Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17362171 times)
Vince and 50 Guests are viewing this topic.
« Reply #39025 on: September 17, 2019, 02:53:57 am »
I ended up finding a way better deal with a HP 974a.
Oh dear, is it RPN?
Nope. You choose the function, first. :-DD
« Reply #39026 on: September 17, 2019, 03:06:32 am »
LOL there's 21 "guests" viewing this thread right now, they must think we're all crazy.   :-DD
Hey man - if the shoe fits...   ;)
-Pat
11th Commandment, man...  :-+
Did... did... did somebody say cannoli...?
Sooooo long since I had cannoli...
damn.  hope your diet did not become collateral damage in our vendetta.
Nope, I made Pillsbury Flaky Layers breakfast biscuits; had one with butter & orange marmalade while it was still hot. Satisfied my sweet tooth (and the fang next to it) just fine.  >:D
Considering the distances involved with GPS and the fact that a good lock could land a hand grenade close enough to me to put me in the hospital ... or the morgue ... I think I'd be OK with the error.
... but, then, I'm not a true time nut.   (yet)
All right... which one of you jokers lifted the remote to my suborbital crowbar launcher...?
*slaps the bill for reloading on the table* Ever since they got the ISS contract, costs 3 times as much... bastards.
« Reply #39027 on: September 17, 2019, 03:09:58 am »
I can afford to waste decent resistors on magic smoke opportunities  :-DD (4000x TE LR1F100R)
I remember that order! :-DD
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #39028 on: September 17, 2019, 03:23:18 am »
I picked up a super clean Heathkit SG-8 in original condition.    I just need to re-cap it, check the resistors, and align it and it should be like new!
There isn't any rust or even much dust on the inside.  It's like it's been stored in a sealed time machine.
Nice!  FWIW, I believe the connector that mates to those old-school screw-on mic jacks is a Switchcraft 2501F.  Mouser has them in stock; they're about $7 a pop.
And in a slightly related note, the baby version of that mic connector, which is used on things like the Simpson 303 VTVM, is a Switchcraft 5501FX, also available from Mouser for about the same price.
-Pat
The following users thanked this post: dcbrown73
« Reply #39029 on: September 17, 2019, 03:26:20 am »
Just won some more HP goodness. I really don't need it but it was in pretty good condition. 5316B  :-+
Not sure what timebase it has in it but if it's a poo one I have an excuse to build a replacement OCXO :)
Edit: just realised I'm going to need a common frequency standard now and distribution for it. Hmm can of worms now opened :-DD
You are on the correct path, grasshopper.
« Reply #39030 on: September 17, 2019, 03:37:05 am »
Such a simple project...
Famous last words... :-DD
« Reply #39031 on: September 17, 2019, 04:39:47 am »
-Pat
You're right. Their actual intended purpose was a microphone connector, not an RF connector. A lot of TE in the 1950's used them anyway because they were cheap and readily available.
« Last Edit: September 17, 2019, 04:41:42 am by med6753 »
« Reply #39032 on: September 17, 2019, 05:01:09 am »
Time to stop using my clunky very repeatable but fairly inaccurate old USB Victor 86B's. Not sure what to do with them after 7-8 years + of reliable use.  :-//
Playing with the heavy metal in my larger Coffee Roaster, 12V supply fitted for some additional stepper and servo automation and powering a micro to make it all work. Also fitted is a heatsink so the SSR won't overheat and go to sleep which brought forward the current upgrade from later in the year.
Most of this wiring is ex factory Chinese proving not all of it is junk. Even reasonable sleevening  ;)
Offline bsfeechannel
« Reply #39033 on: September 17, 2019, 06:17:14 am »
For those that didn't learn a little German at school, in German the verb is at the end of the sentence, not between the subject and object. Yes, German is RPN :)
Eh, no. The verb is between the subject and object unless there is a tense or additional verb in the same sentence.
McBryce.
Jepp. Example:   "bd139 verlötet Molexstecker."
bd139 <-- subject
verlötet <-- verb
Molexstecker <-- object.
Another example:  "med6753 benutzt UPN."
Same pattern as above.  ;)
Hope, this was helpful.
Afaik German is classified as a 2V word order language, i.e., the finite verb comes in second place in main clauses. The infinite verb is placed at the end. In subordinate clauses the finite verb is placed after the infinite verb.
Z. B.: Ich habe Deutsch gelernt, weil ich mit BU508A reden will.
Translation word for word: I have German learned, because I with BU508A to talk want.
