Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 16862278 times)
factory and 155 Guests are viewing this topic.
« Reply #51350 on: March 05, 2020, 07:05:38 pm »
And I have a surprise. A TEA related activity involving leather!  ;D That should grab the dragon's attention.  :-DD No additional clues, you'll just have to be patient.  :popcorn:
A Leather Dragon Tail Whip perhaps?   :-DD
I have these pre-sorted "capacitor packs" for instruments that are getting re-capped. All these are for Flukes. 8010A, 8050A, 7260A. I have a few more to build up but I have to submit another order.
No big one, it'll be a replacement handle thats all folks.  >:D ::)
« Reply #51351 on: March 05, 2020, 07:21:36 pm »
I have a lot of the blue Park Tool in my garage.
Park Tool=Agilent/Keysight=TTi
Park Tool MK-297 Master Tool Kit By: Park Tool $7,795.95
 :wtf: :wtf: :wtf:
I understand your comparison. That is a lot of money.
« Reply #51352 on: March 05, 2020, 07:53:08 pm »
Here are the internal shots of this nice GW GOS-310 scope. It is as if it just left the factory inside there is not even a spec of dust, beautiful, What is so amazing is that I can only actually spot 1 IC in it, its all made from discrete parts so should be very repairable is later life should it need it to be repaired. Nice to see a linear power supply inside this puppy as well. All the PCB's are nicely and clearly labelled what the voltages and adjustment pots etc are, nice to see. Those 3 HV caps are the EHT caps for the CRT circuitry.  The single IC is to far away and is only 8 pin die, making reading the date code impossible without completely dismantling the scope to gain access to it.
« Last Edit: March 05, 2020, 07:55:24 pm by Specmaster »
The following users thanked this post: xrunner, bitseeker, BU508A, med6753, mnementh, bd139, grizewald, Kosmic
Offline VK5RC
« Reply #51353 on: March 05, 2020, 08:01:12 pm »
Yup got some nice Park tool gear,  they keep coming up with new good stuff, Calvin is a -'legend' (for those who don't watch, he is Park tools youtube bike mechanic) - cue Monty Python bicycle repair man jokes!
Offline Mr. Scram
  • Display aficionado
« Reply #51354 on: March 05, 2020, 09:13:33 pm »
Now I finally have a dedicated electronics bench and I'm setting things up but I'm finding I can't fit it all on the sodding desk. Not sure that's a win or a loss.
« Reply #51355 on: March 05, 2020, 09:28:26 pm »
That's one reason I just ripped my entire corner and cupboard out and started again with a larger desk and a different objective of just getting stuff out I need at the time and buying stuff I need when I need it. There just wasn't enough space for it all on there however I organised it!  :palm:
Having night off TE. I fired up the K2 again after a month break and made a CW contact instantly with someone who wasn't a complete tit. And I'm hooked on that crack again :-DD
Also considering buying a KX2 as it's small and I'm going to be in and out of hotels for a bit and you can usually get an end fed out a window if you're sly about it  >:D
Offline Brumby
« Reply #51356 on: March 05, 2020, 09:30:24 pm »
It'll never be big enough.
« Reply #51357 on: March 05, 2020, 09:40:16 pm »
My grandfather suggested the same. I remember clearing his house after he dropped dead. The issue was not the workbench size, which was around 200 square feet
across three walls (!) but the amount of crap he'd collected and put on it  :-DD
« Reply #51358 on: March 05, 2020, 10:41:33 pm »
Are you talking about benches or BD139's 'end' fed out of a hotel window?
« Reply #51359 on: March 05, 2020, 10:45:01 pm »
Neither  :-DD
Online Kosmic
« Reply #51360 on: March 05, 2020, 11:55:08 pm »
I spend almost half my time reorganizing my place. If I don't do that, the repair queue naturally invade the bench. and I have 3 of those now. I think I need to requisition a closet to put the repair queue.
Offline worsthorse
  • aina varma, usein väärin
« Reply #51361 on: March 06, 2020, 12:22:43 am »
I have a KX1 for traveling, but these days, why not build something like the QCX for 20 meters instead?
Offline URI
« Reply #51362 on: March 06, 2020, 12:33:40 am »
I have also reorganized my bench as I wrote some weeks ago (photos still to be made, not ready yet).
One positive effect is being able to pull out single instruments out the rack.
I used that for swapping the quartz in my HP 3456As that determine the integration time of the A/D conversion from the 60Hz-type to the 50Hz-type.
I ordered some custom made quartz built to HP specs some years ago and had them waiting for use since then -because swapping them in would have meant to tear down all the stack my HP 3456A were sitting in.   :palm:
Since the change in noise level with the right quartz (50Hz type) was noticeable I decided to do some statistics using the built in the 3456A statistics functions.
(I also tested my shorting plugs with this.)
I checked my two working units #1 and #2, each with 50Hz-synchronous integration time and once with 60Hz-synchronous integration time.
Auto-zero was ON and filter was OFF.
