Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17490713 times)
vk6zgo, wolfy007 and 89 Guests are viewing this topic.
« Reply #40450 on: October 03, 2019, 12:13:39 pm »
Indeed. Case is rather nice. I'm happy. It will probably run with front off though. Keep airflow unrestricted. It's mostly light workload and no overclocking so it'll be fine for that.
Offline URI
« Reply #40451 on: October 03, 2019, 12:23:46 pm »
The lost package has found its way to me:
It was delivered the next entrance of the appartment block I'm living in -to someone that I don't know and who doesn't know me.  :palm:
Gladly, this person came over to me yesterday asking when I would have liked to come and fetch my packet.   :o
After I explained to him that I didn't get any note and the hotline couldn't tell me to whom it was delivered to because the signature was unreadable he understood and was friendly again.   :)
I will use this front plate of a HP 3325B as a donator for the keyboard for my HP 3325B where the marking of one of the keys has faded away and the keys have turned their color to a yellowish tone:
I know, it's not a must at all but it's a hobby^Wan addiction, so I don't bother.    >:D
Only problem is: The 3325B is at the bottom of the stack...   :-DD
Interestingly ...with flashlight on the keypad to be replaced doesn't look yellowish on the photo but rather white.
But it's yellowish, believe me.
Edit: corrected model number from 3325A to 3225B
« Last Edit: October 03, 2019, 02:14:32 pm by URI »
The following users thanked this post: med6753, bd139
« Reply #40452 on: October 03, 2019, 12:30:22 pm »
Definitely a first TEA world problem.  :-DD
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #40453 on: October 03, 2019, 01:23:55 pm »
FYI for my buds here regarding the NanoVNA 3D printed case (at least the popular style).
In order to flash the firmware in .dfu mode you must short together the two pins shown in the pic until finished. If it's outside any case you can clip the pins together and all is well. But, since they do not have header pins, when it's inside the case, you cannot access the pins - they are covered by a supporting rib on the case.
I am adding header pins to the board in that location to make it easy to short out the pins either with a clip lead or a shorting block, which then means they will interfere with the case ribs. So I'm going to cut out the rib space required manually (not worth hours more printing just for this little mod). Just letting you know, if you want to add headers the case needs to be modded before printing (not hard to subtract that area in a CAD program), or you can cut it afterwards.
That is all, have a nice day.
The following users thanked this post: PA0PBZ, bd139, beanflying
Offline SilverSolder
« Reply #40454 on: October 03, 2019, 01:24:33 pm »
[...] I will use this front plate of a HP 3325B as a donator for the keyboard for my HP 3325A where the marking of one of the keys has faded away and the keys have turned their color to a yellowish tone [...]
The 3325A and B models have different key hardware though, can you actually swap parts between A and B this way?
« Reply #40455 on: October 03, 2019, 01:59:17 pm »
I know some of you in here are aircraft, especially warbirds, fans.
7 killed yesterday when a B-17 went down in Connecticut. There's only about 18 or so still flying.
https://www.nbcnews.com/news/us-news/vintage-b-17-plane-crashes-erupts-flames-bradley-international-airport-n1061161
« Last Edit: October 03, 2019, 02:01:23 pm by med6753 »
Offline Martin.M
  • in Tek we trust
    • vintage Tek collection
« Reply #40456 on: October 03, 2019, 02:05:42 pm »
here is a stop watch for olympic games.
Manufacturer: Philips (Elektro Spezial)
counting: 99,9999 seconds.
Time base: tube crystal 10kHz
economy: yes, only 100W
There are 3 different plugins:
one digit (5pcs)
one digit + komma (what is a holle illuminated with a little bulb)
crystal time base
« Last Edit: October 03, 2019, 02:11:50 pm by Martin.M »
The following users thanked this post: xrunner, doktor pyta, Cubdriver, med6753, mnementh, Mortymore, bd139, factory, Kosmic, grbk
« Reply #40457 on: October 03, 2019, 02:07:47 pm »
That is cool!  :-+
Martin, you have all kinds of neat stuff.  :-/O
Offline URI
« Reply #40458 on: October 03, 2019, 02:12:10 pm »
No, I don't think so.
I just misspelled the model number.   :palm:
I have a 3325B (my photos show it..)
edit: corrected the misspelling in my two posts.
« Last Edit: October 03, 2019, 02:17:24 pm by URI »
« Reply #40459 on: October 03, 2019, 02:42:29 pm »
...I am adding header pins to the board in that location to make it easy to short out the pins either with a clip lead or a shorting block, which then means they will interfere with the case ribs. So I'm going to cut out the rib space required manually (not worth hours more printing just for this little mod). Just letting you know, if you want to add headers the case needs to be modded before printing (not hard to subtract that area in a CAD program), or you can cut it afterwards.
That is all, have a nice day.    (Attachment Link)
I thought these came with an extruded aluminum case like the DSO2x3? Or are those pics on fleaBay just of nicely refinished FDM cases like yours?
