Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 18229345 times)
SingleBitError, Carl_Smith and 66 Guests are viewing this topic.
« Reply #38725 on: September 12, 2019, 12:55:04 pm »
Final picture as most of the ones I've posted are it lying arse up!
Edit: so scope situation:
1. HP 1740A - working
2. Philips PM3217 - working
3. Hameg HM203 - working
4. Rigol DS1054Z - working
5. tektronix 475 - working
6. incoming Telequipment D75 - not working.
That's a good turnout. So, which one do you think is going to break first?  :-DD
« Last Edit: September 12, 2019, 01:07:36 pm by bd139 »
The following users thanked this post: nixiefreqq, Kosmic
« Reply #38726 on: September 12, 2019, 01:25:48 pm »
Thought it was a pass transistor but it was the drive current from the LM723. I stuffed a DMM in series with base and it was only driving 4mA through whereas for the beta it should have been about 30mA. That was causing rails to collapse.
Anyway made a heatsink quick. Took longer to get the bloody screw in than make the heatsink. Disclaimer: I have zero metalworking tools here so this was literally aviation shears, file and hand drill :-DD
Hey, that will work. Not a bad bodge at all.  :-+ :-DD
This 465B has been cluttering up bench 1 for 2 days now untouched. Gotta get my arse in gear here. Today's mission is to get the old capacitors out without destroying the board....or myself.  :o ;D
« Reply #38727 on: September 12, 2019, 01:30:13 pm »
Shut your mouth.  :P :P :-DD
« Reply #38728 on: September 12, 2019, 01:37:43 pm »
Hahahaha  :-DD
Offline dcbrown73
« Reply #38729 on: September 12, 2019, 02:38:53 pm »
Just picked up a Sencore LC75 with SCR250 SCR and triac tester.
Guess this means my Peak ESR70 will be relegated to mobile use.
Why exactly do people feel I should have read their post before I responded?  As if that was necessary for me to get my point across.
The following users thanked this post: med6753, Neomys Sapiens, bd139
« Reply #38730 on: September 12, 2019, 03:04:11 pm »
FFS I was going to buy a Farnell L30BT power supply as a beater but I forgot to bid on the damn thing  :palm:
« Reply #38731 on: September 12, 2019, 03:25:26 pm »
@bd139, great job with the 1740A looks like great win there  :-+
I've been working on the SU-V2X amp again, it had noisy left channel with a low burbling noise and low gain, thinking that it was probably, a cap, I've pulling them out and checking and found nothing at all. There was a spot of some sort of spillage on the PCB so while clean, the transistor got slightly touched and then I found what I believe to be the problem. The spillage had corroded the base leg of a transistor right beneath its body, new one on order, so hopefully if the Ebay offer is on next week I'll be flipping it again.
« Reply #38732 on: September 12, 2019, 03:29:24 pm »
Glad that Lucas aren't in the semiconductor business still. They'd just sell that as a TO92 diode  :-DD
Offline worsthorse
  • aina varma, usein väärin
« Reply #38733 on: September 12, 2019, 03:53:05 pm »
That PCB looks like it has had a hard life.   :'(
« Reply #38734 on: September 12, 2019, 04:00:02 pm »
I can't tell you how much fun this is. Like going to the dentist. Got 2 of the capacitors pulled so far. What a royal pain in the gonads. And one land pattern pulled up as a bonus.  :palm: Luckily super glue fixed that. 3 more to go. I knew these were going to be difficult but geeeez.  :-DD
Offline worsthorse
« Reply #38735 on: September 12, 2019, 04:11:52 pm »
The schematics for the B+K 2831D appear to have been drawn by someone who never had to read a schematic. Ever. And added it to the service manual when no one was looking. Missing connections. Random symbols. Unlabeled connections.  A bypass capacitor that appears to short a resistor that determines the input impedance when measuring AC voltage. I imagine that some poor customer service tech had a dog-eared, much marked up version that allowed one to actually work on it.
But it is sort of fun figuring stuff like this out, at least when I am not getting paid to do so. Which is good because I will spend more time fixing the schematic than I will fixing the DMM.   ;D
« Reply #38736 on: September 12, 2019, 04:13:51 pm »
In Other News...
OH MY FUCKING GAWWD!!! I CAN SEE THE LIVING ROOM FLOOR!!!
*small moving-time victory number 57*
The following users thanked this post: bd139, Kosmic
« Reply #38737 on: September 12, 2019, 04:14:58 pm »
Looks like OEM from the guys who made my KSGER T12 soldering station.  :-DD
Any reason you're not replacing with a larger rectum-frier that isn't operating so close to max tolerance?
 :scared:
« Reply #38738 on: September 12, 2019, 04:42:50 pm »
 :scared:
Unfortunately it’s a weird ass 0.156 pitch rectifier which is obsolete by about 20 years this the options were limited. That tiny little POS was 6A rated if I remember correctly. But you have to nail it to something. It’s pulling ~560mA average through it.
I actually had to buy a whole tube of 50 of the damn things just to get one. Figured I’d use the rest in the future one day!
« Reply #38739 on: September 12, 2019, 04:45:07 pm »
It has in that area, coke was spilled over it through the top vents of the amp and I'd just been trying to clean the sticky gunge off, still see some in the holes.
« Reply #38740 on: September 12, 2019, 05:33:04 pm »
They're out, finally. And with only one fubar'ed land pattern which has been repaired. 100% IPA to remove all the flux. Tomorrow new install and power up.   :-+
« Reply #38741 on: September 12, 2019, 06:14:10 pm »
That looks pretty tidy  :-+
Going to have to do the same this week with the D75 and the boards in it are single sided non plated through ones  :scared:
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #38742 on: September 12, 2019, 06:17:27 pm »
Oh my - those are some tall ones.  :P
« Reply #38743 on: September 12, 2019, 06:29:00 pm »
The replacements are so small in comparison that you wonder if they will work.  :scared:
Online xrunner
« Reply #38744 on: September 12, 2019, 06:39:51 pm »
Oh yea much better capacitor technology/manufacturing now - can you place some side-by-side for comparison?
« Reply #38745 on: September 12, 2019, 06:41:20 pm »
Sure, give me a few minutes and I'll put the replacements with the old ones.
« Reply #38746 on: September 12, 2019, 06:49:28 pm »
The following users thanked this post: xrunner, Brumby, bitseeker
Online xrunner
« Reply #38747 on: September 12, 2019, 07:02:24 pm »
Yep - that's about the size of it (no pun intended). Way smaller and more reliable too.  :clap:
Offline dcbrown73
« Reply #38748 on: September 12, 2019, 07:23:57 pm »
Those are too small.  Not gonna work.   :-DD
« Reply #38749 on: September 12, 2019, 07:27:41 pm »
 :-DD
Just buy some from Aliexpress! :)
