Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 16700169 times)
shakalnokturn and 128 Guests are viewing this topic.
Offline Kosmic
« Reply #55250 on: April 10, 2020, 03:02:00 pm »
thought of some social warrior stuff which I will submit to our company as an idea for their making more health initiative.
take a COTS aluminium box.
https://www.ebay.de/itm/ALUBOX-B-184-Liter-Alukiste-Werkzeugkiste-Vollaluminium/372879388124?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
take a finished starter/socket for a UV-C lamp
https://www.ebay.de/itm/VOSSLOH-SCHWABE-Vorschaltger%C3%A4t-f%C3%BCr-PL-S-Dulux-S-Ralux-S-5W-7W-9W-11W-m-Fassung/143557445482?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
and the UV-C lamp
https://www.osram.de/ecat/PURITEC%20HNS%20UV-C-UV-C%20lamps%20for%20purification-Ultraviolettstrahler-Industrie-Spezialbeleuchtung/de/de/GPS01_1028570/PP_EUROPE_DE_eCat/ZMP_60796/
which will give me 3W of UV-C at a distance of 1m from the center of the lamp
Utilize UV resistant bonding tape (3M VHB) to attach this to the lid of the box and
https://www.ebay.de/itm/Montageband-Allzeckband-Universalklebeband-3M-VHB-Klebeband-4611F-19-mm-x-3-m/223575290338?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Cabling is not too expensive.
https://www.ebay.de/itm/Anschlussleitung-Zuleitung-mit-Zwischenschalter-Stecker-Netzkabel-Stromkabel/352890295170?ssPageName=STRK%3AMEBIDX%3AIT&var=622145810635&_trksid=p2057872.m2749.l2649
An inverter running off a lead-acid battery can easily be added. You can also put in a standard grill shelf rack https://www.ebay.co.uk/itm/BBQ-Adjustable-Grill-Shelf-Rack-Extendable-Screw-Fix-Arms-Barbecue-Grid/191404896648?hash=item2c909ef188:g:5TUAAOSwabhUXMjN
to lift the stuff to be irradiated and make sure the UV gets to it from all sides.
To make sure the dosage is sufficient, irradiation time should be no less than 10 minutes, preferable twice the amount.
It would be possible to swap out the lamp for a higher dosage lamp, but those would draw more power.
What do you think ?
Did I overlook something critical ?
Even more ghetto, a simple carboard box with aluminium paper inside  ;D
I used this setup to retrobright parts. Now I can sterilise my mail  ;D
Offline Kosmic
« Reply #55251 on: April 10, 2020, 03:11:08 pm »
Man I think the mail system is seriously clogged over here. Have been waiting for my usb connectors from China for 2 months now and they are nowhere to be seen  :-\
Offline Saskia
« Reply #55252 on: April 10, 2020, 03:12:49 pm »
I know. The idea was to be able to have something somewhat sturdy that would survive but still be easy to produce and halfway safe. That can be stowed away safely, airlifted, mailed, etc.
Our company has some health initiatives world wide. Now, given the current crisis, our colleagues in india, in the philippines, etc are suffering. This would give them the opportunity to build something sturdy which is still easy to obtain and does not cost a fortune. my first idea was to improvise using an easy to get G23 lamp and a cardboard box. But, for logistics, durability and sturdiness I thought this setup might be better suited.
« Reply #55253 on: April 10, 2020, 03:13:24 pm »
I think it's everywhere involving international. The HP probes for AVG didn't kick back a 2nd time from US Customs but who knows where they are at now.
Offline ArthurDent
« Reply #55254 on: April 10, 2020, 03:13:55 pm »
... Worried about getting trampled by the wrinklies   :-DD ...
I resemble that remark! Beware, what we lack in youth we make up for in subterfuge.  ;D
I've whiled away my breakfast-time this AM noodling around this fellow's yoobToob: https://www.youtube.com/channel/UCMuCEiwVy_jvFmboAEYGwjg
His hobby is creating animation to go along with the original BBC Radio show of HHGttG; rather good actually and very faithful to Adams' written works. Unfortunately, the Beeb has been forcing places like YT to take down his works and Ep 1 Pt 1 is no longer up. However you CAN, if you care to, find most of it on his channel in bits & bobs.
Somehow, this fellow's whole debacle of "Fair Use" vs the interests of the corporate megalopoly etc. feels very Adams-esque in its own right...
*off to brave the wilds of Wally Wurlld*
Here's a version of me, er, Arthur Dent, in real life for the same episode above starting at 18:40 minutes.
« Reply #55255 on: April 10, 2020, 03:16:12 pm »
Queueing for supermarket here again today. The locusts have eaten all the good stuff again  :-DD
I presume by that you mean the teenaged locusts you keep as house pets rather than the locusts that cleaned the supermarkets out.
Offline Kosmic
« Reply #55256 on: April 10, 2020, 03:16:31 pm »
I was joking with my box. I prefer your idea. Never seen aluminum box like that over here though.
