Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 16690578 times)
Runco990, alan.bain, KG7AMV and 100 Guests are viewing this topic.
Offline neo
  • The specialist.
« Reply #30125 on: April 25, 2019, 02:13:43 pm »
Enough? No. You don't have 20 oscilloscopes, yet. :popcorn:
Your right, i only got eight.
[1] Ballantine 1066s
Functionality;  completely fubar
[2] Hitachi V212
Functionality;  kinda sorta works
[3] Tek 7704A.
Functionality;  Runs like a dream, as far as i know.
[4] Heathkit O-12
Functionality;  Runs well and despite its limitations and flaws i still find uses for it.
[5] Heathkit IO-4540
Functionality;  A curiosity
[6] HP 1654B
Functionality;  Don't ask
[7] HP 141T
[8] Tek 2465B
Functionality;  Work in progress.
If any of y'all care.
Offline FransW
« Reply #30126 on: April 25, 2019, 03:13:35 pm »
Wait, are those figures above (med6753's 10, for example) total or current?
Tek 2465
Tek 2465 DMS
Tek 2430
Tek 465B
Tek 465B/DM44
Tek 475A
Tek OS-245(P)/U
B&K 2120
RCA WO-505A
Siglent SDS-1052DL
Which one is your favorite w.r.t. performance, emotions & (other) considerations?
Frans
PE1CCN, Systems Engineering, HP, Philips, TEK, BRYMAN, Fluke, Keithley
« Reply #30127 on: April 25, 2019, 03:19:44 pm »
Scopey scopey scope scope. My fireplace at the moment:
There's a DS1054Z and 2/3 of two Telequipment D83s somewhere too
« Reply #30128 on: April 25, 2019, 03:28:02 pm »
Update on the Solartron 7150 meters.
Ran some extensive tests on their calibration and I'm pleased to say that are both within acceptable limits of calibration, one will need a re-cal soon I think and the good news is that I could do it myself via the front push buttons, just like the HP3468A and 3478A meters so that's an advantage.
The other issues with both meters, apart from the dodgy filter units, now replaced, was the LCD displays could be difficult to read in some light conditions. The display did have some yellow inefficient LEDs and they could only be seen in the middle of the night with the lights off, (the camera actually made these appear far better then they were in reality), not a good idea to work with no lights  :-DD.
The solution was to replace these LEds with some ultra bright white ones and after a struggle these are now installed and the meters have been transformed completely now as these photos show. Overall was it a wise move to purchase these unseen from an online auction, I would say a resounding yes to that and unlike the Solartron 7045 meter I got off ebay last year, these two have far better plastics used in the construction of their cases. :-+    :phew:
« Last Edit: April 25, 2019, 03:31:30 pm by Specmaster »
« Reply #30129 on: April 25, 2019, 03:50:33 pm »
Awesome. Nice job  :-+
Offline factory
« Reply #30130 on: April 25, 2019, 04:20:09 pm »
We had two failures of the Solartron 7150 meters at work, one of them was the mA range giving a different negative reading with the leads swapped, calibration decided it was BER.
Another one decided to blew it's fuses, an autopsy revealed one of the reed relay coils was cremated along with a full bridge rectifier in the PSU, not sure what was the cause, I didn't see this one fail as I had left the lab for a few minutes at the time.
