Here's something some of you might be able to answer: I have a nice set of Teledyne drafting tools. Unfortunately, the foam in their case badly deteriorated and created some kind of chemical reaction with the metal that was touching it, causing pitting. I've removed the instruments and cleaned them as best I can, but I'd like to replace the foam with something modern, but it needs to be easy to cut so the nice little spots for the instruments can be recreated. Any recommendations? It appears the foam in the bottom of the case is about 0.6" (1.524 cm) thick, while the top is about 0.4" (1.016 cm) thick.
I was much enlightened when I learned how such form-fitting inserts are made. They basically use two different techniques.
One is built up from sheets/plates of one or even of two different materials. That is close to how the so-called 'shadow trays', which outline every tool's position brightly, are made. But it can use more layers. The side walls of any position are vertical or slightly stepped in this case.
The other method translates the desired shapes into metal 2d stencils and corresponding pressures. The foam part is placed onto the stencil and pressure is applied. Then, all material that is standing out on the other side is cut off by a straight blade, almost like a shave. If the form is complex, they use different stencil/pressure combinations consecutively.
So when one sees a gradually rounded recess for the fingertips, this is not cut with a curved spoon-like tool, but it is a oval cut-out in the stencil, which, combined with the specific flexibility of the foam, allows such a shape to be made.
