Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 18103887 times)
Robert763, mweymarn and 102 Guests are viewing this topic.
Offline Martin.M
  • in Tek we trust
    • vintage Tek collection
« Reply #40900 on: October 08, 2019, 06:06:32 pm »
GM300 ..  :)  (warm)
The following users thanked this post: xrunner, Cubdriver, med6753, bd139, Kosmic
« Reply #40901 on: October 08, 2019, 06:07:27 pm »
The 10MHz Reference project. All the mains wiring is done and tested. The transformer putting out a healthy 19VAC. The VR board still needs to be built up and installed. Getting real crowded in there. The VR will go to the right of the reference module.
More to come....
The following users thanked this post: Martin.M, xrunner, bd139, Kosmic
Offline Martin.M
  • in Tek we trust
« Reply #40902 on: October 08, 2019, 06:27:13 pm »
the TEA Picknick Set (cased)
The following users thanked this post: Mr. Scram, Neomys Sapiens, bd139
Offline Martin.M
  • in Tek we trust
« Reply #40903 on: October 08, 2019, 06:43:06 pm »
Rohde&Schwarz, the HFH  :box:
it`s a easy to handle portable ( around 90 pounds) full glowing field strenght meter, the large instruments is calibrated in dB/0,1µV.
HFH works from 100kHz up to 30MHz, it have a BFO also, and Atten.
The case for the antennas have 4 feets includet to use it as table for the instrument. It use a set of 3 Loops, and a external active vertical antenna (one tube in the socket)
A battery of 90Ah is good for a nice day in the garden  :popcorn:
The following users thanked this post: xrunner, Kosmic
« Reply #40904 on: October 08, 2019, 06:48:02 pm »
Yeah, but it’s still one of the cheapest available with a 300mm print area on any axis. I know THAT would appeal to YOU, even if it is a PITA from hell on crack to get printing right.  :-DD
[EDIT] That fact also makes the idea of gifting it to you very appealing to me.  >:D
Did you just call me a cheap skate?  :o :-DD
Not A cheapskate. THE cheapskate. The one and original.  :-DD
What you SHOULD be asking is WHICH of the above facts "also makes the idea of gifting it to you very appealing to me"... >:D
Online tggzzz
« Reply #40905 on: October 08, 2019, 06:49:19 pm »
When I cobbled together my 10MHz source based on an HP10811 OCXO, the datasheet noted that jitter can be introduced by noise on the PSU lines. The datasheet showed a regulated PSU based on a 723. Win Hill notes in TAoE (and elsewhere) that the 723 has a lower noise than many other regulators.
Since I had some 723s, using one was a no-brainer, with a capacitance multiplier ahead of it to reduce any 50Hz ripple.
It may well be that HP recommended the 723 because not much else was available at the time.
« Reply #40906 on: October 08, 2019, 07:03:12 pm »
I R confused.  :-// What did I do to gain that impression?  :-// :-//
« Reply #40907 on: October 08, 2019, 07:05:08 pm »
After I get it all together and up and running I'm going to monitor voltage, ripple, and any potential oscillation.
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #40908 on: October 08, 2019, 07:20:34 pm »
Offline URI
« Reply #40909 on: October 08, 2019, 07:24:02 pm »
I just refuse to fix stuff for friends now. Problem comes is when you do a hardware fix and they go and blow up their USB port instantly or crap on the software then it's clearly my fault, not their own stupid fault the second time as well. They get a little lecture on the difference between correlation and causality and told to fuck off. This is when you discover the difference between friends and people who just want to know you because you're useful.
Edit: also the usual requests:
1. Can you hack this person's facebook for me. You're a hacker aren't you?
2. I bought this piece of shit in PC World. Can you spend 5 hours of your life fixing it for free when it's not possible to make it not suck?
3. Fancy dinner at our place next week? Bring a screwdriver.
Ugh
The last request I get from my parents regularly... I'll usually take my toolbox with me then.   :-DD
It's the only exception to your rule you described above.   ;)
« Reply #40910 on: October 08, 2019, 08:36:31 pm »
You’ve made comments before about 3DP being too costly a rabbit-hole. But mostly, just because it’s funny and I’m in desperate need of a laugh.  ;)
And sleep. About 3 days uninterrupted ought to do me...
