So IMO this is in essence a back of cigarette packet drawing updated to try to make it clearer and easier for everyone to understand. I understood it perfectly.
Thanks everybody for your inputs.
As I wrote I discover that massive wiring error the night before at bed time, the next morning I could not resist to tell you guys... so open up POWER POINT (yes I it was a PPT) at work and draw some line to get the concept over.
Sorry for all the confusion I created, anyway some of you understood it perfectly what was going on.
Anyway behind a STDP switch (the right one in my terrible schematic, where the live light cable is connected at the "T" pole), I found a fourth cable (yes the live plug cable....) with was connetcted to one of the two "P" switch poles. I moved it to the "T" switch pole and at least I got some sense out of it. Now when the light is on also the plug have 220VAC.
Anyway I am planning to install a new live line that goes to that plug (no more switched plug, thank you...), I don't want to tell you how I will do because I am scared you will yell at me.
No worries it will be safe, but I don't know if it would be allowed by Germans regulations.
Is still general point open for me, I know exactly how to lay down safely a 220VAC wire/line but I do not know what are the German/(european/italian) regulations.... do you know it? Or better said, is your good common sense enough for you or you dig into regulations for wire home stuff
Well ok...., I will tell you with picture I want to see how bad I am solving the problem.
