I used the term VERY loosely...
They're somewhere between a Red Ten and pre-Tandy Radio Shack: www.sayal.com
That said; I found the driver PCB from a CFL bulb in the bottom of a box; it has some BV32s on it. A little overkill voltage-wise, but should be plenty to switch a 80mm fan if they aren't leaky as hell from the hard life they lived...
*back to the bench*
Quick look at their site appears to be mostly surplus crap.
Naaahhh... they have lots of tools, as well as all the crap your typical alarm/AV-HT/SOHO Network Cabling installer would need, as well as a good assortment of discrete components and some common semis. Just do a product search for different classes of components (like zener, for example) and you'll see what I mean. What they advertise is the closeout crap they got cheap; trying to get normal folks in the doors.
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=922254;image)
After futzing around making my little switch PCB and finding the low beta of the BV32s meant base current was high enough to be disruptive to the control circuit,
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
I had a double-take and realized that the EASY solution was just to drop a 78xx across the switched 20V rail on the thing and put it under a screw on the PCB.
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
I've got a 7808 handy; it offers the added benefit of dropping minimum RPM on the 80mm thermal-controlled fan to silent operation levels. Gonna let the beast cook overnight, see if I can catch the fan cycling on in the AM.
*shakes brain like a magic 8-ball*
HEY...! Brain cell that came up with the 7808 idea! WHERE THE FUCK WERE YOU 4 hours ago...?[ SIGNS POINT TO GO FUCK YOURSELF ]Dammit... even my own brain has to fuck with my head...
![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
*toddling off to ded*
