Hamfest yesterday. Got a roll of new coax, Messi & Paoloni Ultraflex 10,3mm. (Like LMR400 or RG213, dimension-wise) and found some nice NOS binding posts. Also, some enterprising person has gotten a plastics manufacturing company in southern Sweden to do UNEF 5/8"-24TPI plugs, that fit on N connectors and, if you are so unlucky, shielded banana plugs. Fitted to my field-day cables with captive cords so as to not be lost in grass.
Binding posts have already been put to use, building my own resistance standard. The zinc box is the one. The other, plastic one, is a 2x1KΩ voltage divider with chinesium posts that is required for checking the 428B. I'm still waiting for the actual resistor (Vishay 0,005% 1KΩ) for the "fine box", so just threw a 100Ω 1% (but it is more like 0,2% according to most of my meters) in it to check the setup.
