Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 18861146 times)
0 Members and 57 Guests are viewing this topic.
« Reply #48700 on: February 03, 2020, 07:53:42 am »
@Zucca Ender FTW!
Ok looks like I didn't blow up the NanoVNA. The SMA connector I was using had a Chinesium fracture. I ran the cal cycle on the NanoVNA and it was fine. Phew!
Well the RF amp is well and truly buggered. It's only a small signal front end amplifier but the damn thing doesn't work. It worked perfectly in LTspice and on the NanoVNA for about 2 mintues. One min it's pulling 20mA, next minute 8mA and the thing is toast. I have replaced every part and it's still damn pulling 8mA. I built the entire amp again with new parts and it's pulling 8mA fine but only 3dB of gain not 15dB. Can't figure it out. I tried tuning it with a receiver to see if it's oscillating - nothing. Probing it with scope / finger - nothing.  >:(
It actually forward biases an LED successfully by 0.8V by the looks which is a big WTF. Unless it's oscillating at 400MHz+ or something which a PN2222A shouldn't be able to do.
Are you sure it's a PN2222A?  Just sayin'
* worsthorse wanders out of range.
Yeah that batch was legit from RS. I woke up this morning and have come to the conclusion the design sucks so I’m going to switch it out for a W7ZOI design instead.
Offline Martin.M
  • in Tek we trust
    • vintage Tek collection
« Reply #48701 on: February 03, 2020, 08:00:38 am »
GBP goes ready for my Solartron DMM  :)
waiting to the next -48%
I need a 6 1/2 or better 7 1/2 with panaplex displays  8)
(just for playing with..)
« Last Edit: February 03, 2020, 08:14:13 am by Martin.M »
Offline Zucca
  • EE meid in Itali
« Reply #48702 on: February 03, 2020, 10:27:12 am »
Next step:
https://www.creality3dofficial.com/products/ender-5-pro-3d-printer
Where I should buy my new Ender 5 pro, aliexpress?
I will also buy a glass bed, moreover I have PLA but maybe I throw 2 more in the bin, anything else I should add?
https://www.aliexpress.com/item/4000451834825.html
1:Ender-5 3D Printer and Glass + 2KG PLA Filament(Random Color)
It looks like the 2019 upgrade,
Officers I am clear to fire, let me know if I can pull the trigger.
Offline Mortymore
  • Country: pt
« Reply #48703 on: February 03, 2020, 10:28:04 am »
Edit, here it is. The batteries died years ago and I suppose I could get in there and change them.
I replaced the batteries on my PULSE CD case, a few weeks ago. The battery support is reversed,  :wtf: at least on my CD case and since I had forgot that issue, there was some head scratch before I realyse that once again.
Offline Brumby
« Reply #48704 on: February 03, 2020, 10:42:33 am »
You have to ask?
DO IT!
(unless someone has a better deal they know of)
« Reply #48705 on: February 03, 2020, 10:42:41 am »
Next step:
In the first 6 months to a year another couple of 0.4 nozzles and another bit of Capricom tube. The rest is unlikely. Check locally you should find PLA in the colours you want for less $ too. Glass Bed  :-+
Offline Martin.M
  • in Tek we trust
« Reply #48706 on: February 03, 2020, 11:38:37 am »
I have a bunch of resistors 10k 5W.
Connected to 230V AC line that is a pretty good heater of 5W.
So 6 of them between 2 Aluminium sheets to become a 30W Heater for my chili seed boxes.
The little corns need 28°C. I will build 3 heaters now.
one month later the little chilis can go out in the room for normal temperature, when they have 4 libs.
Test gear: John Fluke, 2190A with K Type sensor.  :popcorn:
I have some chili from india, spicy,
some from thailand, hot,
Jalapeno from mexico, spicy,
and the Trinidad Moruga Scorpion Chili, skull, 2 mill. scovilles  :-+
baby water melones, some cocktailtomatoes...
all to seed now. The climatic change provides some hot things in the garden
« Last Edit: February 03, 2020, 11:57:13 am by Martin.M »
The following users thanked this post: grizewald
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #48707 on: February 03, 2020, 12:45:03 pm »
You have to ask?
DO IT!
Like askiing a group of drug addicts if they want to try a crack pipe.  :-DD
The following users thanked this post: Zucca, AVGresponding
« Reply #48708 on: February 03, 2020, 12:47:09 pm »
Yep  :-DD
Offline Zucca
  • EE meid in Itali
« Reply #48709 on: February 03, 2020, 12:50:47 pm »
It was more: is this the best crack outhere?
BTW, it took one of your words to convince me.
My brain is remote controlled by one of your TEA systems... bastards!
« Reply #48710 on: February 03, 2020, 12:54:55 pm »
You have to ask?
DO IT!
