This pleases me...Family (and TEA family on the Discord
) finally let me get away long enough to finish installing Fusion360 & Cura; this is the first actual print off the machine.
I'm using the Alfawise U30 profile built into Cura 4.5; I've done precisely ZERO tweaking of the model except to select fine .1mm LH. Really hard to get better than that stock out of the box; some "Elephant foot" distortion of the bottom few layers is responsible for the difference in the Z-axis. I'm printing another one sliced with bed at 50°C instead of the profile default 60°C; also releveled "a hair looser". What I can see has no such distortion; if it completes successfully, I'll start a benchy with the same settings before I toddle off to ded.
BTW... the TouchScreen UI is just... sweet. Everything you need to USE the thing, laid out in an intuitive fashion. Of course no command-line UI; if you want to tweak the Marlin FW you'll have to do it the hard way via serial.
