Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 16616636 times)
Ismo, flash2b, Vince, themadhippy, wkb, Robert763 and 30 Guests are viewing this topic.
Offline Neomys Sapiens
« Reply #43850 on: December 02, 2019, 02:05:27 am »
I guess I have some kind of obsession with high resistance meter and electrometer. Found this little puppy on ebay, advertised as broken for parts. Since it was broken I tried negotiating a bit. Worked pretty well and ended up paying less than the Genrad 1644a.
Now I need to make / find the test leads and do calibration and adjustment.
Yes, with the aquisition of the Philips LCR the Hi-Ohm and Low-Ohm requirement moved up a bit in priority. Except that neither tubes nor manual bridges will be accepted. The only current offer that I have is for a HP Milliohm-Meter, but the condition is rather dubious. Still looking.
Digital high resistance meters are out of my league. I'm probably too cheap  :-DD.
It's completely analog but the resolution of the genrad 1644a is interesting. It will probably die as soon as one of the tube give up though. Not sure if it's still possible to find those.
Did I say digital? Did I somehow evoke the concept of 'digital' by talking of numbers on a display?
The exclusion of manual bridges referred to anything working on a compensation and zero indicator principle. That HP is solid state and I would be fine with one. It aimed at the GR.
Offline Kosmic
« Reply #43851 on: December 02, 2019, 02:23:49 am »
Ok I misunderstood. Thought you were not interested in everything that has a analog display.
Offline kj7e
  • Damon Stewart
« Reply #43852 on: December 02, 2019, 02:27:29 am »
jeebus!
you have sent me down the path of evil once again.  (you know who you are!)
ya' gave me power supply fever, and the result is an offer on an hp 6227b.  so my sorry ass is dual cursed if accepted.  my only hope is that the guy turns me down.
AMF!  (adios......my friends)
I absolutely love my 6227B, extremely clean DC supply.  However, I ended up completely recap'ing mine and changing out the the high power bleeder resistors.
https://www.eevblog.com/forum/repair/hp-6227b-dual-dc-power-supply-ripple-in-master-channel/msg2296266/#msg2296266
883054-0
« Last Edit: December 02, 2019, 02:34:07 am by kj7e »
The following users thanked this post: nixiefreqq
Offline nixiefreqq
« Reply #43853 on: December 02, 2019, 02:33:43 am »
@freqq: did you really have nothing but the midget HP as a power supply? Sorry, but I think you are pulling our legs, aren't you?
ok.  in the spirit of full disclosure i will embarrass myself.
in addition to the tiny hp there is a box of assorted junk raped out of old pc's, and one ancient dinosaur (new jersey electronics?  who the hell were they?)
that is the sum total of my power supply resources.  shameful isn't it?
it may get me shunned,  but it feels good to be out of the closet.
free range primate
Offline kj7e
  • Damon Stewart
« Reply #43854 on: December 02, 2019, 02:40:08 am »
Added some rack space for the older mostly matching HP vintage gear, work in progress...
The following users thanked this post: xrunner, edavid, med6753, Neomys Sapiens, bd139, Kosmic, 0culus
« Reply #43855 on: December 02, 2019, 02:47:16 am »
We know the actual truth you couldn't find one with Nixies you liked  ;) Of all the test gear PS's seemed to just jump from Analog to LED to VFD's and skipped Nixies.  :-//
The following users thanked this post: mnementh, Neomys Sapiens, nixiefreqq
« Reply #43856 on: December 02, 2019, 02:49:45 am »
I have looked at that sort of shelving before but haven't brought any yet. How is it for side to side wobble when loaded?
And make it some nice shoes already  >:D
Offline kj7e
  • Damon Stewart
« Reply #43857 on: December 02, 2019, 02:58:31 am »
Its very sold.  Its still a work in progress.
Older daughter is moving back home for a bit, so my wife is loosing her home office up stairs and will be moving her office downstairs with mine.  So had to consolidate to free up some space for her.
« Reply #43858 on: December 02, 2019, 03:10:21 am »
No need to feel shunned. Other than the previously mentioned HP my power supply collection consists of a home brew 15V/2A linear variable, a home brew 15V/10A linear variable, and a home brew linear multi output supply.    :-//
Offline Kosmic
« Reply #43859 on: December 02, 2019, 03:12:34 am »
And that NJE one look like a proper linear power supply  :-+
The following users thanked this post: Neomys Sapiens, nixiefreqq
« Reply #43860 on: December 02, 2019, 03:36:39 am »
Quote from: Neomys Sapiens
ok.  in the spirit of full disclosure i will embarrass myself. in addition to the tiny hp there is a box of assorted junk raped out of old pc's, and one ancient dinosaur (new jersey electronics?  who the hell were they?) that is the sum total of my power supply resources. shameful isn't it? it may get me shunned, but it feels good to be out of the closet.
