As I'd finished my parenting (moving children between the bed they fell asleep in and the one they're s'posed to wake up in) that cut my Discord participation short I actually went and time-nutted for a bit. Weather here today was sunny and crisp, not too cold, just about freezing so I've been getting on with the GPS move a bit. (the part where bd139 sticks his antenna to the window and declares "Done"
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
I routed the antenna cable down, in under the garage, so that it shows up under the raised flooring in the machine room. There it'll meet a lighting arrestor and then continue up inside the cabinet that holds my computers. The antenna and lighting arrestors have N sockets, and the receiver has BNC. I had to cut the cable to get it through the plastic conduit that protects it going in, and I needed a short BNC-N cable for the last bit.
Just spent an hour building the short cable, routing it down through the floor of the computer rack, connecting it to the arrestor, making a ground cable to go from the ground rail to the arrestor, and pondering the "fun" of terminating a N plug onto RG58 while crouched up in a ball below the raised floor. There's not much room there, and the coolant pipes pass through where I'm supposed to sit. Wonderful.
OTOH, the part where I pulled the cable through conduit had me scurrying from the roof down into the machine room and back up some 5 times; a three-ladder climb with some acrobatics.