« Reply #30131 on: April 25, 2019, 04:21:04 pm »
« Reply #30132 on: April 25, 2019, 04:29:32 pm »
Tek 2465
Tek 2465 DMS
Tek 2430
Tek 465B
Tek 465B/DM44
Tek 475A
Tek OS-245(P)/U
B&K 2120
RCA WO-505A
Siglent SDS-1052DL
Frans
Hard to pick just one. But purely from an emotional perspective it would be this one. Why? Because prior to it showing up in 2015 I was essentially inactive in the hobby. And this 2465 DMS needed repair and I had to seek out help via net which eventually lead me to here. And it's been down hill ever since.  :-DD :-DD
« Reply #30133 on: April 25, 2019, 04:42:25 pm »
Not going to even begin to list meters though.  :palm:
Likewise! :palm:
Oh, go on list your meters, that’s my weak spot. I have far more meters than I actually need, then hear Dave Jones voice whispering in my, “You can never have too many meters” so I get another and another and so it goes on. I think I need to let some go, no more space.☹️
Naaahhhh... "Sufficient unto the day is the evil thereof." I feel no need to add to Murphy's spoils today.  ;) And my back remembers the LAST TIME I tried to do a family portrait with all my meters.   :phew:
I'm behind on reading blogs at the moment.
The Tekwiki for the Pacific Measurements 1038 system is moving forward at full blast.   :box:
I figured I'd promote for membership (enjoy yourself... I'm not nit picky) and have a central source for resources, experiences, history or whatever insight they'd like to share regarding Pacific Measurements and Wavetek Systems.  Thanks in advance for your time and support!   :-+
https://www.facebook.com/groups/698747963909529/?hc_location=group
That requires me to log in to farcebook (or less polite names), so sorry, that's of no use to me.
Same here... FurkBook is a toxic wastedump. I pulled the plug there years ago when I discovered what colossal timesink it is; long before we discovered what an utter fuckstick Zuckerberg, et al were being with people's personal data.  :palm:
I just unearthed a Wavetek SAM Jr. 450 I used to use back in the day for troubleshooting hospital/hotel cable TV; not sure it has any real use nowadays, aside from being a clunky "retro" FM radio with poor sesitivity and selectivity...  :palm: It uses a 12-cell 500mAH "AA" NiCd pack... and the battery compartment has plenty of room for 4 18650 cells plus a BMS board. I just did a quick wipedown and cleaned the volume/tuning pots... yup. Barely receives a VERY local Spanish-language Jesus station; not even enough to deflect the meter using the FM dipole antenna on the wall from my stereo.  :P
It'll detect carrier if I key up my 'feng in close proximity, and it detects something very strong around (It's hard to tell... the scale doesn't go that low) 2-3MHz ... maybe WWV?
Hmmm...
*Cogitating-ily*
« Last Edit: April 25, 2019, 04:48:45 pm by mnementh »
The following users thanked this post: PrecisionAnalytic
Offline PA0PBZ
« Reply #30134 on: April 25, 2019, 06:04:32 pm »
Probably zero Hz, where your LO is at the MF frequency.
« Reply #30135 on: April 25, 2019, 07:20:41 pm »
Well, the thing is supposed to go down to like 1500KHz, but not calibrated on the dial. Where I'm picking this up is a little below 4MHz, so guessing 2.5-2.8MHz. But it's probably a local oscillator in the unit, I think, since engaging the atten does nothing. I thought maybe picking up its own 3.58 MHz crystal, but couldn't find one anywhere in it.
Tuner is interesting construction, though, for '80s-'90s vintage electronics.
« Reply #30136 on: April 25, 2019, 07:24:12 pm »
That's some collection you there, please don't tell me you keep in the fireplace, if only you could get them all going
« Reply #30137 on: April 25, 2019, 07:29:18 pm »
Hope mine aren't in for the same treatment? When was this and do you know of their whereabouts now at all?
