Are you going to re-instate the battery option now? I find mine with the battery option fitted is great, it saves me having to turn on the entire bench feed if I just want to a quick and dirty ad hoc measurement, far quicker then getting a hand held DMM out. ![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
Unfortunately the internal battery measures a whole 206mV which means the cells are, to use a technical term, knackered. Thus I will look for something in the same form factor but it's going to come to about £40 after looking at RS. Not sure I can be bothered with that so might leave it disabled. I will do some research on suitable 6V 2.5Ah batteries over the next few days when I get some time.
Anyway calibration done and it's in situ now with its fellow emissive displayed friends (and other assorted cack)
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
![](https://imgur.com/mxnSmS4.jpg)
Managed to fight the arduino and won by binning it and using vim + AVR-gcc + NT7S's Si5351 code. Also got the (cheap shitty) encoder connected to INT0/1 and run it on pin change interrupts as well. This only has one channel set up at the moment but I need two out of phase variable signals for a quadrature product detector and it's a pain in the arse doing it on the DG1022Z due to the randon phase alignment problems.
![](https://imgur.com/5H93QYU.jpg)
And on that note I'm going to turn it all off and go and watch Disenchantment in bed.
![](https://imgur.com/u9YavkB.gif)
