While using the Tek 284 pulse generator, It has become evident that there's some intermittent contact going on inside of the airline. I was able to get a pulse when tapping on the GR874 pulse output connector, which lead me to believe there was a bad connection somewhere at or near the tunnel diode. I removed the airline and found the following:
The piece that makes contact with the tunnel diode has bent "fins" on the end that slide over the inner conductor of the GR874 connector. The manual doesn't show a spring in this part, but it seems like the inner conductor of the 874 connector is machined out for one...
I removed the set screw, spring, and ball bearing to clean to ensure good contact with R180.
I also removed the contact and spring on the other side of the tunnel diode and found that the spring has been stretched and twisted.
I also tested the tunnel diode on the 7CT1N, and it's fine.
The springs measure 0.125" OD and are closest to 0.500" length, so those are the ones I've selected. I ordered a pack of music wire type and stainless steel type.
I ordered some new springs from McMaster-Carr.
music wire springs PN: 9657K266
SS springs PN: 1986K45
Time to put this 284 back together so I don't lose anything..
