Typing on the laptop that's already WIN10. The TEA computer which I use just for manuals/schematics I'll re-image from WIN7 to Linux Mint. Media PC is a different story. Best option is to stick with Windows so it will have to go to WIN10. Unfortunately I'm going to have to spend the bucks for a license to upgrade (actually do a total wipe and fresh install). Now why is that? Truth be told I've been running a bootleg WIN7 Ultimate on that machine for years and I had a bootleg program to make MS recognize it as genuine and keep it up to date. But upgrade is a no go.
Cof Cof Try to upgrade to Windows 10 Pro with your current copy Cof Cof Get the Digital Key activation that will stuck to the hardware in the PC Cof Cof Format and reinstall fresh Cof Cof.
N cases that it happen, I have one of my PCs who activated a genuine Windows 10 Pro that was from a Windows 7 Pro bootleg activated VLK.
Although if you need a Windows 10 Home key I can provide you with one for free that I don't use - My ZenBook one, I don't use the OEM one, I have the Windows 10 Pro and Fedora 31 Workstation on it.
Huh, that could be a grab. My local surplus joint has two of the somewhat newer version of that (forget the model #) that uses some sort of totally unobtainium proprietary connectors instead of banana jacks.
If they are 740 A or B's then yep special addon box and lead. I have one of the two for mine and Cubdriver has one of two for his from memory. These two are also higher precision and the 740B comes with Nixie glow
![Cool 8)](https://www.eevblog.com/forum/Smileys/default/cool.gif)
I have done a 3D printed model for the box and at this stage will do a connector swap on mine.
So... I have a line on two 2465BDV scopes locally. I will have a chance to test them both before buying and, from the photos, they look well cared for. I've asked the seller to send me the serial numbers so I can check on the NVRAM, too.
No, I don't need any more oscilloscopes (and in fact, this evening, I started setting aside scopes I am going to sell) but I do need a 400MHz 4 channel scope and I should be able to get a very good deal on one or both of these, do the necessary refurb and end up with a pretty good deal. The BDV has all the options that Tek could cram into the 2465.
So... anyone want the second one, assuming they are both in good working order?
Either one have the counter option? My 2465B doesn't have any options at all.
my hp 6227a was delivered today by ups.
only thing wrong with this acquisition........there was nothing to fix!
sure hope this does not make oculus jealous. (even though he practically stole the previous one i lusted for)
this grumpy old man is a pretty happy camper.
So now you are facing a difficult choice. Which one of the multitude of -hp- power supplies in this form factor to stack it with? 4quadrant? precision? 1channel with more oomph? HV?
Is there even an 'or' in that decision?
no. my power supply craving has been satisfied.
awwwwwwwwww shit.
https://www.ebay.com/itm/HEWLETT-PACKARD-HP-6228A-DUAL-DC-POWER-SUPPLY/183762055164?hash=item2ac9126ffc:g:y-oAAOSwj61cprRH
If you want Windows 10 and you are going to do a fresh install, just go download it from Microsoft's site, use their media creation tool to make a flash drive, and try installing it. It's possible they will let you have it for free. I heard rumors of this repeatedly so I tried it and it worked.
I had an old laptop where the hinge busted due to crappy design, so I got a different laptop, and used the broken one propped up on my desk to watch YouTube and stuff, but then later the hard drive died good. Didn't have a spare drive and didn't want to spend money on one for an old laptop so it sat for like a year until I ended up with a spare drive. Fixed the hinge with a lot of epoxy and superglue, wiped the spare HD that was from another system, installed it blank, and installed Win 10, and it just came up licensed to me.
Not sure why MS is still letting some people have Win10 free, but I'm not going to complain. The only thing I can think is that I had Win 8.1 on that system before it died and had all my systems linked to my Microsoft account, so maybe the system let me have it free because they knew I had the system when the Win10 upgrade was free? Don't know, but again, I'm not going to complain.
Worst case is that it will come up as unactivated and you'll have to decide if you want to install Linux or buy one of those $15 Chinese activation codes.
Yup. Both have the DMM/counter, GPIB, word recognizer and video options.
Anyone has an idea what that would really cost to ship? Forget it. But I also need a new analogue.
Windoze10 will activate based on a serial number in the BIOS; they've actually been doing this with some OEMs since the Win7 daze. I have one USB of Win7 Pro that I used to use on Dells... it would install and activate on pretty much anything Dell made in the last 10 years. Win10 will ALSO run quite happily with no activation; it just won't allow you to personalize the system or get Defender updates. After 14 or 21 days it will revert to the "Not Genuine" nag desktop, which, since you can't personalize, you can't make go away.
Other than that, and the fact that when MS rolls out the next major update it will break all your Windoze Automatic update ability, you CAN run Win10 unlicensed... they do this on purpose as "Trial" mode.
Of course, if you can find a legit non-OEM license from Win7/8/8.1, you can ALSO just use THAT key to activate Win10; then that license will remain YOURS in principle "til the end of time".
*currently running on a legit .edu license from 10 years ago*
Ok, in 10 min I will be married. Just checking here before my TEA career will change forever.
Sorry misspelled with a phone.
Which meter are you marrying, though? Careful of jealousy on the bench!
Congrats!
Congratulations or commiserations. Haven’t decided on which yet
