Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17337984 times)
Nermash, Vince and 47 Guests are viewing this topic.
Offline BravoV
  • +++ ATH1
« Reply #44050 on: December 04, 2019, 01:26:29 am »
YALBOA : Yet Another Low Balled Offer Accepted
Another Simpson 260 on its way. :palm:
Offline 0culus
« Reply #44051 on: December 04, 2019, 01:28:07 am »
This is an HP Free zone except for one dinky power supply that somehow got past security  ;D
You need this to calibrate your 5.5 digit DMM's;
https://www.ebay.com/itm/HP-3455A-Digital-Voltmeter-Vintage-Hewlett-Packard-Digital-Voltmeter-3455A/113998874609?epid=1603927670&hash=item1a8adcc7f1:g:p5IAAOSwXVdd5dRI
Do I need this? No, I have many DMMs.  Do I want this? Yes, because it looks very cool.  So I made a low ball offer on it, since "it worked last time he looked" but apparently he couldn't find a power cord to see if it still lights up.  :-DD
Go for it. I won't out bid you.  :-DD
Damn if the seller didn't accept my offer.    :o   I didn't expect that to happen. Going to cost me more for shipping than buying.
If you do get it and need parts I have one that I’ve already robbed one unobtainium ic from to help out another forum member. No worries robbing more from it. No guarantee though because this particular unit has always been a bit flaky on the digital side.
« Reply #44052 on: December 04, 2019, 01:44:06 am »
Good deal! You MUST post pix when you get it. And if it works you can go na-na at me for not bidding on it.  :-DD Although I have stated all along that I will NOT venture into 6.5 digit and above territory.  :palm:
« Last Edit: December 04, 2019, 01:45:56 am by med6753 »
Offline Brumby
« Reply #44053 on: December 04, 2019, 01:49:43 am »
I  don't know if I've stated a similar attitude, but it is the fear of the voltnut rabbit hole that steers me in that same direction.
BUT - for ten bucks I could easily be swayed!  (I feel pretty safe, though.  There's absolutely negligible chance of such an opportunity in Oz.)
« Reply #44054 on: December 04, 2019, 01:52:11 am »
It was definitely tugging at me so I'm (sorta) glad that someone scooped it up.  :phew:
Offline 0culus
« Reply #44055 on: December 04, 2019, 02:01:41 am »
I got an e-mail this morning from the Bay of Evil.  Apparently someone offered them $40 for it, because it was to inform me that it sold for that amount.
-Pat
That may or may not have been me.  :-DD
LOL - cool - at least one of us snagged it!
-Pat
but......but......but.........i saw it first!
you had better post pictures!
(my feelings are still hurt that they never sent me a counter offer.  but that's ok, 'nuff hp junk round here anyway)
Should be here on the 12th if the shipping notice is accurate.  :-+
« Reply #44056 on: December 04, 2019, 02:03:36 am »
Maybe not for $10 but I will accept the mission to assist you with your goal  >:D
Mmmm thinking some more my Advantest 6871E is not getting any use since I got the 34461A  :-DD
« Last Edit: December 04, 2019, 02:05:21 am by beanflying »
Offline Brumby
« Reply #44057 on: December 04, 2019, 02:10:50 am »
 :scared:
Offline Brumby
« Reply #44058 on: December 04, 2019, 02:22:32 am »
I've only just picked up a 12RU box and one device will take up a quarter of it.  Will be a challenge to fit the gear that will be displaced to make room for this - and the other things I want to have at the ready...
... and you want to aid and abet in a campaign of tetris?!!
But, then, I suppose I could do an expansion of the hob over my screens.  Another cm or two in height would allow several pieces of kit to fit.  Hmmm......
 |O
« Reply #44059 on: December 04, 2019, 02:50:53 am »
...and do those floor joists above your head REALLY need to be 2" x 12"...?  >:D
Offline worsthorse
  • aina varma, usein väärin
« Reply #44060 on: December 04, 2019, 02:56:20 am »
I will post pix. I don't consider it 6.5 digit territory as I will just ignore any digits past the first four or so. And if they bug me by flickering, well, there's always the blue tape solution.   ;D
Offline worsthorse
« Reply #44061 on: December 04, 2019, 02:59:09 am »
Thanks! I took a gander at the service manual this afternoon. It's cheap enough that if its unfixable (at least by me) I won't feel too awful about it.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #44062 on: December 04, 2019, 03:15:15 am »
All this talk of fire stick soldering irons makes me wonder:
How many of us learned to not catch a falling soldering iron by catching a falling soldering iron.  Once...
(Raises Hand)
I learned not to catch marbles that broke off of punties that way...
