Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17492895 times)
enut11, flash2b, abeyer, smaultre and 113 Guests are viewing this topic.
Offline Martin.M
  • in Tek we trust
    • vintage Tek collection
« Reply #42400 on: November 08, 2019, 01:44:58 pm »
Triangels and rectangles looks OK
« Reply #42401 on: November 08, 2019, 01:46:03 pm »
There might be a distortion adjustment for the sine wave.
Offline Martin.M
  • in Tek we trust
« Reply #42402 on: November 08, 2019, 01:54:12 pm »
I will check the power rails for peaks + pokes, here are more scopes then the apparatus have transistors  8)
Offline Zucca
  • EE meid in Itali
« Reply #42403 on: November 08, 2019, 01:59:00 pm »
Martin if you can't fix it nobody can.
Offline Kosmic
« Reply #42404 on: November 08, 2019, 02:12:56 pm »
My inner VoltNut is saying yes, but my wallet is saying where's the make offer button  :-DD
https://www.ebay.com/itm/254412212863
Better not touch that thing. Could easilly cost you another 2K$ to fix the unit. 3458a parts are super expensive.  :-\
The following users thanked this post: Zucca, salvagedcircuitry
« Reply #42405 on: November 08, 2019, 02:15:07 pm »
My Fluke 1953A arrived, in the usual bomb-proof packaging I've come to expect from this seller. Even having sat for hours in a near-biblical downpour, the TE was dry and undamaged.
Which is not to say there aren't any issues however, the rotary switches clearly need a lot of cleaning, and there's so much instability on the readings I'll have to poke around a bit to figure out what's going wrong.
1MHz square wave:
Fluke says:
and
and
also
and
The fact I can't find my BNC-BNC lead is not helping either   |O
Even considered chopping the ends off a TV aerial lead and soldering BNCs onto it, but decided against it in the end...
At least it comes in the med-approved colour scheme   :-DD
Meanwhile in Canada...
« Reply #42406 on: November 08, 2019, 03:09:24 pm »
   I think they were "working some shit out" after getting laid off when LucasFilms closed up shop after ROTJ...  :-DD
 >:D
:-DD I think you're onto something there. Local surplus joint has a stack of thermometer/thermocouple controllers in that some case style. Assume they are largely worthless without the sensors.
No doubt being offered for sale by this guy... :-DD
med... is that you...?  ;)
« Last Edit: November 08, 2019, 03:13:27 pm by mnementh »
Offline 0culus
« Reply #42407 on: November 08, 2019, 03:13:22 pm »
I won't say there isn't a resemblance between them.  >:D
Offline worsthorse
  • aina varma, usein väärin
« Reply #42408 on: November 08, 2019, 03:13:44 pm »
Hey @med I found another meter you could stack on your ugly duckling Fluke. Even painting it blue wouldn't help   :-DD eBay auction: #401819975598
All the nay sayers.  :P I think it's cool. :-+  It's in the same case design as my 7260A Frequency Counter.
And yes.....I would paint it blue.  :-DD
That's the standard issue look from the  "every box must look like a short distance transporter from star trek" industrial design era.   ;D
The following users thanked this post: Martin.M
Offline worsthorse
« Reply #42409 on: November 08, 2019, 03:15:58 pm »
Back to TEA, why the previous owner is always a moron?
(Attachment Link)
My PITA Points:
1) the two elco caps on the top are not deformed but smaller in diameter than what they should be.
2) the big ass blue (dedicated to med) elco cap is not stripped down with a zip tie to the board
3) the relocation of the T220 is nice for thermal but I do not like the execution:
 a) no heat shrink on the T220 legs
 b) flux is like saturday night vomit out of the local bar
it's a legendary 7.5 DMM, you should work with gloves on it.
It's not a cow to milk out, you moron. I hate you.
Temped to put the T220 where the R&D decided to place it.
Why does my name always get dragged into a situation?  :o :-DD
hmm.... maybe it's your avatar? or that post you defaced with blue scrawls? :-DD
Offline FransW
« Reply #42410 on: November 08, 2019, 03:27:11 pm »
Amazing what just turned up before the weekend.
Star-Tek, aliens and distorted sinuses
« Last Edit: November 08, 2019, 03:30:05 pm by FransW »
PE1CCN, Systems Engineering, HP, Philips, TEK, BRYMAN, Fluke, Keithley
Offline bsfeechannel
« Reply #42411 on: November 08, 2019, 03:29:08 pm »
The satin bowerbird be like "Bitch, please!".
« Reply #42412 on: November 08, 2019, 03:36:55 pm »
Potentially ROM replacement and re calibration needed  :o Lots of possible downside without checking the error numbers.