(Attachment Link)
You mean: Like asking a bunch of TEA members, if they are interested in buying this palette full of test gear for USD 50.-  :o  :-DD
Edit:
Example:
Description:
4 Oszilloskope
    (1 Stück Philips/Fluke PM3082, Bandbreite bis 100 MHz;
     1 Stück Tektronix TDS420, Bandbreite bis 150 MHz;
     1 Stück HP 54601B, Bandbreite bis 100 MHz;
     1 Stück LeCroy Waverunner LT344, Bandbreite 500 MHz);
2 Millivoltmeter R&S URV 4, 10 kHz bis 2 GHz;
1 Datenleitungsmessgerät Wandel & Goltermann DLM-4,
    Frequenzbereich 200 Hz bis 4 kHz;
2 Zweikanalverstärkereinschübe Tektronix 7A18;
3 Oszilloskope Philips PM 3206;
3 Anzeige- und Bediengeräte Litef DE 64, 30 V, mit Tastatur u. a.;
zum Teil unvollständig bzw. defekt.
Link:
https://www.vebeg.de/web/de/verkauf/suchen.htm?DO_SUCHE=1&SUCH_MATGRUPPE=1170&SUCH_STARTREC=0&SUCH_NOPAGINATION=1&SHOW_AUS=2008170&SHOW_LOS=58
« Last Edit: February 03, 2020, 01:05:09 pm by BU508A »
« Reply #48711 on: February 03, 2020, 01:00:01 pm »
I'd be saved by the shipping costs, in that circumstance...
I see so much nice gear from Fluke and Keithley etc at nice prices, then I look at the shipping costs from the US and I go away and cry inside a little...
Offline SilverSolder
« Reply #48712 on: February 03, 2020, 01:20:14 pm »
You just take a van across the Channel to pick it up!  (assuming this is permissible in the new free Britain of course)
Offline WastelandTek
« Reply #48714 on: February 03, 2020, 01:26:28 pm »
Wes is one brilliant MFer, I have a WA7MLH implementation of his spectrum analyzer here that is one of my most prized instruments.
« Last Edit: February 03, 2020, 01:29:28 pm by WastelandTek »
I'm new here, but I tend to be pretty gregarious, so if I'm out of my lane please call me out.
Online med6753
« Reply #48715 on: February 03, 2020, 01:31:29 pm »
Look at this. Was in Michigan. You don't how bad I wanted to make a road trip but realized....where would I put it all??  :o :-DD
https://www.facebook.com/marketplace/item/863047330818573/
Offline Brumby
« Reply #48716 on: February 03, 2020, 01:34:19 pm »
Do what I do ... MAKE it fit.
(Which reminds me ... I gotta do something with the garage.   ;D )
Online med6753
« Reply #48717 on: February 03, 2020, 01:37:32 pm »
That's where most of it would wind up, out in a damp garage.  :--
« Reply #48718 on: February 03, 2020, 01:41:19 pm »
Spot on. I've been collecting parts to build that for a while. I have all the minicircuits bits  :-+
Offline Brumby
« Reply #48719 on: February 03, 2020, 01:47:19 pm »
My garage isn't too damp - but it would be other things that get dumped out there.  Test gear stays in the house - maybe stashed somewhere generally inconvenient - but in the house.
« Reply #48720 on: February 03, 2020, 01:49:53 pm »
Doooo it! I was really lucky, Jeff worked at Tri-Quint at the time and we would sneak in after hours and use state of the art gear to tune the xtal filters and such.  Good times.
« Reply #48721 on: February 03, 2020, 01:52:37 pm »
The girl hasn't grumbled too loudly, but the Tek frames awaiting work have kind of invaded one side of the pantry...
« Reply #48722 on: February 03, 2020, 01:57:06 pm »
Next step:
https://www.creality3dofficial.com/products/ender-5-pro-3d-printer      Where I should buy my new Ender 5 pro, aliexpress?
It looks like the 2019 upgrade,   Officers I am clear to fire, let me know if I can pull the trigger.
Ditto on the  :-+
From the above assembly vid, looks like it'll be a bit more involved than the Tornado/CR10; this may seem a bit daunting for a first build, but if you watch the vid several times BEFORE you start, you should be good to go. Still DEFINITELY a cakewalk compared to assembling a Kossel and getting it aligned/leveled.   |O  Your reward for the extra work will be a much more stable, precise platform than the CR10/Tornado, which should be good to much closer tolerances and inherently less prone to runout.
Congratulations!  :clap:
« Reply #48723 on: February 03, 2020, 01:58:31 pm »
Hope you appreciate her!  :)
Online tggzzz
« Reply #48724 on: February 03, 2020, 01:59:35 pm »
In 2021 there will be extra car insurance, customs duty, and a lot more red tape paperwork. Didn't see that on the side of a bus.
