I set the 3400A aside until I find a donor unit that won't make me feel like I am spending $50 for a plug socket. Wandered into the storeroom and pulled the next thing out of the pile. Guess what it is from this photograph:
Yes that is a 0.009975mfd, 400V electrolytic capacitor. One of two in this unit. The big capacitor above it has the negative lead removed and the entire case is soldered, along its length, directly to the printed circuit board.
It powers up and generates and appropriate signal (more or less), too, which was a surprise as it came out of the last "here take this stuff I need to get it out of my garage" trip.
Med or one of the other tek-addicts will probably recognize it.
Yep, it's a special timing capacitor. I think the Type 114 I have coming uses one if not the same or similar value. Also many of the older Tek scopes use very specialized, and unobtanium, tight tolerance timing capacitors.
Edit....luckily they rarely go bad.
Yup... it is a 114. I've been collecting the "calibration" boxes for the last year, like the 114 and the 191. I was going to finish going through all the various meters before I started but I clearly prefer working on things that generate signals rather than measure them right now. So, some 114 *pron* ...
![](http://u.cubeupload.com/worsthorse/IMG0700.jpg)
It worked on power up, though the switches are flaky and it has a few issues:
![](http://u.cubeupload.com/worsthorse/IMG0698.jpg)
When I opened it up, I discovered what looked like a series of ECO mods... a diode removed, a couple of RC networks added, a heatsink added to the PA transistors
![](http://u.cubeupload.com/worsthorse/IMG0716.jpg)
Dig that crazy heatsink!
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
There was also an electrolytic added, on the back of the board, which has leaked and disconnected itself in the process...
![](http://u.cubeupload.com/worsthorse/IMG0714.jpg)
I am going to remove the bad cap and clean up the board around it. Then I am going to document the modifications, (which aren't on the schematics I have). I am going to assume that the mods are there for a reason and leave them in place, though I am wondering about the electrolytic...
Sidenote: This 114 was built with Ge transistors almost exclusively. The good news? I have a crate full of Ge parts in my storage room and the user manual includes commercial subs for the tektronix part numbers.
