I'm so pissed off with not having a new toy to play with that I have just pressed the button on a TI Nspire calculator, now to source some of the alternative keyboards for it.
Something that hasn't got yet fully touch or bezels to worry about when dropping
. They will age and last years.
I bid on an auction I wasn't sure I actually wanted to win. Got outbid with stupid money. My conscience is at ease now.
Sometimes things just work themselves out.
"Plenty of fish in the sea"
MwaaaHaha. TEA enabler
Rob
Let's play a game of "guess the waveform!"
Labels 4 Mnementh including the point at which smoke may begin
. Mooning shot for Specmaster.
Short riser block/mount for the pair of fans to be made when they arrive.
Something amplitude modulated with three steps, and frequency modulated with a short pulse?
-Pat
-Pat
Good guess!
Without giving it away too much, it's the analog waveform of a common digital logic construct.
Labels 4 Mnementh including the point at which smoke may begin . Mooning shot for Specmaster.
So, gonna mount the fans push/pull through the stack, or did you actually drill holes in the base of that lovely casting?
Still not too late to make it all horizontal to fit on a shelf... Then you'd have room for a panel meter.
I do sincerely wish you luck not smoking it, however... all this tinkery does make my experiments with soggy coils of coathanger seem much less unreasonable, doesn't it?
Actually, those LED ballast resistors are pretty robust; they'll take quite a pounding. But I know from experience that this fact invites abuse.
So I found a listing on Amazon for a copy of the HP-15C advanced functions handbook from a third party...good price so I bought it. Lo and behold I get another copy of the regular user manual that has a sticker on the back calling it the advanced functions manual.
I figure I'll keep it though, as it's a later printing than the one I got with the calculator and might have errata corrected.
Yeah, I have the PDF version, but holding the nice little wire bound book is nicer. Now back to square one to find a print version...
I never remember to check for hamfests around me and have not ever gone to one.
I haven't yet either. I'm lately addicted to Craigslist, Offerup, Letgo and online free searching or other searches for specific items I'm looking for as a fix.
Especially using Google and the search term with the "site:
whateversite.org" syntax after the search term with or without parenthesis.
I spent a couple of hours building the TM500 extender kit and tomorrow will resume working my way through the pile of plug-ins I've acquired over the last couple of months. It will be such a pleasure to not have to work on stuff while it is in the frame.
I'm anticipating building and extender for the Pacific Measurements D14(A) modules..., and wound up updating the JAMMA wikipedia entry since my JAMMA Connector proposal draft was suggested to merge with the JAMMA wiki..., so I have some reference information and figured others can use a reference. Kind of a tangent... though why not. Threw in the RJ21 link while at it on the wiki.
https://en.wikipedia.org/wiki/Japan_Amusement_Machine_and_Marketing_AssociationThen bought more Pacific Measurements modules (H13, x2 V12's, N10), some detectors and the D14A. Next I'm going to read into sometime if I can figure out how to make the detectors for less than the cost of purchasing.
I'm not sure how else to work on the modules without extenders. Figured the same for the Tektronix 7000 series.
I've been able to calibrate and adjust the attenuators on 7000 series vertical plug-ins on a 7603N by simply removing the scope's side cover and leaving the mesh screen off the plug-in. This may not be sufficient if you have to troubleshoot the plug-in because you can't get to the backside of the circuit board but for routine maintenance it works. The timebase plug-ins are more complex and an extender is almost mandatory but luckily they require less maintenance.
Yep that's how you do the plugins on the Telequipment D83 also.
They ain't hard to make.
Below from another recent thread. IIRC I just drew the etch resist on with a ruler and permanent marker and notched it to maintain polarity like the notches in the plugin cards.
Make one, the hardest part is finding the right socket.
For the rest some old PC IDE ribbon cable and the for the plug just etch some strips on a PCB.
You could probably just do the strips with a Dremel.
One I made moons ago for the plugins for a UK Telequipment D83 (owned by Tek).
That's a good mooning shot, good air flow assured [emoji16]
So I found a listing on Amazon for a copy of the HP-15C advanced functions handbook from a third party...good price so I bought it. Lo and behold I get another copy of the regular user manual that has a sticker on the back calling it the advanced functions manual. I figure I'll keep it though, as it's a later printing than the one I got with the calculator and might have errata corrected.
Print it in book format and then spiral bound it, the bits are on ebay etc. [emoji48]
But doesn't that cause roll off in the vertical response at high frequencies? I would think that 50Mhz and above could be problematic.
It would do. Most of the time you use these while they are broken.
Or when I did some cal, pull it out then adjust it and stick it back in again. Took a few times.
It seems that the "Cold Start" I performed on this 2430 DSO had other positive benefits. I noticed that the GPIB now shows status although I don't use it. And prior to the cold start when the scope was powered off upon power up would default to CH1, 100mV, 100uS. Now it does a much preferred remembers last settings when powered up. There's probably a bunch of other things that got reset that I just haven't discovered yet.
The D83 I built if for was a just a 50 MHz CRO.
Wasn't so worried about any top end performance impacts only the ability to get to any test point I wanted to.
With CRO's, most often so few real adjustments are needed once the PSU is to spec and faults are fixed.
I thought I would show my rough dc loads, used to proof test a 28V 35A linear PSU, it powered my 1.2GHz 350W PA for EME.
I didn't run them for too long as everything gets very hot esp me!
So close to b-f design but mine are much rougher I am afraid.
Edit re the HP extender boards in the video above - I have bought some of the kits - very useful, I found the best way to coat the tips in solder was to put solder on then drag it off with solder wick and a good hot iron.
