Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 18805993 times)
MVSantos, Ice-Tea, Rosco, bd139, Peter_O, diskcopy and 91 Guests are viewing this topic.
« Reply #22300 on: January 08, 2019, 11:14:47 pm »
Not feeling brave enough to fully series-stack the inverters and run 'em both off a single 36V supply, eh?  :-BROKE
*Star Wars time*
You can't. The -V in and -V out are common. As soon as I tied -V out of one to +V in of the other....KABOOM  :-DD
Do the outputs NEED to be tied together? Each of the LR8s has reference back to its own inverter power supply. Either leg should be floatable. Then you can actually ground the (-) output rail while using a transformer-based power supply.
Mmmm... floating 500VDC... yummy.  *tzzzzt*  ;)
I dunno, maybe that would work. At this point I would prefer to keep it battery operated. Safer in case something goes fubar.
« Reply #22301 on: January 08, 2019, 11:29:47 pm »
Fair enough... and as long as you keep it battery-op; even if it won't produce a stable output, you can always turn it into a neighbor-who-keeps-parking-in-the-wrong-spot educational aid...  :-DD
*tzzzt²*
Offline LapTop006
« Reply #22302 on: January 08, 2019, 11:30:49 pm »
My location is a bit bad for receiving GPS signals:
My apartment is at street level and the GPS antennas are on the window sill of a window that's looking out to the west and onto the street where on the other side (~25m distance) there's an apartment building with 4 floors.
My apartment doesn't have windows to the south or to the north.   :(
That is far from ideal, maybe you should try to find a way to bring an antenna outside and up, but that could be hard depending on landlord and regulations…
Errrm. The antennas are on the outside window sill. Didn't describe that clearly.
Inside the window it doesn't work at all thanks to energy saving window glass that's metallized to keep the infrared inside.
You have the same problem I have, although I've got mesh screens on my windows and no way to run an antenna outside.
I can sometimes get enough signal to lock a modern GPS receiver, but rarely.
« Reply #22303 on: January 08, 2019, 11:42:02 pm »
I can get the trim pots cheap so I'll also order up some 5K trimmers and add 5K fixed in series and see if it makes a difference.
Lower :) Attached is the divider my HP735A (1V reference) uses might be of interest. Maybe not down to 500 ohms but lower is better.
« Last Edit: January 08, 2019, 11:44:10 pm by beanflying »
« Reply #22304 on: January 08, 2019, 11:46:27 pm »
How are you going to solder them in close proximity to that thermoplastic? Seems highly unlikely you won't uglify the hell right out of it.
Tacked them together to make them stay in place easier while I work on the strip copper links. So Far So Good :)
Good work on losing the hairspray. Good squirt and wipe of IPA between prints to keep any skin oils away from the glass and wash it every dozen or so prints just because. Glassy finish and no glue gunk  :-+
Ahhh... so the ring is bigger than the contact circle. I thought it was supposed to drop right on top of them.  :-+
This latest project, I've literally just been knocking the part loose with a 3" razor scraper, do a dry scrape in case of any loose shreds, and then a quick wipe with a paper napkin and start the next one. I don't even touch the glass. ;)
Now about 3/4 thru #8.   :-+
I thought about reslicing to do 4 at once... I have 310x310, so plenty of room. But these are printing so well, and the layer adhesion is just fabulous. I'm afraid that moving from one part to print three others every layer will affect the layer adhesion, and then there's more likelihood of stringing and blobs... no.  :phew:  I'm fine with letting it chug away one at a time.
Let the machine do the work. That's what it's there for.
« Reply #22305 on: January 09, 2019, 12:55:54 am »
Yeh, I think its best to do one at a time, my printer guy did say however that if I needed more knobs for scopes that he could print multiples at a time and therefore the cost would be lower, but they are significantly smaller so there should not be a problem adhesion etc unless he stretched it to far so by the time he came back to the first it gotten to cold to blend in.
« Reply #22306 on: January 09, 2019, 01:14:11 am »
Small objects like knobs are close enough to the heated bed that they stay warm. A 30mm x 130mm tall cylinder, not so much. ;)
Now working on migrating the data off her old desktop... freaking 200GB iTunes folder over USB 2.0.  |O
At least the new one has USB 3.0 on it.  :-+
*Less than the sum of my printed parts*
« Reply #22307 on: January 09, 2019, 01:18:07 am »
Mixed bag of results doing multiple prints at a time.