In red are the finite verbs. In black, the infinite ones.
In main clauses where you only have a finite untrennbares verb, however, it sounds like a typical SVO (Subject-Verb-Object) language like English, French, etc., as you showed.
By the way, I don't speak German. So don't quote me on that. :P
P.S: BD139 solders the Molex connector.
Offline McBryce
« Reply #39034 on: September 17, 2019, 07:05:35 am »
Yes, as stated. With just one verb in the sentence the verb is between subject and object:
"bd139 verlötet Molexstecker" = bd139 miss-solders Molex connectors
With supporting verbs in the sentence or fragmented sentences, the verb(s) move to the end:
"bd139 hat den Molexstecker verlötet" = bd139 miss-soldered the Molex stecker (Past tense, verb at the end)
"bd139 merkte nicht, daß er den Molexstecker verlötet hat" = bd139 didn't notice that he miss-soldered the Molex Stecker (Fragmented past tense sentence, two verbs at the end)
"Hätte bd139 es richtig gelötet, wäre weniger Rauch im Zimmer" = If bd139 had soldered it correctly, there'd be less smoke in the room (just added to complete the story :D )
McBryce.
« Last Edit: September 17, 2019, 07:07:23 am by McBryce »
The following users thanked this post: bsfeechannel, mnementh, grbk
Offline tautech
« Reply #39035 on: September 17, 2019, 07:11:47 am »
McBryce.
Some might say he's not equal to the task !  :-DD
Out of office and unavailable for a few days.
« Reply #39036 on: September 17, 2019, 07:21:12 am »
bd139 gefickt Molexstecker! Scheisse!
The following users thanked this post: McBryce, BU508A, mnementh, Mr. Scram, Neomys Sapiens, grbk, horo
Offline McBryce
« Reply #39037 on: September 17, 2019, 07:29:59 am »
See! You're already getting the hang of it :D
McBryce.
« Reply #39038 on: September 17, 2019, 08:20:00 am »
McBryce.
Just as long as my name doesn't get dragged into this again.  :-DD
« Reply #39039 on: September 17, 2019, 12:33:51 pm »
Got new laptop. Phew. Damn thing is immaculate. No sign of use. Also 372 days of Lenovo warranty left, decent Samsung SSD, perfect full HD screen, new genuine USB-C charger. Winner  :-+
Offline McBryce
« Reply #39040 on: September 17, 2019, 12:35:51 pm »
Well USB-C at least stops us from making jokes about you putting connectors in the wrong way :)
McBryce.
Online Wolfgang
    • Electronic Projects for Fun
« Reply #39041 on: September 17, 2019, 12:36:50 pm »
McBryce.
Proper UPN:
BD139
ENTER
MolexStecker
ENTER
FUCK
SHIT
ENTER
« Reply #39042 on: September 17, 2019, 12:38:39 pm »
McBryce.
Hahaha it's got plenty of those USBs and I've done it several times already today  :-DD
The following users thanked this post: xrunner, mnementh
« Reply #39043 on: September 17, 2019, 12:52:57 pm »
Good, just don't blow the poor thing up this time then eh?  :-DD :-DD
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #39044 on: September 17, 2019, 12:54:44 pm »
I hate the USB connector design. Why didn't they make the top or bottom easier to see?  :palm:
« Reply #39045 on: September 17, 2019, 12:56:16 pm »
McBryce.
How the Fecking hell do you manage to do that, they are designed to fit together easily one way only, if you have to exert force then you clearly have them round the wrong way  :-// :palm:
Online xrunner
« Reply #39046 on: September 17, 2019, 01:01:34 pm »
My neighbors who I help with their PC problems did a job on one of the USB connectors on their laptop. It's in the right way but will not come out. I told them I'd have to take it apart to get it out for fear of damaging the internal parts and mucking the computer up.
« Last Edit: September 17, 2019, 01:03:54 pm by xrunner »
« Reply #39047 on: September 17, 2019, 01:19:28 pm »
Also another problem with USB is that USB plugs neatly fit into the ethernet hole too.
Edit: something I hate about new PCs these days. Some Dolby shit gets turned on and makes everything sound like farts in a coffee can until I've found it and neutralised it.
« Last Edit: September 17, 2019, 01:24:06 pm by bd139 »
« Reply #39048 on: September 17, 2019, 01:33:09 pm »
Offline Mr. Scram
  • Display aficionado
« Reply #39049 on: September 17, 2019, 01:33:14 pm »
They may be designed to fit easily one way but they sure as hell don't in reality.
