You should now notice that all the plug-ins have two matching holes for those latches, you will probably be looking for a 5243L or 5245L from 1962 to 1964.
Earlier in the week some unicorn poop arrived, a HP 5240A frequency meter, I'm still a little pissed off at the moment that one of the handles got busted off, will try and get some pictures on here tomorrow.
actually had noticed that the plug in's had a latch slot on both sides. used to have an hp 5345 with a 10590 adapter and noticed at the time that its locking latch knob was on the right side. always figured that was just because the lever latch for the adapter was on the left.
a 5240? wow. have never seen one.
It's the first 5240A I've ever seen, inside it's mostly the contents of the 5260A frequency divider with an 8 digit 12.5MHz counter stuck to the top (probably based on the circuitry from similar counters such as the 5321 & 5216A).
It was packed in a large enough box, but unfortunately it was filled with the thousands of tiniest polystyrene balls I've ever seen, most of which had escaped out of the box (not enough tape used to close it), the useless balls allowed the heavy meter to move about during transit & were a PITA to contain after opening the box, there were holes created by both the front handles and the BNC adaptor/termination on the back.
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=841388)
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=841392)
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=841396)
A quick test to see if it still worked (after changing switch to 240V), picture is a bit crap, one more tube lit than in the sellers pictures, the half zeros were showing in the sellers pictures too.
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=841400)
More to follow with some inside pictures.
