Last weeks hoarding on the in-country auction site resulted in a couple of used connectors. Rosenberger solder/clamp TNC for RG213. Now, in classic rabbit hole fashion, all I need is a radio (I'm thinking of a Niros/Ericsson UHF) to plug them in and an open-jaw 16mm torque wrench that will do 4Nm to properly tighten the clamp screw. The tooling rabbit hole is as tantalizing as the TE one. Believe me. For I have gone there.
I've already desoldered them. One needs to loosen all of the clamping, then open the little manhole, heat the joint for the centre conductor, and carefully wiggle the cable stub out. Then clean out the excess solder.
All the silicone seals are somewhat squeezed to bits, so am thinking about getting a bag of suitable neoprene O-rings instead.
