Thank godness, I've got me a spare Trimble 57963-D board long time ago!
My Trimble 57963-D based GPSDO shows strange behaviour since last night.
Turns out it has lost it's lock and doesn't lock any more.
Checked supply voltages (ok*), cabling (ok), different antennas (ok, working with spare GPSDO board), it just won't lock any more.
In effect I've fallen back from two GPSDOs at my lab to actually one.
I'm going up to two again when my new BG7TBL GPSDO arrives.
Strange thing about it is that the DAC controlling the OCXO can drive it lower and higher than 10MHz in startup meaning it's unlikely that the OCXO is defective in a way that it's adjustment input isn't working properly. Also the temperature of the OCXO seems to be regulated and stable. I will investigate further after work..
*- My Trimble 57963-D based GPSDO is one of
these.
I liked (and still do like) the idea of an interface board and an internal power supply and it worked fine until last light.
When I checked the supply voltage of the internal switch mode power supply (LM2678ADJ based) it had 6,5V whereas I had the information that the Trimble 57963-D takes 5,5 +/- 10% which results in max. ~6V voltage!
I found (after a searching the 'net) information that it'll be fine with higher voltages also letting the onboard regulator run hotter. Yep, it was: I barely could touch it. But: It limited the internal board voltage to about 5V, so no over voltage damage had to be expected.
Anyway, I changed the adjustment voltage divider of the LM2678ADJ to an output voltage of ~5.5V and now the LM2678ADJ isn't running hot any more.
Still won't lock.
