Thanks for the heads-up. I feel like a bit of a doof for not researching deeper, but then this listing is a lot cheaper than most on this particular model; what I saw on fleaBay looked like similar prices until I looked again.
Everything nowadays "box full of air" is the norm... if you can't shrink an item and still have it serve as needed, you can at least save on the weight of your shipping container. I wonder where on GitHub the original open-source project is that they snurched for this...
The History of JDS/Feeltech is fairly muddy but one copied the other to a degree is clear based on the layout and close clone look of both. I haven't seen any evidence that either was pinched from an open source or other project.
I find that notion shocking, considering it appears that 95% of the thing is an Arduino (or Pi, or STMDuino) with the 2.4" OLED touchscreen shield installed.
Well, good on them then. I hadn't noticed the core weakness of the thing; being that only the Sine output goes to 60MHz. From what I see looking at specs it appears AWG, Saw, Square, etc only go 15MHz. I think maybe the FY6800 is worth the extra $40 to get 25MHz and internal SMPS.
*Knocks self unconscious with clock mallet*