Here's the raw data:
#1 / 50Hz
#1 / 60Hz
#2 / 50Hz
#2 / 60Hz
upper
-00.0000E⁻3V
+5.40000E-6V
+1100.000E-9V
+6.00000E-6V
lower
-4.00000E-6V
-7.40000E-6V
-2.40000E-6V
-6.00000E-6V
mean
-1586.778E-9V
-1634.096E-9V
-521.938E-9V
-602.368E-9V
variance
0.000049E-9V
0.004099E-9V
0.000036E-9V
0.002787E-9V
count
141.8320E3
147.3180E3
124.5800E3
157.3460E3
It's clearly visible that the "right" quartz for the A/D integration time being synchronous to the mains power (50Hz in my place: Germany) has a significant effect; it's roughly a factor 100 looking at the variance.  :o
I'm quite pleased about these results.   :-+   :)
I started the same test with my 3457A and it seems to be worse by roughly a decade (~147E-9V);
It's significantly noisier -but that's no surprise when taking it's front end construction into account..   :palm:    :popcorn:
Conclusion: Do work with the HP 3456A only with the right integration time, use the right quartz for synchronizing the A/D-conversion integration time to the frequency of your mains power systems in your place. Otherwise you loose roughly two digits resolution to (unnecessary) noise.
Edit: Added conclusion
« Last Edit: March 06, 2020, 12:39:11 am by URI »
The following users thanked this post: BU508A, mansaxel, grizewald, Kosmic, syau
« Reply #51363 on: March 06, 2020, 01:57:05 am »
   Just wanted to share with you all how much I *hate* the HP8563E.   Hate. HATE. HAAAAAAATEEE!!
Yep, you're right. But does that help you?   >:D   :-DD   It got better with newer designs like the ESA-E/E440xb-series..   ^-^
Got one of those too. But luckily troublefree. Almost. Except for a chirp. Not opening it though, I'm not nuts.
But... but... how can you not just lurrrrrve all that gorgeous HF plumbing...?   >:D
THIS is gorgeous RF plumbing:      The HP856x? Not so much.
I find hardline coax mildly pornographic. Loathe working on it; love looking at it. >:D
Perhaps...  >:D
*toddles off for couch-tuber time widda boi*
« Last Edit: March 06, 2020, 03:44:13 am by mnementh »
« Reply #51364 on: March 06, 2020, 01:58:54 am »
I have an entire closet dedicated to TE. Repair queue, parts mules, loose parts, books, documents, etc.
Offline angrybird
  • Country: pr
  • I have a particular fascination with birds.
« Reply #51365 on: March 06, 2020, 02:01:59 am »
Ahh, the test equipment thread.
duct taped man
leather whip
Ok I'm gonna go over somewhere else right now.... *slowly backs away*
THE CAKE IS A LIE AND THESE NUTHATCH ARE WAY TOO DISTRACTING
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #51366 on: March 06, 2020, 02:29:42 am »
In my case I have pretty much an entire house so dedicated... :o
-Pat
Online Kosmic
« Reply #51367 on: March 06, 2020, 02:50:44 am »
-Pat
Yeah I remember seeing pictures. Looked like a fun place to be. You should do a party at some point  ;D
Online Kosmic
« Reply #51368 on: March 06, 2020, 03:09:21 am »
So as every voltnut, I was looking for some good quality, low thermal EMF binding post. The only problem is that apparently Im a cheap bastard and I can't resolve myself to pay the 13$ apiece Pomona is asking for (Pomona 3770).
So I started by ordering varieties of cheap binding post from eBay and aliexpress, hopping that one of them would really be "Pure Copper" as advertised. Conclusion, there is some good quality brass binding post but they are not in copper and not low EMF.
One night, while I was endlessly looking for something to buy on eBay, I stumbled on some NOS binding post  advertised at 1$ apiece from a seller in Texas. They looked like the binding post ESI was using on their metrology instruments. So I decided to bite and ordered some.
After doing some tests (magnetism, weight, density, color of the metal and my clumsy attempt of measuring the Seebeck coefficient) I concluded they were, like the ESI binding post, in fact low thermal EMF gold plated tellurium copper.
No name NOS binging post on the left, ESI binding post on the right.
So really quickly I ordered everything the seller had to sell  :P
« Last Edit: August 12, 2020, 02:46:50 am by Kosmic »
The following users thanked this post: xrunner, mnementh, grizewald, syau
« Reply #51369 on: March 06, 2020, 03:31:57 am »
You greedy bugga you didn't even try and share  :P
I need to stump up and buy some good ones for my Hamon Divider build. I do have some old Silver plated copper posts but it makes more sense to go to 4mm bananas. Going cheap is an option but it isn't doing the Resistors and Trimmers justice  :scared:
Online Kosmic
« Reply #51370 on: March 06, 2020, 03:35:23 am »
Apparently there is more where it came from. I'm trying to see if I can buy the whole lot  :P
In any case, if I get everything or some more pop on ebay, I'll let you know.
Offline Brumby
« Reply #51371 on: March 06, 2020, 04:13:34 am »
Bean ... going bananas .... ... ...
Made me chuckle  ;D
« Reply #51372 on: March 06, 2020, 05:20:38 am »
Have we become as obsessive as the audiophool trying to get his system's total harmonic distortion from an inaudible 0.02% to 0.01% ? Is this our ultimate fate? To be just like them?
"Low thermal EMF binding posts" to gain one more least significant digit confidence out of an 8.5 digit DMM. Are we just as nuts as they are?  :palm:
The lines between reality and fantasy are blurred.  :D
The following users thanked this post: mnementh, Specmaster, Mortymore
« Reply #51373 on: March 06, 2020, 06:01:48 am »
Yeah, I'm considering bringing the FT817 with me if I go to NAB in Vegas in 7 weeks time. With the current situation on covid-19, we're on international travel ban, so not very hopeful.
« Reply #51374 on: March 06, 2020, 06:05:58 am »
duct taped man
leather whip
He's still an apprentice (in his final year admittedly), so he's a boy rather than a man, in industry parlance...
Hmm, now I think about it, that makes it sound worse...