THAT is my whole fukkin' bench.  :palm:
Some people don't know when they've got it good...  :P
Offline BravoV
  • +++ ATH1
« Reply #43861 on: December 02, 2019, 03:37:20 am »
Moving coil envy ...  :'(
Great collection.  :clap:
Offline Doom-the-Squirrel
« Reply #43862 on: December 02, 2019, 05:06:29 am »
Some more stuff of mine.
Not technically test equipment, unless you count the two temperature probes and the non contact thermometer.
883096-0
Offline ZhuraYuk
  • Country: ua
« Reply #43863 on: December 02, 2019, 06:38:17 am »
Everything has started from 20$ LCR meter, and then I got the idea "how I can be sure that it is showing correct readings?" or how it is exactly measuring stuff. Then I got doubted in other equipment so I started checking each piece of gear I had, even the cables and adapters to know their characteristics.
More stuff in the way, so I can perform more measurements over the measurements. This is really satisfying to do.
I keep my mouth shut on the light-blue abomination, as no one should suffer that much.
But nice Generator and DMM above.
We can see clearly that the west-east relations have mostly equalized.
But for LCR you are still stuck with the original?
Anyway, welcome to the most peculiar thread on a already peculiar forum..
I have DER EE DE-5000 but that one has black colour and is kinda stands out from overall colur palette, so I did not put it there.
Also the abomination had fan replacement procedure so it is much friendly now.
Online Brumby
« Reply #43864 on: December 02, 2019, 07:21:00 am »
Just found myself a home for my HP 8656B - with room for some friends.   ;D
eBay auction: #323991523569
« Last Edit: December 02, 2019, 07:23:06 am by Brumby »
Offline VK5RC
« Reply #43865 on: December 02, 2019, 08:43:55 am »
Quote 'THAT is my whole fukkin' bench'
It's not what you have, its what you do with it!
Seriously about the only two things missing for a full bench, really are a freq gen and a scope.
The stuff I made with the crappiest of an  unregulated soldering iron!
Offline Sam Spastic
« Reply #43866 on: December 02, 2019, 08:49:38 am »
I went with the Xtreme Garage shelving at Menards.  Almost "industrial" but probably would not stop a UFO but would slow it down.
PS. Thats factory slang for Unidentified Forking Object.
An old fart.
Offline McBryce
« Reply #43867 on: December 02, 2019, 08:58:59 am »
car battery charging  ::)
I have limited the Rohde+Schwarz to 20A so it will not boil the test cables.
(Attachment Link)
Just a tip Martin - Never put the battery on top of the supply when charging. If for any reason the battery starts leaking, the acid will be flowing into your supply.
McBryce.
Offline nixiefreqq
« Reply #43868 on: December 02, 2019, 12:01:58 pm »
i call horseshit.
we have seen the supplies you have in storage.
they weigh more than the freqq did in high school, and there are places in the world where they could power an entire village.
(the pipe wrench still makes me smile)
free range primate
« Reply #43869 on: December 02, 2019, 12:13:27 pm »
Thats the whole point, its in storage awaiting delivery to Canada  >:D
Online Brumby
« Reply #43870 on: December 02, 2019, 12:31:16 pm »
Exactly.  That makes the frustration doubly irritating.
« Reply #43871 on: December 02, 2019, 01:08:31 pm »
Tautech, what's the status of this? It's been almost a month now. Are users going to have the ability to tweak the cal or not?  :-/O :-//  The source voltage is 9.99691V and as you can see the 40 year old fluke (in fact, both of the 8800A's) shows how it's done.  :-DMM
« Reply #43872 on: December 02, 2019, 01:19:03 pm »
That's probably still in cal based on the 1Y 0.015+ 0.004 perf.
Also why you buy an HP 34401A instead of a Siglent.... 1Y = 0.0035 + 0.0005  :popcorn:
Then again are you sure the voltage source hasn't aged the same direction as the Fluke?  :-DD
« Reply #43873 on: December 02, 2019, 01:24:11 pm »
Oh I agree it's in spec but I'm a hard ass. It should be better.
Nope, the source HASN'T aged in the same direction as the Fluke. I have the other AD584-M as a back up and unless that one has ALSO aged in the same direction (Unlikely) what you see there is a fail on the Siglent's part.  ::)
« Reply #43874 on: December 02, 2019, 01:36:35 pm »
This morning's winter scene. The total snow accumulation so far has been less than predicted. Overnight it keep changing back and forth between sleet and snow. So the snow has a crust on it. But today's prediction into tomorrow morning is all snow. So we'll have to see tomorrow what it adds up to.
As you can see the road and parking areas have been plowed. Compare that to what I saw last week in Colorado. They do an absolutely terrible job out there at snow removal. Which is very surprising but I saw it for myself. Luckily almost everyone out there has 4WD or they would never get around.
