Ok, someone please tell me..
WHAT IS IT ABOUT HPAK AND THOSE BLOODY FEET?
The HP6825A is missing all four of them. I am not amused!
But it is the least of my woes with this device. The second part from that triple score did go downwards fast.
External inspection did not rise my concern. no deformations, no debris inside. On the plus side, the jumpers on the terminal strips in the rear seem to be complete.
I took the bottom cover off to have a look at the ground jack (whch is not realy accessible from there, but ok for a look and bit of manipulation) and it is not simply loose, but broken. Real access wil need the front assembly to be taken off, if I can get the part.
Also, the rotary switches feel funny. Mushy. In a way that, were it a Tek, it might have to be put down.
The switches in the 3312A are not nearly as mushy. I dont want to look there right now.
And it not exactly clean.
But that was not the most alarming discovery. There is a spot. No, it is not a particularely nice spot.
It is a scorchmark. Right on the bottom main PCB.
And the only doc that I found has no circuit diagram and no component locator.
Yes, I switched it on. Slight hum, indicator lit, no frying sound. CC Led solidly lit.
No combination of mode and pot positions did cause any reaction.
Zero output.
Disgusting.