-Pat
what???
When making glass marbles, you do what's called a 'cold fuse' to a glass rod that's called a 'punty'.  The idea is to make a purposely weak joint so that the rod used to hold the marble may easily be broken free without making too much of a mess of the surface where it was located.  It usually must be transferred at least twice to get the whole surface formed.  Sometimes, the joint is a bit TOO weak, and the marble breaks off while you're working it.  Being spherical, they tend to land on the bench and then try to roll off.  Natural instinct is to try to catch the marble you've been diligently working on as it falls.  This is NOT a prudent thing to do, as a piece of glass that moments before was bathed in an oxy-propane flame is, oh, what's the term I'm looking for...  ...FUCKING HOT!!  Unless you are especially slow witted, you will usually only do this once.  Subsequently, instinct will still make you try to grab, but a split second later reason will assert itself and you will instead jump out of the way.
In the following video, if you skip to 8:50, 10:50 and 12:35 you can see him transferring the marble and just how easy the joint is to break:
(And this reminds me that I need to get my burner set up some one of these years and get back to doing this stuff!  It's been far too long.)
-Pat
Offline Cubdriver
  • Nixie addict
« Reply #44063 on: December 04, 2019, 03:17:08 am »
Nah, they can be 2x10s if you put 'em on 8" centers...
-Pat
« Reply #44064 on: December 04, 2019, 04:08:45 am »
« Last Edit: December 04, 2019, 04:11:58 am by mnementh »
« Reply #44065 on: December 04, 2019, 04:37:44 am »
-Pat
what???
-Pat
Yeah... when I was sorting my mother's stuff for the move, I found several handmade glass "ornament beads" from approx 25-75mm that she had bought from another artisan met at one of her shows. They were essentially large marbles of various artistic content with a little flat loop of glass at the top; you could see where the fellow had heated the punty and formed the loop with pliers. She did several orders by mail over the years with him.
I did some slumped glass bits for her using a rosebud torch and working on a piece of 1" thick plate steel; had to heat the steel before I started and keep it heated as I worked so I could lay the softened sheet & bits together on the plate so it would cool slowly enough to not shatter. Real "primitive work", but it gave me a real appreciation for the artisans I remembered seeing at work at Corning Glass as a kid. And for the value of a proper electric kiln.  ;)
*primitive*
« Last Edit: December 04, 2019, 04:47:16 am by mnementh »
« Reply #44066 on: December 04, 2019, 04:44:04 am »
-Pat
Oooooh! That's room for another layer of manuals on top of the stack!!! *steals chainsaw from the dog*
Okay... maybe I've gone a little too far off the "meta" deep end this time...  :o
Offline kj7e
  • Damon Stewart
« Reply #44067 on: December 04, 2019, 05:55:39 am »
The 3455A is indeed 6.5 digit realm, the service manual with it is worth the price of admission alone.  It was built during an age when price was no expense, its built to the limit of the state of art of the time, not a price point dictated by bean counters.  It will be stable to the last digit if in good working order. Hope its in good condition and working order when you get it.
« Last Edit: December 04, 2019, 05:58:51 am by kj7e »
The following users thanked this post: worsthorse
Offline capt bullshot
« Reply #44068 on: December 04, 2019, 07:24:55 am »
(Raises Hand)
Even worse, my foot was caught by the power cord and then the iron was "caught" by my face just across the mouth. Nice burn mark on my lips was the result ...
Same kind of experience as connecting your shiny new first scope to a mains powered circuit (scope and me survived, circuit didn't).
« Reply #44069 on: December 04, 2019, 07:31:18 am »
(Raises Hand)
Or entering "sudo shutdown -h now" into the wrong terminal. Went home and shortly after got a phone call ...
« Reply #44070 on: December 04, 2019, 07:41:29 am »
LMAO have done that before. Cost me a round trip from Nottingham to Manchester because I was too cheap to put an ILO card in the machine  :-- :-DD
« Reply #44071 on: December 04, 2019, 07:42:07 am »
:scared:
To soon for savings @Brumby ? >:D eBay auction: #163960440176 might suit another local in the market.
« Last Edit: December 04, 2019, 07:46:18 am by beanflying »
Offline Zucca
  • EE meid in Itali
« Reply #44073 on: December 04, 2019, 11:40:37 am »
Happy 2,000,000 + views TEA.  :-+
The following users thanked this post: bitseeker, mnementh
Offline Brumby
« Reply #44074 on: December 04, 2019, 11:52:51 am »
A little outside the budget at the moment - and the 2,200km round trip for "local pickup" isn't tickling my fancy to say the least.
But it does look nice.  :)