Offline Kosmic
« Reply #55257 on: April 10, 2020, 03:17:38 pm »
You could add a timer to stop the lamp automatically ? also maybe a red led that let you know the lamp is active ?
« Last Edit: April 10, 2020, 03:20:49 pm by Kosmic »
« Reply #55258 on: April 10, 2020, 03:27:09 pm »
Interlock switch for the lid? (Commenting as I'm catching up, so ignore me if someone else has said this in the interim.)
The following users thanked this post: BU508A, Saskia
« Reply #55259 on: April 10, 2020, 03:33:14 pm »
What do you think ?
I would add a safety switch. As soon, as the box gets opened, the lamp should be switched off immediatly. I'd realize this with two reed contacts and a magnet, probably at two opposite positions.
The following users thanked this post: Saskia
« Reply #55260 on: April 10, 2020, 03:35:02 pm »
Gee, with everyone being sheltered in place and bored out of their skulls this thread has gone nuclear.  :-DD
Offline Saskia
« Reply #55261 on: April 10, 2020, 03:37:47 pm »
an interlock switch is an excellent idea. Will add that to the design but need to think about the details. The insulation needs to be UV proof.
Online Ice-Tea
    • Freelance Hardware Engineer
« Reply #55262 on: April 10, 2020, 03:39:54 pm »
Was closing up a a 8563E after some heroic fights. Having learned from past experiences, I did a quick power up test after each layer of the sandwhich and sure enought, after layer 37,5 something started smelling foul and smoke spiraled out of the depths. Suspecting, as always, the power supply I dissasembled until I had it bare again and started the camera roling so I could catch the culprit in the act. Only thing is: it wasn't the power supply (you'll note my surprise as I was focused on the PSU and had to pan to the CRT driver. Odd thing is I can't find anything burned there.
I've sunk a *lot* of hours in this bitch already. I'm not gonna yield?
https://ftrnf.com/EEVBLOG/1.mp4
« Last Edit: April 10, 2020, 03:55:16 pm by Ice-Tea »
Online tggzzz
« Reply #55263 on: April 10, 2020, 03:47:33 pm »
Went shopping this morning, arrived at Tesco's just on 8  o clock as they opened the doors, the queue was already snaked up and down the parking lanes 4 times and around the outside edge of the car perimeter, store side and then store front. I thought F that and drove down the road to Lidl where there was about 30 people in the queue, but even then it took almost an hour before I was allowed in the store. Once inside though it was almost back to normal with most stuff on the shelf in reasonable volumes. The shopping trip, to just 2 shops, next to each other, Lidls and FarmFoods, took almost 2 and a half hours  :wtf::palm:
I went to a local Polish deli and a greengrocer. I was very annoyed to have to wait 5-10 minutes to get in each of those. It looks like "YMMV" :)
« Reply #55264 on: April 10, 2020, 03:48:01 pm »
https://photos.google.com/photo/AF1QipMVtT3YJD7qPGAj9-mGeXF5q60AfZKBA7XOQeo0?hl=nl
There's something wrong with your link. No go.  :--
« Reply #55265 on: April 10, 2020, 03:52:42 pm »
Correct :)
I made the mistake of buying various craft things in poundland for the young one as well which are now stuck to everything.
Sort of like this
« Last Edit: April 10, 2020, 03:54:21 pm by bd139 »
Online Ice-Tea
« Reply #55266 on: April 10, 2020, 03:55:38 pm »
Thanks for the heads up. Better?
« Reply #55267 on: April 10, 2020, 04:02:35 pm »
Nope. 404 error.
Online Ice-Tea
« Reply #55268 on: April 10, 2020, 04:04:54 pm »
Did you try the original link or the one I replaced it with?
« Reply #55269 on: April 10, 2020, 04:08:34 pm »
Perhaps an emergency switch is a good idea, too.
« Reply #55270 on: April 10, 2020, 04:19:16 pm »
That works.  :-+
« Reply #55271 on: April 10, 2020, 04:20:59 pm »
More Heathkit tear downs to tempt bd.  :-DD
IG-4244 Oscilloscope Calibrator.
« Reply #55272 on: April 10, 2020, 04:21:47 pm »
My first thought... honestly:   "Can you say 'Major Litigation', boys and girls...?"
Point being... it's one thing to present this as a DIY project for a third party; by taking part and building it they take responsibility for using it properly and safely. ie, ensuring it's wired properly and seals in all UV light, ensuring no inappropriate materials are irradiated with it, ensuring it doesn't get left on and burn someone's house down, etc...
But if any part of your company takes part in producing it or providing the components for any end-user... I can see a dozen different potential avenues of liability, just off the top of my head.
 :scared:
« Reply #55273 on: April 10, 2020, 04:24:07 pm »
For our canadian TEA voltnut fellows (and the ones in the USA, too):
https://www.ebay.com/itm/324130874459
Fluke 845AR
 8)
Offline Saskia
« Reply #55274 on: April 10, 2020, 04:29:40 pm »
point taken. They may go through the effort to validate the design, though. The company is big enough to be able to do just that. We'll see.
