Tggzzz, if you get a chance to open up your 485 this week these are the parameters you should set up on yours to match my readings. This set up should result in a trace but trigger light OFF. My trigger light is on.
Scope set up:
Channel 1: 1v/div, GND. No signal.
Int Trig set to channel 1
Time/div set to 1mS
Horiz Display to A
Sweep Mode to Auto Trig
Slope to +
Level to slightly negative
A Trig Coupling to AC
A Trig Source to INT
DC voltages on U780:
Pin 1 +0.495V Pin 11 +5.518V
Pin 2 +0.0789V Pin 12 +0.0108V
Pin 3 +0.3027V Pin 13 0
Pin 4 +4.981V Pin 14 +4.945V
Pin 5 -4.961V Pin 15 +0.8714V
Pin 6 +0.0291V Pin 16 0
Pin 7 +0.4347V Pin 17 -0.4684V
Pin 8 +0.6746V Pin 18 0
Pin 9 0 Pin 19 0
Pin 10 0 Pin 20 +4.980V
And some waveforms:
Pin 17 x1 probe. AC coupled. 0.5V/div 2mS (There is no pulse at pin 16 and I think there should be)
Q816 base. x1 probe. AC coupled 0.1V/div 2mS
J816 x1 probe. AC coupled. 0.5V/div 2mS
Thanks!!
