The 7061 has arrived!
Thankfully, it was well packed and has survived the journey from The Netherlands to Sweden without damage. It even seems to work!
More COTO relays and precision resistors than you can shake a stick at.
Upon opening the case, I was greeted by the left over smell from when the previous Schaffner mains filter committed suicide. The remnants of the smoke created by the boiling pitch are easy to see.
The white plugs on the voltage selection part of the filter are actually much more dirty than the photo would suggest. At least I don't need to immediately order a new filter.
There is a small problem which needs immediate attention though...
Maybe those batteries should be called "Time Bomb" instead of Mempac?
