Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17746770 times)
0 Members and 86 Guests are viewing this topic.
« Reply #37725 on: August 30, 2019, 09:11:59 am »
BU508A, I got this one if you want. Diameter is 24.10mm and shaft is 6.40mm
Thank you for your kind offer, but I would check out first this hamfest in Weinheim (weekend 7th / 8th of September) if I could find anything that fits.
Thanks again,
Mounty
https://ukw-tagung.org/
« Reply #37726 on: August 30, 2019, 09:20:54 am »
The comment below the line was the set up for a joke. You were meant to ask how much, then i give some ridiculous monetary value or perhaps even your soul. Also a quarter is 24.26mm
Yeah, I have to recalibrate my humor detector unit.  ;)
And thanks for the info.
Cheers,
Mounty
« Reply #37727 on: August 30, 2019, 09:43:56 am »
"Memo to self: do not become a voltnut."
I explicitly tried that technique, with insufficient success :(
In my case some functional 70yo saturated Weston Cells were the gateway to hell.
Mine was the LTFLU-1, mysterious unit, no datasheet  etc.
There you go ...
« Reply #37728 on: August 30, 2019, 10:00:02 am »
I'd like to share two pieces of advice here for our UK readers...
1. Never buy anything that is RS Pro branded.
2. Never buy any die cast boxes that aren't Hammond branded.
Just got me the worst turd I've ever seen. Lid is bent and doesn't shut and the walls are dented and the whole damn thing is bent. Also none of this was the postman's fault.
« Reply #37729 on: August 30, 2019, 10:05:17 am »
Have you ever tried the die cast boxes from RND Components, available @Reichelt?
Bopla, ROSE and Fischer electronic are good as well. Imho.
https://www.reichelt.de/Metal-Enclosures/2/index.html?ACTION=2&LA=2&GROUPID=7722
« Reply #37730 on: August 30, 2019, 10:08:53 am »
Not tried those yet. Our availability is pretty limited on these here. We are saturated with Hammond, Camden Boss and shit from China. I occasionally order from TME so might have a look there too.
Edit: this box is supposed to be IP66 rated (strong water jets) as it's going outside but I can slide paper in the side of it when the lid is screwed down hard ffs  :palm:
« Last Edit: August 30, 2019, 10:22:47 am by bd139 »
« Reply #37732 on: August 30, 2019, 11:04:25 am »
And where was this box made, China?
Sent from my POT-LX1 using Tapatalk
« Reply #37733 on: August 30, 2019, 11:16:13 am »
Hammond are nice as are Rose. RS Pro is only branded bottom of evilbay  :--
« Reply #37734 on: August 30, 2019, 11:22:11 am »
https://eshop.wuerth-ag.ch/is-bin/INTERSHOP.enfinity/WFS/3126-B1-Site/de_DE/-/CHF/ViewModelDetail-ShowRecommendedModel?CatalogCategoryID=VLIKD92dO34AAAFYdLcqafae&CampaignName=CS008&RecoId=categorytopseller%40categorypageA
 :popcorn:
LMAO
Made by "simbo" in China. RMA'ed the fucker already. It's a joke.
A lot of the hammond ones are actually Eddystone ones (same dies and Eddystone logo). Those were always the best.
Anyway, lunch time fixing session. Still waiting for the damn LM723 to turn up but got the Molex connectors. Reworked HP 1740A board. Not pretty and I had to gouge and fill some stuff but it's electrically ok now. Will conformal coat the new copper runs later once I've powered up the board and checked it out. Conductor clearance and soldering is better than it looks in the pictures!
I'm going to check that square bridge rectifier temperature once the scope is powered up and may add a little heatsink to it.
« Last Edit: August 30, 2019, 11:32:38 am by bd139 »
« Reply #37735 on: August 30, 2019, 11:30:20 am »
RS did good:
Ordered the Hammond equivalent now (from another supplier!)
« Reply #37736 on: August 30, 2019, 11:37:06 am »
"If you buy cheap, you'll buy twice."   ;)
« Reply #37737 on: August 30, 2019, 11:40:47 am »
If I buy cheap RS pays for the experiment  :-DD
Need to find a Schadow NE15 power switch for this HP now. Nightmare.
« Reply #37738 on: August 30, 2019, 11:47:30 am »
This one?
https://www.ebay.com/itm/192566244235
Can reship it, if you want.
« Last Edit: August 30, 2019, 11:49:11 am by BU508A »
« Reply #37739 on: August 30, 2019, 11:55:53 am »
That’s the one! Thank you. I may take you up on that offer if I can’t find one here. Will PM you.
Edit: more research - that isn't the one. It needs pins on the bottom as well as top :(
« Last Edit: August 30, 2019, 12:14:43 pm by bd139 »
Offline Mr. Scram
  • Display aficionado
« Reply #37740 on: August 30, 2019, 12:25:16 pm »
I have to disagree. Some decent rebranded kit is sold under RS Pro.
« Reply #37741 on: August 30, 2019, 12:32:55 pm »
I've found this one @Conrad electronic
https://www.conrad.de/de/p/pwl-2p1tl-6sasha-netzschalter-druckschalter-250-v-ac-6-a-2-x-aus-ein-rastend-1-st-701606.html
Would this fit?
Edit:
Are you sure it is a NE15, not a NE18 by any chance?
https://www.ebay.com/itm/362704922415
« Last Edit: August 30, 2019, 12:38:27 pm by BU508A »
« Reply #37742 on: August 30, 2019, 12:39:29 pm »
Quite right.
« Reply #37743 on: August 30, 2019, 12:42:29 pm »
Problem is it's a dice roll.
Would this fit?
Edit:
I think NE18 appears to have superseded the NE15. That is the right format though but without tie bar.
Have managed to solve the problem though, for a slightly grumblesome tenner: https://www.ebay.co.uk/itm/202251155171
I will buy one when I've got the LM723 in and I'm 100% sure it's not going to end up a parts mule. Not before  :-DD
Edit: Even cheaper! Looks like there's a thousand different things about right: https://www.rapidonline.com/rvfm-pt-m3bl-pcb-power-switch-locking-dpst-m3-hole-78-0069
« Last Edit: August 30, 2019, 12:50:49 pm by bd139 »
« Reply #37744 on: August 30, 2019, 12:50:55 pm »
I would try to re-use the tie bar with the new switch. Having done this in the past. Works well, if one is careful with the bending.
Good luck with the 10 Pound switch, hope it will fit.  :-+  :)
« Reply #37745 on: August 30, 2019, 12:54:45 pm »
Got cheaper - £5.60 in the end from Rapid inc delivery.
Offline factory
« Reply #37746 on: August 30, 2019, 01:01:38 pm »
Well their fuses glow just as brightly as other brands in my faulty HP 180A.  :-DD
Offline factory
« Reply #37747 on: August 30, 2019, 01:05:40 pm »
Thanks again,
Mounty
If the damaged knob for the 3460A is part # 0370-0104 I may be able to help, if I can find it of course.
« Reply #37748 on: August 30, 2019, 01:27:32 pm »
Yes, that is exactly the knob. In my case the one for the "Rear - Front" switching.
Much appreciated if you can find one. Thanks.  :-+
Offline Mr. Scram
« Reply #37749 on: August 30, 2019, 01:45:21 pm »
Quite right.
My mistake. It’s all rusty crap. Or do they remove that during the rebranding process?
