Hi again!
All the cheese/bacon/egg/food discussion made it a lot easier to follow the thread the last days...
![Evil >:D](https://www.eevblog.com/forum/Smileys/default/evil.gif)
I'm still working to get my bench pimped with a nice rack for all my boat anchors.
But before I could use my cellar room/work shop for metal works (drilling and countersinking mainly for this) I improved it with 2x 4000K, 2400 ANSI Lumen LED lights instead of one 60W light bulb ("Funzel").
I now have something like light daylight in that room that used to be a dimly lit cave.
I also installed two electrical outlets on the wall behind my work bench where my drill stand is located. Before, the only outlet was on the other side of the shop right at the door -and I always had to use an extension cable.
Next up is building a fixture with quick releases for drilling 30mmx 30mm 90° extruded aluminium angle profiles.
I have to drill/countersink two holes into every single one and I got 60 to drill so the quick releases to clamp them will be worth the effort, I hope.