« Reply #30138 on: April 25, 2019, 07:34:38 pm »
They're only living there for the moment while I finish sorting the cupboard out. The fireplace is actually disconnected as it's dangerous so it never gets turned on. The 2225 and 2235 are going shortly. 2225 isn't a lot of use for me and I've just about had enough of the 2235 now  :-DD
« Reply #30139 on: April 25, 2019, 07:53:34 pm »
So in other words your all fecking scoped out  >:D :-DD
Just maybe, you might have better luck with the HP brand eh? :-//
« Last Edit: April 25, 2019, 07:55:42 pm by Specmaster »
« Reply #30140 on: April 25, 2019, 08:21:56 pm »
I am totally scoped out. Feel like I need a change from Tek to be honest. I've actually lost count of the number of 4xx scopes I've gone through now. Has to be at least 20  :-DD
Maybe lucky with HP. TBH I absolutely need a decent SA at the moment. Decent being one not 30 years old and limping with decent RBW. I tried to build a 70MHz LPF with the TF2015 and my power sensor. It's certainly doable but would be sooooooo much easier with an SA and TG. But they ain't cheap and I have other things I really need to buy. But then again it could be a "fuck it" and live with the consequences purchase  :-//
« Last Edit: April 25, 2019, 08:24:34 pm by bd139 »
« Reply #30141 on: April 25, 2019, 08:55:37 pm »
Well I'm not scoped out. I'm just getting started.  ;D
Dr. Frankenstein here at work. The first organ harvest out of the 465B parts mule.  >:D Both channel attenuator switch decks with the vertical switch board attached.
Are they any good? Channel 1 (top deck) showed some issues. Channel 2 is PERFECT.  :-+ Solid DC continuity on all switch ranges. That will soon be transplanted into the 465B/DM44 with the fubar channel 2 deck.
Been juggling back and forth between TEA stuff and domestic stuff. Total redecoration of the bath plus complete repaint (ceiling and walls). Turned out damn nice if I say so myself.  ;D   Soon will tackle the kitchen. That will get a repaint too.
The following users thanked this post: bd139, PrecisionAnalytic
Offline factory
« Reply #30142 on: April 25, 2019, 09:03:45 pm »
Both several years ago when they used all day every day, I was a bit annoyed that calibration couldn't really be bothered with the first one, BER was easier for them. We never had the line filters smoke as they were never disconnected from the mains unless needing calibration and the lab is also kept at a constant temperature & humidity.
I believe we had four of them in total, the failed ones will either still be in the storeroom or may have been sent for e-waste recycling.
Nothing gets much use now since management at the site I work at decided they didn't want 99% of the electronic work mid last year. Hence why I have most of the racks of components in the shed, I keep meaning to ask about some redundant test gear but I don't really have much space and it's at no risk of being chucked out anytime soon as far as I know.
« Reply #30143 on: April 25, 2019, 09:38:54 pm »
You're so cute when you get all domestic.  :-DD
*iPud fixin' time*
« Reply #30144 on: April 25, 2019, 09:42:33 pm »
*iPud fixin' time*
OK who's arse sat on it ?   :clap:
« Reply #30145 on: April 25, 2019, 09:46:56 pm »
Oh, OK, that's a shame, I might have been interested in them if they were going for scrap or something, might have made good parts mules.
« Reply #30146 on: April 25, 2019, 09:52:26 pm »
*iPud fixin' time*
Nope; nothing so domestic. ;) Bought one with faulty LCD to fix. Replaced that, but now having problems with the HOME button. Parts just arrived; hopefully this will be last problem.  :-+
*fix-ily*
« Last Edit: April 25, 2019, 10:00:35 pm by mnementh »
« Reply #30147 on: April 25, 2019, 09:59:51 pm »
That's looking very good, fancy coming to do mine for me, having getting down to the low level stuff and trouble getting up again  :-DD How I used to tease my Mum about it when she said the same to me and I rubbished it, now I understand   :palm: She would have been 97 in 19 days time.
Offline Neomys Sapiens
« Reply #30148 on: April 25, 2019, 10:07:44 pm »
I would rather like to know which kind of tests on which equipment were involved in the demise of the second one!
« Reply #30149 on: April 25, 2019, 10:11:51 pm »
*iPud fixin' time*
*fix-ily*
;D
Just like my 4S, dunno how many versions of it I'm on now, at least 10 I reckon.
New chassis, batteries, buttons, screens and charging sockets, all hand me downs from previous members of the family.
Reminds me of grand dads axe..........7 new handles and 2 new heads but still the same axe.  :-DD