Potentially two work months to get it working again and $2000 more in parts/board to invest.
Oh no, it is drifting after 24h test... what I do now?
Finally after a lot of cussing it will work but the cal of that beast costs again Kdollars so you want to jump out the next window you find.
Absolutely. Once you get up into that kind of money there's no point buying a pig in a poke; it's penny-wise & pound foolish. If you're willing to go thousands of dollars, TEQ has them Refurb with warranty for "only" $2500 more pretty much every day.
« Reply #42413 on: November 08, 2019, 04:31:37 pm »
(Attachment Link)
My PITA Points:
I don't see it being any improvement whatsoever; in fact, relocating there looks like it places U629 right next to an edge, with nut and screw protruding to hang up on everything. Thermal obviously is a non-issue here; the original location is a threaded boss swaged into the same exact piece of aluminum deckplate. The only arguable reason for relocating thusly is if threads in the boss were damaged and one was too lazy/cheap/ignorant to hunt up a tap & fix them. Given the barely tolerable execution of the "mod", I'd go with  lazy/cheap/ignorant; probably all in some measure.
  :palm:
Ummm... okay. There's none on the OEM deployment either. I often mount LM7Xxx with the legs nipped to approx 2mm long and no heat-shrink. I know you're not supposed to due to "thermal shock"; but if you solder quick it doesn't harm the reg (over 3 decades using this method and zero fails I can reasonably attribute to it) and makes a nice tidy install with easy maintenance. A real LM7Xxx from a reputable manufacturer is a wonder of abuse-tolerance; witness my recent adventure with one dumping approx 25V through a 10Ω resistor. :o
Damn Skippy. Unfuckerizing TE fucked by others is what we do for fun here. :-+
« Last Edit: November 08, 2019, 05:41:01 pm by mnementh »
Offline Martin.M
  • in Tek we trust
« Reply #42414 on: November 08, 2019, 04:33:34 pm »
stop  :palm: that do not have the digital data output option to use it with the funny little thermo printer
Offline Kosmic
« Reply #42415 on: November 08, 2019, 04:35:39 pm »
I would do that yes  :)
Offline Martin.M
  • in Tek we trust
« Reply #42416 on: November 08, 2019, 05:01:21 pm »
 :popcorn:
The following users thanked this post: Cubdriver, Kosmic
Offline Martin.M
  • in Tek we trust
« Reply #42417 on: November 08, 2019, 05:05:19 pm »
I will make adaptor sockets to give him better Opamps.
There are µA741 (in 14 pin DIP, that sucks! )
With some NE5534 or BB chips that it will be better..
« Last Edit: November 08, 2019, 05:20:45 pm by Martin.M »
Offline Zucca
  • EE meid in Itali
« Reply #42418 on: November 08, 2019, 05:28:02 pm »
F§%& you moron!
The following users thanked this post: mnementh, beanflying, AVGresponding
Offline Zucca
  • EE meid in Itali
« Reply #42419 on: November 08, 2019, 05:30:18 pm »
I need some of your love right now, please share.
« Reply #42420 on: November 08, 2019, 05:32:56 pm »
5000 Posts... Damn. Time for a Change.
Candidates are:
Choose wisely; mnem has a strange sense of humor and may make you regret it. ;)
muahahaha!!!
« Last Edit: November 08, 2019, 05:35:59 pm by mnementh »
Offline Martin.M
  • in Tek we trust
« Reply #42421 on: November 08, 2019, 05:47:24 pm »
it must not be allone in the cold ... dark ... working room, I found a little brother  :-+
Offline Zucca
  • EE meid in Itali
« Reply #42422 on: November 08, 2019, 05:52:50 pm »
Nice Martin you should open a museum.
mnem DragonMohito-Avatar.png all the way... full steam ahead.
Offline URI
« Reply #42423 on: November 08, 2019, 06:12:22 pm »
UPS-rant..
I took a day off for receiving the two packets with parts for my TE rack.
UPS announced delivery between 8am and 6pm.
No option of early or late delivery. Had to wait the whole day and I waited.
No UPS. No delivery.   :rant:
At 6:10pm UPS notes "delayed delivery, next delivery attempt on monday, november 11th!  :wtf:
Had to call the (tall free? -no!  |O ) customer service line to have it delivered to a UPS service point where I can fetch it and don't have to wait for it all day long.
UPS sucks.  :rant:
No TE rack this weekend.   >:(
« Reply #42424 on: November 08, 2019, 06:18:06 pm »
Karma is balanced somewhere. UPS were good to me today. They phoned me up first thing apologising that they were going to be late for parcel collection. Then turned up on time!  :-DD
