Scrub with alcohol first. If you can't completely immerse, treat it as as extra measure, not your primary cleaning method.
Don't use any foaming detergent like dish soap; it will foam even against tiny bubbles of air trapped on the part, and those areas will get no cleaning at all. If you have nothing else to use Windex will work okay, provided you rinse immediately with distilled water to neutralize the ammonia.
Immerse in a shallow pan of alcohol again after all that for several minutes per side to displace water from under parts.
Dry with warm air; heat with hair dryer if you're brave. Wear a glove on the hand holding the part just in case your hair dryer spits out a bit of smoldering lint and the alcohol lights up; check temp of the board frequently. If it's just too hot to hold with a bare hand, and you can't see any liquid, that's just about right. If you start to smell hot phenol, probably a bit too hot. Put the hair dryer down and slowly back away.
If yours doesn't have heat, and isn't an all stainless post-apocalyptic-medical-looking monstrosity like the one Louis has, it's a toy gimmick POS made to sell to Joe/Josephine Dumbfuck for cleaning their jewelry. Even the little ones look like this. The toy ones are deliberately made with weak-sauce to keep The Dumbfucks from destroying "priceless family heirlooms" and litigating.
There are two reasons you need a basket:
A) Because the cleaner is designed around the resonant mass of the liquid and tank, any solid mass touching the tank will alter that resonant mass, decreasing the effectiveness of the cleaning, and direct contact can cause damage to the part, even breaking components loose. This is the "skull-fucked" state Louis is talking about.
2) Unless you have a really expensive unit with recirculating/filtered solvent, most of the crap that breaks loose will settle to the bottom. You want your part suspended above that.
Cheers,
Oy gevalt; my taxes.