Layer at a time works fairly well on small bits as far as layer adhesion goes but on the larger parts it takes a while to get back to the next layer so the parts are weaker across the layers. Generally faster than one at a time.
Printing one at a time then moving on to the next (top of one back to bed height for the next) is preferable so long as the head doesn't knock over or bump the earlier parts and cause a stepper to lose position |O It isn't really faster than one at a time but it can mean you set it overnight and print multiples while you sleep but you can wake up to spaghetti too :palm:
Offline Kosmic
« Reply #22308 on: January 09, 2019, 02:22:59 am »
I received another of those brown box today  :)
Was described by the seller as "It powers on but there is a burning smell very quickly". That's probably why I got a good deal. Anyway, anybody got some spare triax cables ?  ;D
Will soon be able to measure pico amps and Tera Ohms  >:D
« Last Edit: January 09, 2019, 02:48:16 am by Kosmic »
Offline neo
  • The specialist.
« Reply #22309 on: January 09, 2019, 02:52:26 am »
So what you mean to say is that you've taken up, as a hobby, the fine art of measuring the breadth of a gnat's fart?  :popcorn:
« Reply #22310 on: January 09, 2019, 02:52:57 am »
Now THAT... is some hardcore pulchritude. Can't wait to see it all cleaned up.  :-+
@neo - Not breadth - length and height. Breadth and duration are options that go in those two empty slots.  :-DD
 :popcorn:
« Last Edit: January 09, 2019, 02:54:47 am by mnementh »
The following users thanked this post: neo
Offline neo
  • The specialist.
« Reply #22311 on: January 09, 2019, 02:59:40 am »
 :popcorn:
 :-DD :-DD :-DD :-DD :-DD
Thanks for the correction, wouldn't want to look like an idiot when i go trying to be sardonic and acerbic.
Offline Kosmic
« Reply #22312 on: January 09, 2019, 03:00:06 am »
Hehe yeah I don't really have any use for it right now. But electrometer can also be used as a really high impedance voltmeter so that can certainly be useful. Plus I should be entertained for a little while doing the cleanup and repair.
« Reply #22313 on: January 09, 2019, 03:08:39 am »
You're not going to be happy until you can count the electrons going past one by one, are you?  :-DD
Volt-nuttery: Not just a job; an adventure.
« Reply #22314 on: January 09, 2019, 03:08:57 am »
ITunes is freaking slow regardless of USB2 or USB3 because it has so many files to album  :palm: And it is even slower to copy over to a NAS drive as well  :rant:
Offline Mr. Scram
  • Display aficionado
« Reply #22315 on: January 09, 2019, 03:09:23 am »
I pretty much ran out of reasons to buy multimeters for myself, so I simply started buying them for others. It feels good doing things for others. That some real alteaism. Proper charitea.
Not that we need reasons, mind.
« Reply #22316 on: January 09, 2019, 03:13:33 am »
Not just counting the electrons, but grading and numbering them as well.  >:D
Offline Kosmic
« Reply #22317 on: January 09, 2019, 03:14:19 am »
Nah i'm just a wanabee voltnut. Not sure I will ever get there. It's a fun trip though  :)
Offline Brumby
« Reply #22318 on: January 09, 2019, 03:15:35 am »
Could be a quick exercise....
Offline Mr. Scram
« Reply #22319 on: January 09, 2019, 03:19:12 am »
"You may be technically correct. The best kind of correct."
Offline Kosmic
« Reply #22320 on: January 09, 2019, 03:23:33 am »
Talking about volt-nuttery, I'm currently benchmarking different solder wires and recording the EMF generated when coupled to copper. Recording on my Keithley 181 is a pain so got to finish writing another software before I get some real results.
But 10Sn90Pb seem really good when compared to Sn62/Pb36/Ag02.
Offline Kosmic
« Reply #22321 on: January 09, 2019, 03:26:30 am »
Good idea! Valentine's Day is coming, I could buy one for my wife.  :-DD
Offline Mr. Scram
« Reply #22322 on: January 09, 2019, 03:31:47 am »
A bouquet of Brymens should go over well.
Offline Kosmic
« Reply #22323 on: January 09, 2019, 03:33:51 am »
hehe good one  ;D
Offline Brumby
« Reply #22324 on: January 09, 2019, 03:45:06 am »
Oh - the myriad of hellish reactions such a move on my part would bring to the fore.
I'm going to have to go into hiding for three days for just reading that.
