Since replacing my old workbench, I didn't any longer have the the inrush-current limited extra outlet for my Philips variable isolation transformer. I wanted to use a Grundig (yes, Grundig, me!) one in a more practical housing, but that lacked a few features. So I ordered one of those combo meters, which arrived a week ago.
So, today's project: Replace the moving pointer voltmeter by a combined volt/amps meter. Clean up the very dusty inside, add an inrush current limiter, tighten the loose screws on the transformer.
Mostly (dirty) mechanical work, fastening the cap rail for the meter turned out to be quite a task.
Eventually it was finished. Yes this took most of the day! Still not the most beautiful, but it does its job.
At last I have that important piece of gear ready to use again.
Nicely done! What did you use for the inrush limiting?
About 15 years ago, we (developers) moved to a different building. The DCS guys where transferred to a different place, far away. In the deserted building remained a pile of trash, where I found a small black box with 4 FASTON terminals, labeled OUT L, IN L, IN N, OUT N. Didn't know what it was, but kept it.
When I brought those hauls in - now about 2.5 years ago, there where these isolation transformers I knew to trigger circuit breakers. While rummaging through my belongings, I came across that small box and opened it for the first time. I saw a biggish NTC, a little electronics and a relay.I actually couldn't believe it: That was exactly what I needed!
It is this:
Sorry for the lousy pic, but it was awkward to take.
