyone is a dummy at most things, except those few experts at everything we've got here.  :-DD
Offline Mr. Scram
« Reply #59539 on: May 27, 2020, 05:27:43 pm »
Another useful tip, is that you can get some silver paint on the carbon pads if they are failing.
Traditional black carbon ink is something I've seen being used too.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #59540 on: May 27, 2020, 05:29:39 pm »
Expert - someone who knows more and more about less and less, until ultimately they know everything about nothing.
-Pat
Offline xrunner
« Reply #59541 on: May 27, 2020, 05:57:05 pm »
-Pat
I thought I was wrong once, but after reviewing it, I was mistaken in saying that.  :-DD
« Reply #59542 on: May 27, 2020, 06:21:39 pm »
Ha-ha... and the list of similar bell-end cases goes on & on. Given the right conditions and enough time etc... ;)
"The difficult we accomplish as scheduled. Impossible may take slightly longer."
« Reply #59543 on: May 27, 2020, 06:28:36 pm »
An interesting "Noob's Guide" for anybody who has seriously considered one of those cheap CNC Mills for quick one-off PCB fab.
 :popcorn:
Offline URI
« Reply #59544 on: May 27, 2020, 07:07:32 pm »
 :popcorn:
Veerry tempting!
But not enough room here saves me from my wifes disaproval.   :phew:    :popcorn:
« Reply #59545 on: May 27, 2020, 07:14:26 pm »
For the headset, I got a LogiLink HS0002 as first measure, which will fit the T60 directly. Although I ordered both the Y-cable proposed by AVG responding as well as the reverse version (to connect a two-plug headset to a integrated jack).
I do not yet know what will really suit me, because for earphones alone I am used to ultralight things which procect slightly into the ear without plugging it with a very light folding frame. Finding somthing like this with a mic would be lovely. Maybe I will try a PLANTRONICS HW540 EncorePro. Anything that is closed and/or puts pressure on my head and ears is a no-go.
Offline Saskia
« Reply #59546 on: May 27, 2020, 07:44:57 pm »
been fooling around with some X99 chipsets. Found my microSD adapters along with some rare metals (~ 2 grand) in my mailbox. Normally I would expect having to sign off on such a parcel ...
As for the klystron: hey, it's rated at 250 mW, not 150 MW. What's yer problem ? I don't think this is more dangerous than 10 kgs of liquified N2O in that steel can boiling in the sun ...
« Last Edit: May 27, 2020, 07:49:01 pm by Saskia »
« Reply #59547 on: May 27, 2020, 07:58:25 pm »
So the CRT in the Type 561B may not be going bad after all. I went to measure the HV and it's only about -1.6KV. It should be -3.3KV. That's odd. So I started checking the HV Oscillator first and clumsy me accidentally shorted the input to the oscillator from the PSU. Result is the 125ma HV fuse popped. No other damage. But do you think I have a 125ma fuse on hand? Hell no. Order submitted and I'll have some Friday.
And no, I'm not jumpering the fuse to continue troubleshooting. I may be dumb but I ain't stupid.  :palm: ;D
The following users thanked this post: mnementh, jxjbsd
Offline Saskia
« Reply #59548 on: May 27, 2020, 08:01:28 pm »
I could give you some in 7.62x51 with acoustic overload indicator  :-DD
Offline duckduck
  • 20Hz < fun < 20kHz, and RF is Really Fun
« Reply #59549 on: May 27, 2020, 08:03:17 pm »
My DHL delivery has been at stop 209 of 216 for the last 2 hours  >:(
Stop 209:
