Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 16671344 times)
Vgkid and 55 Guests are viewing this topic.
« Reply #57175 on: April 28, 2020, 08:39:43 am »
Nope, TI 83
It's not a real calculator if you have to use shift to get the exponent  :-DD
Offline capt bullshot
« Reply #57176 on: April 28, 2020, 08:53:29 am »
@Neomys Sapiens I am bidding for one, currently ...
Look what I found in one of the not yet cleaned corners ...
An HP48 calculator, as far as I recognize.
Nope, TI 83
Damn, I'm Pwned now.
« Reply #57177 on: April 28, 2020, 09:04:36 am »
Nope, TI 83
Now for something completely different:
Can you spot the HP device? And what make and model is the calculator?
The following users thanked this post: edavid, mnementh, Mortymore, bd139, beanflying
Offline Saskia
« Reply #57178 on: April 28, 2020, 09:10:07 am »
Nope, TI 83
my favorite calculator is:
saskia@morgoth> bc
« Reply #57179 on: April 28, 2020, 09:13:32 am »
dc is better  :popcorn:  :-DD
bc was actually a preprocessfor dc originally on V7.
« Reply #57180 on: April 28, 2020, 09:37:33 am »
Somebody here in Germany interested in a Fluke 3330B DC calibrator?
Pick-up only in Kraichtal Baden-Württemberg (near Bruchsal/Karlsruhe).
https://www.ebay.de/itm/143586084444
Photo from the auction:
No affiliations with the seller.
Ooh yes, I am interested, Sir!
Thank you very much for pointing at it.
And? Did you get it for 125 Euros? :)
Offline URI
« Reply #57181 on: April 28, 2020, 09:54:54 am »
Nope, TI 83
Nice bench!  :-+
I see a Casio calculator similar to mine:
BTW: Is this a real calculator?  :-//   :-DD
« Last Edit: April 28, 2020, 09:57:50 am by URI »
« Reply #57182 on: April 28, 2020, 09:58:12 am »
@Kosmic - How many petaflumps izzat? :-DD
Well for me, the real problem is in games, like WSC real09, written for XP and Vista but also worked perfect in Win7 but will install under Win10. This is also true for the most part with all of my C&C collection of games. There are now online versions of C&C that will run happily in Win 10 but you cannot buy the games on DVD/CD any more, so the urgency to set up the Dell is not as critical as it once was and besides, I don't get that much time now for games because I got back into electronics and TEA  :-DD However I would like to get WSC09 working again because they never did an updated release of that fabulous game other than on PS4 and I'm buying a games' consol just for that.
Now I'm not a programmer by any stretch of the imagination but the main problem as I understand it that programmers like to save time and work will often make calls to sub routines within the OS itself rather than write their own code for that routine and when a new version of OS comes out, if the programmers move those builtin routines to another location then the games will not run or load correctly etc because it is making a call to a location that now contains completely different code and hence the problem.
https://www.ea.com/games/command-and-conquer/command-and-conquer-remastered
Ain't I a stinker...?  >:D
*out, standing in my field*
No you're not a stinker  >:D Hmm, I might just get that download, probably worth it just for the enhanced graphics  :-+ But its the WSC09 that the real pig, because neither Steam or Origin have that available for PC updated for Win10. As an ex team snooker player, I really enjoyed potting a few virtue balls and clocking up a few 147 breaks. Helps to refresh your mind and clarify your thinking, so hopefully one day it too will get remastered.  :-+
Offline FransW
« Reply #57183 on: April 28, 2020, 10:03:00 am »
My Rubidium reference vs my GPSDO.
I probably need to find a cesium reference to know who's right and who's not.
Isn't GPS controlled by NIST & space rubidium oscillators?
PE1CCN, Systems Engineering, HP, Philips, TEK, BRYMAN, Fluke, Keithley
« Reply #57184 on: April 28, 2020, 10:17:46 am »
Yes. Casio are excused as they're quite decent. I've got at least three here myself  :-DD
Offline URI
« Reply #57185 on: April 28, 2020, 10:21:22 am »
Another one from the HP Harrison 6824A bipolar power supply / amplifier.
Now as an amplifier.
Situation: Load Test.
Input: 2.5V RMS sine wave 400Hz
Output: variable depending on amplification factor (adjustable)
First screenshot: oscillogram of the output waveform at 118,4V peak-to-peak. No distortion/clipping visible:
Second screenshot: output waveform at 121,6V peak-to-peak. Beginning of clipping at the positive peak visible:
Third screenshot: output waveform at 125,6V peak-to-peak. Clipping at the positive peak clearly visible. No clipping at the negative peak. Hmm.
Fourth screenshot: output waveform at a slightly higher amplification factor:
This looks strange to me; asymetrical and with a jump back like a limiter kicking in delayed -inspite of the negative half of the amplifier being able to deliver the peak voltage (?).
Fifth screenshot: output waveform with an even higher amplification factor:
The limit seems to be stable, the sine wave gets cut off "earlier" with higher voltage levels as it is to be expected.
I'm curious why the amplifier of that 6824A doesn't clip symmetrically.
Have to explore the service manual parts more deeply..
Didn't notice that my siglent gave hints to me while capturing screenshots..   :palm:  :-DD
« Last Edit: April 28, 2020, 10:25:47 am by URI »
The following users thanked this post: tautech, Zucca, BU508A, bd139, Kosmic
Offline URI
« Reply #57186 on: April 28, 2020, 10:27:07 am »
I'm saved!   ;)  :-DD
« Reply #57187 on: April 28, 2020, 10:34:43 am »
Well it was only trying to help stop you falling asleep at the wheel.  :=\  :-DD
Yep, lean on any of the buttons and Help pops up.
« Reply #57188 on: April 28, 2020, 10:48:07 am »
Congrats, it's exactly the same model
Offline nixiefreqq
« Reply #57189 on: April 28, 2020, 11:09:53 am »
don't think so.  the master clock for gps used to come from the us naval observatory.
maybe it changed?
free range primate
Offline nixiefreqq
« Reply #57190 on: April 28, 2020, 11:11:24 am »
I'm saved!   ;)  :-DD
don't you still owe us pictures of an hp5370a?  (or was it a "b"?)
free range primate
Offline kleiner Rainer
  • Rainer DG1SMD JN48ts
« Reply #57191 on: April 28, 2020, 11:13:49 am »
I am also in the "Casio Club". Scored at our local flea market for 35€ or so, with all accessories.
980116-0
If I have read correctly, the calculator on top is not a"real" one, because you have to shift not only for exponential functions, but for ANY function  :-DD
Rainer
Offline nixiefreqq
« Reply #57192 on: April 28, 2020, 11:21:58 am »
holy shit.  did bd just come out?
welcome to the world of "=".
shall i count you as recovering from "rpn"?
you should start attending meetings or risk a backslide.
free range primate
« Reply #57193 on: April 28, 2020, 11:26:13 am »
They’re standard here for schools so I need to know how to use them. The 991EX is ok.
Just not as ok as the 35s  :popcorn:
Offline nixiefreqq
« Reply #57194 on: April 28, 2020, 11:26:36 am »
half english foxhound.  but with good taste in calculators.
free range primate
« Reply #57195 on: April 28, 2020, 11:33:52 am »
To me, this poor dog is looking very sadly, like someone who's missing his beloved HP48G.
 :popcorn:
The following users thanked this post: mnementh, Neomys Sapiens, bd139
Offline nixiefreqq
« Reply #57196 on: April 28, 2020, 11:36:43 am »
 :popcorn:
what that look really means is:
"if the guy with the camera looks away i am gonna chew the shit outa' this thing leaning on my leg"
free range primate
The following users thanked this post: BU508A, mnementh, bd139
Offline Ero-Shan
« Reply #57197 on: April 28, 2020, 11:49:32 am »
Alas, no. I was the one offering 120 bucks. :( Got to continue the tradition of "second best offer".
I just wish I knew how much the winner was willing to pay ... Or better not. If that actually was the limit, I'd be really pissed off.  >:(
« Reply #57198 on: April 28, 2020, 11:54:48 am »
Hei, anybody here in need of an AC calibrator from YEW, the YEW 2558?
https://www.ebay.com/itm/402247018317
Picture from the auction:
« Reply #57199 on: April 28, 2020, 11:58:10 am »
Sadly to hear this.  :(
If I'd bid for that thing, I think I'd have set my limit to around 350 Euros. Usually, these 3330B are going for much more.
More luck next time.  :-+