« Reply #40911 on: October 08, 2019, 08:47:53 pm »
I hate spiders.  :scared: :scared: :-DD
Dr. Who can help.
 ;D
Offline URI
« Reply #40912 on: October 08, 2019, 10:01:32 pm »
« Reply #40913 on: October 08, 2019, 10:07:19 pm »
Quote from: don.r
I get that too now but its mostly elderly neighbours wanting me to set up their iPad to their home WiFi. My reward is happy smiles and home baking.  ;D
I work for pie. Preferably cherry.  ;D
i am a sucker for banana nut bread and i have worked for it.
Ditto. On both counts. I have done jobs for a fresh-baked cherry pie or loaf of fresh banana-nut bread I wouldn’t do for money. :-DD
Good thing none of you know how I feel about honey crisp apple pie... :scared:
Hmm, date and walnut bread is also worth working for  :-+
« Reply #40914 on: October 08, 2019, 10:16:24 pm »
I’d rather buy it myself and choose my customers  :-DD
Always look a gift horse in the mouth!
« Reply #40915 on: October 08, 2019, 10:20:58 pm »
TE rescue time again!
Anyone?   >:D   :-DD
https://www.ebay.com/itm/RARE-very-large-lot-vintage-electronic-lab-testing-Tektronix-Hewlett-Packard/174057289993?hash=item28869f7909:g:dngAAOSwKENdVLjC
Disclaimer: I don't have any connection to the seller.
That's a ship load of anchors for not a lot of $ - ROAD TRIP USA  ::)
« Reply #40916 on: October 08, 2019, 10:21:36 pm »
Speaking of gift horses, "upgrade" your hacked DS1000Z with an all-in-one genuine license pack from Tequipment...for $0.01! Yep, just a penny.
https://www.eevblog.com/forum/buysellwanted/rigol-bnd-msods1000z-license-clearance-one-penny-at-tequipment-net/
You'll get the options certificate via email.
« Last Edit: October 08, 2019, 10:29:01 pm by bitseeker »
« Reply #40917 on: October 08, 2019, 10:22:50 pm »
That's what the Trojan war has tought us.  :-+  ;D
Btw, is Helena really that beautiful?  8)
« Reply #40918 on: October 08, 2019, 10:31:09 pm »
Dr. Who can help.
 ;D
Hey Bean, did you leave the Dunny door open again???
« Reply #40919 on: October 08, 2019, 10:31:46 pm »
My last one came with all options enabled other than 100Mhz. Standard Rigol policy now.
Actually i think that told us to look in its bum.
I’m sure, like most people back then, from a distance yes  :-DD
« Reply #40920 on: October 08, 2019, 10:33:38 pm »
Yes, it's good for those of us who bought one long ago.
Online xrunner
« Reply #40921 on: October 08, 2019, 10:56:18 pm »
Got the correct SMD diode (SD103AWS-7 SCHOTTKY) installed for the NanoVNA to enable the battery indication. Works perfectly.
Now it's Miller time.  8)
850834-0
850838-1
« Reply #40922 on: October 08, 2019, 11:03:57 pm »
The other end is for the one of us which are polite and civilised.  ;D
That's what I call a 100m beauty. The nearer you come, the less beautiful.  ;)
« Reply #40923 on: October 08, 2019, 11:17:44 pm »
Mmmhmmm... for those of us with 1054Z-cum-1154Zs, I imagine that might be a bit of a downgrade... :o
Heh-heh... heh-heh... heh-heh... he said cum... heh-heh... heh-heh... heh-heh...
« Reply #40924 on: October 08, 2019, 11:23:38 pm »
At least for my part, the banana breads & pies in question were of the sort that one cannot buy, but must be EARNED. And worth every  :phew:;)
Treetrunks got nuthin’ on Mrs. Henderson’s pies & cookies...
