That's it! No fancy shit, no variable temp, no flame throwers.![]()
And I hope the wrapped up cables annoy the shit out of you so perhaps you'll leave me alone.![]()
How can I remove those images from my mind now that I've been exposed?
well my $30 offer on that $45 hp 6227b just expired with no response from the seller.
thought he might at least counter offer at 35 or 40.
was my offer so low as to be offensive? did not mean for that to happen.....thought it was just part of the bargaining process.
No I think it was a fair offer. Not sure why some of them add the option to receive offer and just don't answer ?That was a fixed price offer, not an auction, right?
sure. it is still out there.
https://www.ebay.com/itm/HP-6227B-DUAL-DC-POWER-SUPPLY/153732549763?hash=item23cb2c8c83:g:SUYAAOSwIbVd1bXJ
Damn you stop with the temptation - that looks to be in decent physical shape...
-Pat
offer him $30.01 just to see what happens.
Geez....you make it sound like I turned down the opportunity of a life time."Solder school" was something like a 2 hour class during work time.
And this was in the 1970's before SMT. It was all pin thru hole. What the hell were they gonna teach me that I didn't already know? Not much.
I dunno... maybe why a temp-controlled iron is important...? So you'd put away the firestarter and get a proper station... some time before somebody gave you one as a retirement gift in your old age...?
*frantically looking about for my athletic cup or some similar form of armor*
Did anyone ever tell you that you can be a total pain in the ass at times?I'll bet this isn't the first time...maybe the 9999th time.
There were no temp-controlled irons used in that assembly/test area at that time. We had.....
The Ungar Imperial
The Hexacon Mini![]()
-Pat
LOL - that might be pushing it. You just prompted me to try $35.
We'll see what comes of it.
-Pat
The Ungar Imperial
Pshaw. Get a real soldering iron!![]()
Perfect for 0402 SMD components and 0.5mm pitch chips!
-Pat
is that you who bid on the lightweight freq standard down in charm city?
I'm assuming that you mean that double rack GenRad system in Baltimore that was posted earlier, and if so, no, that's not me. If it were within three hours or so, rather than 6-8 hours driving each way I would certainly have asked about pickup and if that was acceptable to the seller I'd have thrown my hat in the ring. Alas it's a bit too far for my inclinations...
-Pat
But how can you really be sure @med ?Time to get a calibrated source or meter ....
Spent part of the evening playing with now sharp blades. Brought a set of very poorly sharpened Marples chisels and took to them with stone and then several grades of wet and dry. Still some more to do but the hollows in the faces and the horrid rounding and chips on the tips are now gone not to mention one of them had a small bevel on the back face.
Is that sandpaper on glass or a huge stone?
Being hollow ground is not a bad thing, tip to heel needs to be ~25o and the honed edge @ 30o. That way getting a nice edge back takes less effort as you're taking off less material.
Still got my honing guide exactly like yours from nearly 45 years back.Rarely use it now, instead just freehand
oilwater stone stuff now.
Ha and I also need to find a solution for the front panel
Take it slow and you can glue it all back together. Try a test piece and see it if will weld with plastic welding cement like Plastruct.
-Pat
well the listing now says:
Local pickup or buyer to arrange freight
Museum piece / collectors item. Probably one of the last in existence.
General Radio Frequency Standard & Frequency Measuring Equipment.
(2) relay racks. 1940 Vintage.
Rack 1 Includes:
693B Synchronometer - Synchronous motor clock that runs off the freq standard
(4) 692B Multivibrators
698A Duplex Multivibrator
690C Piezo Electric Oscillator
691C Temperature Controller
676A Quartz Bar
694C Control Unit
696C Power Supply
Rack 2 Includes:
699A Comparison Oscilloscope - displays '3D' Lissajous patterns
616D Heterodyne Frequency Meter
617C Interpolation Oscillator
619E Heterodyne Detector
612C Coupling Panel
619P1 Coil Drawer
614C Selective Amplifier
Listed as 'For parts, not working' because operating condition is unknown.
All units are in good physical condition, except that clock glass is cracked on Synchronometer.
Replacement domed clock glass available on ebay for less than $20.
All units worked when last powered up around 1980, except power supply has been bypassed with a Lambda unit in the rear of rack 1.
Must move soon.
Looking for a good home. I would hate to scrap.
I bought this in the early 1970's for $25
I'll start the auction for the same $25
Would donate to an interested museum - contact me
wwnd?
I'll just file this one under "Things that shouldn't exist."
The Ungar ImperialThe Hexacon Mini
No doubt Sean will be along in a minute to tell us about his first 'soldering iron':![]()
You call that a soldering iron, this is a soldering iron!![]()
I'm starting to like how ebay is handling things. Found a cheap Lecroy DDA-260 on ebay last week. The DDA-260 is similar to the WavePro 960 but with 2Ghz bandwidth, 16GS/s sampling, 64Mpts memory. Was supposed to be non functional but in good physical shape.
Received the package couple days ago. Front panel was smashed during shipping (pretty typical for old lecroy scope)Contacted the seller, he told me to contact ebay since he shipped via global shipping program. Then contacted ebay, told me to open a case. I explain my case and add bunch of pictures. Then today, the seller asked ebay to intervene in the case. So ebay just refunded me and I got to keep the scope
Look like since it went through GSP, ebay is going to cover it.
Now for the "non functional" part, I did some tests, and it look like the only problems are the rotary encoder and the screen backlight (uneven lighting). I think I found myself a nice 2Ghz scopeHa and I also need to find a solution for the front panel
I'll just file this one under "Things that shouldn't exist."Yeah, I never put a switch in my suicide cords. No need for one. And if for some reason I DID put in a switch, it would be closer to the business end than to the plug...
-Pat
A home made version of what's called a "cheater cord". What's the big deal??![]()
That hollow was as per the photo proud outer tips and hollow between. I suspect they were sharpened on a bench grinder with untrue stones.
I don't get enough practice to freehand sharpen so the guide keeps it all nice. It is only a cheapy evilbay one that I reground to make it true. Just going with 25 degrees as a primary as most of what I do or are likely to do is softwood. Even with a secondary at some stage you then need to regrind the face back and start again.
