I'm a cable nazi so mine are always tidy. Or in AWS where there are no cables I have to organise
Hey, you guys are always poking me about my neat bench. So I gotta be sloppy somewhere.
I didn't care too much about neatness under the hood of a PC either until I was asked to look at one that was intermittent booting, once it did it was fine. You had to keep pressing the power button until it latched and booted.
Turned out the PSU was shutting down due to high current draw from dud motherboard caps....they looked OK but one nearly burnt my finger while poking around to see if there were any hot spots. Amazing it hadn't already launched its can and covered the PC insides in confetti.
Replaced all the 1000uF caps.......some were sick and some buggered and the PC behaved perfectly thereafter.
Since then I've been just a little anal about unimpeded airflow inside a PC case.
Bit of a fan of modern mainboards with solid caps now.
