@bd139, OK seems I was wrong, these winding taps are supposed to go through a grommet on a partition and terminate there. That transformer is actually mounted in a hole in the partition, the likes of which I don't recall seeing before.
Edit:
Looking at the two photos, I'm beginning to think that choc block could be original but poorly terminated, the photo I found would mean that the transformer is exposed at the rear of the scope??? In my photo it looks as if the transformer was bolted to the rear panel externally and the bottom connections have been extended but interestingly, the tappings at the top would appear that those long leads are original.