*hiding out from the suck*
Online xrunner
« Reply #40460 on: October 03, 2019, 02:53:08 pm »
No, what you see is simply PCB material milled out and painted . The PCB covers don't have any copper under the paint either.
Offline Martin.M
  • in Tek we trust
« Reply #40461 on: October 03, 2019, 02:54:36 pm »
Do you know the german word "Großbildoszilloskop" ?  :)
Offline Martin.M
  • in Tek we trust
« Reply #40462 on: October 03, 2019, 03:04:16 pm »
... its a KNOTT, munich, germany.
8 channels + 1x diff.  amber-yellow with long delay (radar phosphor)
it runs 59 Tubes, and please do not ask what is the weight of the little instrument
 8)
« Last Edit: October 03, 2019, 03:07:15 pm by Martin.M »
The following users thanked this post: Cubdriver, med6753, mnementh, Mortymore, bd139, Kosmic, grbk, 0culus
« Reply #40463 on: October 03, 2019, 03:07:02 pm »
So... that translates to Godzillo’scope...? :-DD
 :clap:
« Last Edit: October 03, 2019, 03:10:05 pm by mnementh »
The following users thanked this post: Zucca, Neomys Sapiens, bd139
« Reply #40464 on: October 03, 2019, 03:10:24 pm »
Ahhh... making an extra PCB and letting the silkscreen be your “finished product”. Have seen that before; guess I should’ve looked closer.
Will revisit when I again have time for such things.  ;)
 :scared:
Offline Martin.M
  • in Tek we trust
« Reply #40465 on: October 03, 2019, 03:13:52 pm »
If you need a good programm in TV you must use a glowing Oldie and turn it to watch in the backside.
The following users thanked this post: xrunner, bd139
« Reply #40466 on: October 03, 2019, 03:41:36 pm »
 :-DD
Martin.M - these posts are great  :-+. Thanks for posting them :)
Offline Martin.M
  • in Tek we trust
« Reply #40467 on: October 03, 2019, 04:00:36 pm »
here are the alternating facts why they need the brexit.
the dual beam desaster from Solartron can`t be sold to people who do not understand how to use it  :)
german electro boys knows only knobs "Time Base , mV/Div , Position" and so on..
« Last Edit: October 03, 2019, 04:15:14 pm by Martin.M »
« Reply #40468 on: October 03, 2019, 04:16:28 pm »
I can figure that out even though it's all in Deutsch.  Upper beam and Lower beam.  :-+
What's my prize?  :-DD
Offline nixiefreqq
« Reply #40469 on: October 03, 2019, 04:18:43 pm »
hp 8569b update.
over the air signal from channel 21 harrisburg (rf channel 32).  (40 miles and a mountain between us)
awwwwww crap.  forgot to include a calculator in the frame.
free range primate
The following users thanked this post: xrunner, Cubdriver, med6753, mnementh, URI, Kosmic, grbk
« Reply #40470 on: October 03, 2019, 04:19:34 pm »
Next project. Mount the 10MHz reference in a project case with a self contained power supply. Initial fitment shown here. Need to order some more parts.
The following users thanked this post: Zucca, bd139, Kosmic
Offline Neomys Sapiens
« Reply #40471 on: October 03, 2019, 04:28:27 pm »
Got this on the printer so my silicone cables don't get chaffed  ;)
Takes about 22m of filament with 4 layers all round and 25% infill. In the zip file if anyone else wants to give it a go too.
Nice! So please answer me some questions, as I would give the technology a try before jumping into the hole headlong.
What did that cost you to make (Material)?
Did you find that model or did you have to do 3d-CAD?
What is the material?
How long did it take to print?
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #40472 on: October 03, 2019, 04:30:54 pm »
Gaze at the pretty neon glow and breathe serenely.
-Pat
Amazing picture! Those Nixie tubes in dim light  :-+
Can we have it on better resolution?
This should get you to the original photo:
https://pmanning.smugmug.com/Electronics/Lucent-RFG-M-RB-Rubidium-Frequency-Standard/i-TFTjLzn/A
I think it should be downloadable; if not and you want a copy let me know and I'll PM it to you or something.
-Pat
The following users thanked this post: Mortymore
Offline Cubdriver
  • Nixie addict
« Reply #40473 on: October 03, 2019, 04:36:18 pm »
Guys, could we all please just each take a deep breath and chill for a bit?
Look!  Nixies!!
-Pat
careful there man!  you can overdose from too much of that.  try to limit your intake to one nixie device at a time, or you risk finding yourself unable to blink.
ps  is that a lucent gps?  am also a telephony aficionado.  (not much chance though of stirring up an at&t vs northern telecom vs gte war)
Close - it's the rubidium one.  I have the matching GPS unit as well, but have not gotten to obtaining and rigging an antenna for it so far.
-Pat
Offline Martin.M
  • in Tek we trust
« Reply #40474 on: October 03, 2019, 04:40:55 pm »
congratulation.
The following users thanked this post: xrunner, med6753
