Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17499632 times)
Carl_Smith, TERRA Operative and 90 Guests are viewing this topic.
Offline VK5RC
« Reply #47525 on: January 21, 2020, 10:36:48 am »
« Last Edit: January 21, 2020, 10:44:46 am by VK5RC »
« Reply #47526 on: January 21, 2020, 10:49:45 am »
If you're going to have to put up with that wailing I figure its far better with something to watch as well
Offline VK5RC
« Reply #47527 on: January 21, 2020, 11:03:15 am »
The nickname for those are 'smashed pipe bands' as no one is in tune or time.
PS Re Steam train to mallaig, starts with solo piper, at about 35 secs typically 3 other pipers join in, as the drones come up to pressure they are off tune for a few seconds and you can hear the heterdyne, but by 45 seconds you can't hear it any more - just the harmonies and a little syncopation.
« Last Edit: January 21, 2020, 11:09:44 am by VK5RC »
« Reply #47528 on: January 21, 2020, 11:18:05 am »
The real saving grace for our combined Ears is the noise of whatever type doesn't auto start  ;)
« Reply #47529 on: January 21, 2020, 11:25:50 am »
In Germany (and Switzerland) there is something similar. It is called "Guggemusik".
Example:
The following users thanked this post: SilverSolder, Specmaster
Offline tggzzz
« Reply #47530 on: January 21, 2020, 11:31:40 am »
Do you think there is any point in trying to resurrect these 1988 NiCds?
They are from my newly acquired Time Current Calibrator; look at the minimum scale and resolution, but the spec is +-0.2nA etc :)
Yes, it does work fine without the battery, although I had to replace the filter electrolytic and a torched 100ohm resistor in series with the battery.
Offline VK5RC
« Reply #47531 on: January 21, 2020, 11:32:16 am »
No no no! you (Swiss-German) have the top secret drum corps, these guys did this for free drinks!
https://youtu.be/gwmrzgg-IS0
Offline Martin.M
  • in Tek we trust
    • vintage Tek collection
« Reply #47532 on: January 21, 2020, 11:40:07 am »
In the bay they still sale fresh made NiCd.
You need 2x  5 pack of AA = 12v
Offline Zucca
  • EE meid in Itali
« Reply #47533 on: January 21, 2020, 11:55:22 am »
Do not spit on my face, but I would put a 3S Lipo pack with somehow a charger circuit.
Offline tggzzz
« Reply #47534 on: January 21, 2020, 12:14:15 pm »
I'm probably not going to bother replacing the NiCd cells, since it works well on the mains supply and I don't need transportabillity nor am I worried about warmup times.
In the past (for a Tek 1502 TDR which requires the cells before it will even switch on) I've used tagged NiCd cells from https://www.batteriesplus.co.uk/acatalog/1.2V_NiCd_Sub_C_Rechargeable_Tagged_Batteries.html and simply soldered the tags together. But since my local hackspace has now got a battery terminal spot welder, next time I might use that on untagged cells.
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #47535 on: January 21, 2020, 12:38:27 pm »
Got a few of those myself. Better not plug it in untill I removed the battery pack, then ;)
Offline nixiefreqq
« Reply #47536 on: January 21, 2020, 12:57:49 pm »
Nope. I personally still think that they should be chucked on the same fire as kazoos, banjos, vuvuzellas, piano accordions and the 808 cowbell
you left out the jingtinglers, floofloovers, tartookas, whohoopers, gardookas, trumtookas, slooslunkas, blumbloopas, and whowonkas.
There's one thing I hate! All the NOISE! NOISE! NOISE! NOISE!
free range primate
« Reply #47537 on: January 21, 2020, 01:04:08 pm »
You might need them to meet leakage specs (i.e. remove insulation resistance to the mains out of the equation by unplugging it) if you're planning on playing at the arse end of that source's capabilities.
« Reply #47538 on: January 21, 2020, 01:29:11 pm »
Says he by shouting  :-DD :-DD :-DD
Offline Ice-Tea
« Reply #47539 on: January 21, 2020, 01:31:14 pm »
Actually, I bought a few of eBay some time ago. They turned out to be NiMH. When I looked closely at the ad, it was indeed listed as compatible or equivalent or some such. Not sure if there are actual NiCads on eBay still...
Offline grizewald
  • Country: ua
« Reply #47540 on: January 21, 2020, 01:35:13 pm »
Furry NiCd battery packs seem to be a recurring theme with Time equipment!
I managed to find some NiCd packs locally from a radio control shop, so I replaced the pack. Replacing them with NiMH is a big no as the supply is made to trickle charge the pack at the correct rate for NiCd cells.
  Lord of Sealand
« Reply #47541 on: January 21, 2020, 01:41:10 pm »
Gotta disagree with you all that can't stand bagpipes. Done properly I think they sound beautiful.
Here's the NYPD Emerald Society. Every retired NYPD officer is entitled to a single piper at their funeral if requested. I've been to a funeral and while it may seem a little out of place for a retired Hispanic officer it does add beauty and dignity.
And of course if an officer is slain on duty the entire Emerald Society turns out for the funeral. This particular cop was Chinese descent.
Offline WastelandTek
« Reply #47542 on: January 21, 2020, 01:47:37 pm »
Something in my ad/script blocking config doesn't resolve the embedded vids, but that Dragoon Guards cut may well be the finest pipes I have heard
thank you.
I'm new here, but I tend to be pretty gregarious, so if I'm out of my lane please call me out.
« Reply #47543 on: January 21, 2020, 02:15:24 pm »
I've always had a soft spot for march bands with bagpipes and you're right they sound OK when done properly. They also of course IMO need the drums, especially the bag bass drum to balance them otherwise they can get a little scratchy.
I always respect things like this when a colleague in the Police or the Fire Services is struck down, the solidarity and respect shown for them, irrespective of their colour or race is very touching and heart-warming to see.
« Last Edit: January 21, 2020, 02:18:05 pm by Specmaster »
« Reply #47544 on: January 21, 2020, 02:46:20 pm »
And now to cleanse my ears via some music from chilled out suburban Ipswich  :-DD
The following users thanked this post: shakalnokturn
« Reply #47545 on: January 21, 2020, 02:51:15 pm »
Wow, thats some dark music there bd
Offline SilverSolder
« Reply #47546 on: January 21, 2020, 03:06:30 pm »
Some woman really messed with the songwriter's head...
« Reply #47547 on: January 21, 2020, 03:12:41 pm »
Nah - living in Suffolk does that to you.
« Reply #47548 on: January 21, 2020, 03:33:48 pm »
Or, living behind a red door in the basement of an IT company, together with Roy and Maurice. :D
The following users thanked this post: SilverSolder, mnementh
« Reply #47549 on: January 21, 2020, 04:06:04 pm »
There's something about that flat part of England that means that the inhabitants make, and have a fondness for that kind of music. My good mates Alan and Kleo (niece of the Rev. Lionel Fanthorpe - for those of you of a Fortean disposition), who hail from Norwich, used to be in a band of that ilk.
That's my mates Alan and Kleo in the centre from an old band publicity pic taken sometime in the late 80's:
