After being stymied by the setscrews, I moved to the back of the scope. No joy.
At least six rotted screws rusted in place. I will have to drill them out, too. With half a day invested already and no end in sight, well yessir I am starting to question my sanity. In case you all weren't already doing so...[/quote]
https://smile.amazon.com/dp/B07Q7ZJXFL/These little guys are your friend. Best $10 you'll ever spend. Make sure you get a set that goes down to at least #0, though. IRWIN makes a better set just for screw heads that doesn't require drilling, but cost ~$25:
https://smile.amazon.com/dp/B0002NYBHIOf course, IRWIN also makes a similar set of stud/bolt-head extractors. Yes, they're more expensive at ~$35. And yes, damn those monsters at IRWIN, they WORK.
It all depends on how much you value your time and assache over money.
*assache-motivated*
[/quote]
I don't mind assache (which should be evident if you've looked at any of the photos I have posted over the last couple of days) but I do hate wasting time...
I was actually on my way to the hardware store to get a decent set o these. ez-outs, as we used to call them. If I need to order them online, I am going to put the 466 aside and try to put a couple more hours into the furnace room/inventory/crating/organization project...
