Yep I just realised that the 4000 on the input ranges actually refers to 4,000k
![Ohms \$\Omega\$](https://www.eevblog.com/forum/Smileys/default/omega.gif)
and 1,000v max input DC and 700v AC so it's not a major problem after all with a little thought, I can use 230Vac as the input source for both the 400v and the 750Vac ranges and it will be near enough for function. When it comes to DC, I have my Heathkit RC bridge which generates around 360Vdc and by comparing the readings against a known good meter, I can then enter those values into memory and it will fit for my purposes.
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
I'm going to hold off doing any more calibration on this until the correct battery arrives, hopefully tomorrow, then I can reassemble it correctly with all the proper screening in place and then it should be job done, another British built piece of TE on my bench
