TEA, TEA, TEA, ...
Since it's possible (and I won't be able to withstand..) pimping my Fluke PM6681s/6685s and my newly acquired HP 53132A with 3rd inputs for the GHz range my list of TE that's missing on my bench is now:
- Signal Generator (3-4 GHz, with GPIB or Lan and 10MHz reference input)
- Spectrum Analyzer (would like it with a TG, GPIB or Lan and 10MHz reference input is a must)
plus other things..
- Electronic load capable of >>10A and R-modes down to milli-Ohms
I'm a bit surprised of the shortness of my list.
Perhaps it's because there are only expensive instruments left in it..?
I think I'll have to be careful not to stress the tolerance of my SWMBO too much.
It'll be hard to balance between the craving for those instruments and the strategic need to put enough time between getting those. And eb** has no mercy sometimes when there are showing up opportunities to give in to TEA.
Ok, end of the preface.Looking for a reasonable and reasonable priced siggen I came across this:
https://www.ebay.com/itm/172210964785That's a 35M-4.4G simple signal generator designed by BG7TBL with a minimalistic user interface with display, push buttons and knob and (!) a 10MHz reference input.
It's based upon a remarkably spec'd Analog Devices ADF4351 wideband synthesizer with Integrated VCO.
Ok, the list of limitations of this little sig gen compared to a "real" sig gen might be longer than the advantages but it's quite a lot bang for buck as long as I also can tell from the possibilities the ADF4351 gives (regarding its datasheet)
pros:
- wide frequency range from 35MHz to 4.4GHz
- ability to syntonize to a reference (e.g. 10Mhz with measures)
- relatively clean signal (in regard to having no output filtering)
- small
- low power consumption
- price
cons:
- sine output only from 2.2 - 4.4GHz, other frequencies are generated through fractional N circuitry and therefore are rectangular
- no modulation capabilities
- no sweeping capabilities
- no output filtering (that alone would cost more than this sig gen..)
- only 60dB dynamic range because it has
- no output attenuator (that alone would cost more than this sig gen..)
- no automatic level control
- no data interface
- no documentation
There are other sig gens based on this chip around for lower prices, even with touchable display and more powerful firmware -but without housing and with some HF/RF pcb- design flaws.
Since it's marked with BG7TBL and this source has gained some reputation for GPSDOs and also other HF/RF stuff I google'd for this sig gen and found ... nothing.
Does anyone know anything about it?
I wasn't even able to find photos of the inside.
