Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17732618 times)
Vince, flash2b, doktor pyta and 56 Guests are viewing this topic.
« Reply #13550 on: July 22, 2018, 09:09:18 am »
How about this for starters?...
Laminate it and DS tape and you're done !  :clap:
Online Messtechniker
« Reply #13551 on: July 22, 2018, 09:53:18 am »
Question as to the lamination bit: does paper exist which adheres to the lamination sheets? In order to avoid lifting edges, I must always ensure some excess lamination of around 1 mm so that the lamination sheets can meet and stick together. Any ideas?
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter, UT216C AC/DC Clamp Meter
« Reply #13552 on: July 22, 2018, 09:58:13 am »
*Tosses soggy ol' boot at Specmaster's head, just on GP*
I see that your fishing trip produced the same usual catch then, you must have quite a haul of those now, (specmaster battens down the hatches in expectation of soggy boot bombardment)  :-DD :-DD :-DD
« Last Edit: July 22, 2018, 10:04:09 am by Specmaster »
Offline Brumby
« Reply #13553 on: July 22, 2018, 11:26:24 am »
My approach would be slightly different.  I would print on a decent quality paper and then spray it with a clear, non-yellowing lacquer which I have.  That will make it waterproof.  It might still be more exposed to physical damage than I might like - but it's not something I'm going to be too concerned about for a sub AUD$10 DMM.
« Reply #13554 on: July 22, 2018, 11:45:57 am »
I’d dip the whole meter in acetone overnight  :-DD
Offline Brumby
« Reply #13555 on: July 22, 2018, 11:48:57 am »
You first.
« Reply #13556 on: July 22, 2018, 11:53:03 am »
Yep that'll fuck it alright 🤣
« Reply #13557 on: July 22, 2018, 01:08:32 pm »
Your intent is a little unclear. Do you mean "Does paper exist which does not adhere to the lamination sheets?", i.e. you want to effectively laminate one side only and leave a margin of laminating film that can be subsequently stuck down? When I want to do that I cut a piece of baking parchment a little larger than the piece of paper that I'm laminating.
Offline Brumby
« Reply #13558 on: July 22, 2018, 03:53:15 pm »
Another tweak....
« Reply #13559 on: July 22, 2018, 03:54:55 pm »
« Reply #13560 on: July 22, 2018, 08:59:45 pm »
To be more precise: I put the printed piece of paper between two lamination sheets
whereby the printed piece of paper is a bit smaller - about 1 mm all round - than the two sheets.
Then upon lamination, the 1 mm area sticks together. If the lamination sheets and printed
paper were cut to the same size, then the laminated sheets and the paper will eventually
detach usually beginning at the corners. Therefore I will have to live with a 1 mm all round border.
I laminate using two sheets because the glue of the double sided tape tends to discolour paper
when in direct contact.  :palm:
Offline sixtimesseven
    • Flickr
« Reply #13561 on: July 22, 2018, 09:29:10 pm »
Just won a HP 8007B pulse generator for 22.50 Euros. Couldn't resist it  :palm:
Now I have to find a shelf which will not collapse im.
« Reply #13562 on: July 22, 2018, 09:33:52 pm »
*SNERK*
*Out the door*
Offline Mr. Scram
  • Display aficionado
« Reply #13563 on: July 22, 2018, 10:18:47 pm »
The dubious non responsive seller refunded me, after me opening a case and an attempt to "resend" the product. It irks me that I can't give him negative feedback, but at least I got my money back.
« Last Edit: July 23, 2018, 02:20:09 am by Mr. Scram »
« Reply #13564 on: July 22, 2018, 10:56:19 pm »
Add the seller to all the shit list sites you can find. Where there’s a will there’s a way.
« Reply #13565 on: July 22, 2018, 10:56:53 pm »
Congratulations. Just remember with HP kit it can be the shelf :)
Online tggzzz
« Reply #13566 on: July 22, 2018, 11:05:11 pm »
I got a Tek 115, which looks similar, for about £5 IIRC. I like the independently controllable rise and fall times, something modern pulse generators lack. But AWGs can do that to some extent.
« Reply #13567 on: July 22, 2018, 11:18:24 pm »
Yes my AWG does that. It’s pretty neat the things one little box can do now.
I’d still have a dedicated analogue PG if I had the space though. They’re much more fun :)
« Reply #13568 on: July 22, 2018, 11:34:43 pm »
Another tweak....
I like all your customizations, Brumby. The "1000VDC" next to the volts jack should probably be red, like the "750 VAC."
*SNERK*
Haha, yes, it must have Brumby somewhere on it.
« Reply #13569 on: July 22, 2018, 11:36:23 pm »
Actually, since we have no shortage of DMMs, an unusual one like that is just fine. If you're in a situation where being distracted by it is critical, just use another meter. :-DMM
Spoken like a true TEA addict!  :-DD
Yes, well, I wouldn't want someone to think I was cured or anything. :o :-DD
Offline Brumby
« Reply #13570 on: July 23, 2018, 12:29:02 am »
Thanks.
I didn't even think about that. I was just following the original artwork.
Seems a bit self-serving - but that's a couple of votes.  Maybe I should consider it.
« Reply #13571 on: July 23, 2018, 01:53:36 am »
If you don't want it to be too obvious, then you could call it the BMB830B.
« Reply #13572 on: July 23, 2018, 04:17:04 am »
Some goodies on my local Craigslist. I have no interest in either. In fact, I think I would find that "clear" 87 somewhat distracting.
If you don't want it, buy it for mnem! ;D
If mnem wants the link......here it is.....
https://hudsonvalley.craigslist.org/ele/d/fluke-87-true-rms-digital/6647792597.html
Aside from the novelty factor... I find it absolutely, utterly, completely resistible.  :-DD But hey; you'll at least be able to see the path of the lightning through the meter as it knocks you on your ass... :-DD
I'd have to have a few more zeroes in the savings account before I'd even consider buying it solely for that reason; I'd still probably buy a BM869S first.
The tubing will cost more than the meter did.
Yeah, especially in my case since they were all free from Horror Fraught.  :-DMM
Thanks.
Actually I considered that angle, but decided that the serendipity of how the original model number so easily lent itself to being Brumbified was evidence that it simply was meant to be. Besides; it's expected that an artist will sign his work.  :-+
Lemme know if you want a red one to demonize similarly...  :-DD
"Remember kids... the difference between fu**ing off and science is writing it all down."
« Last Edit: July 23, 2018, 04:22:14 am by mnementh »
Offline Brumby
« Reply #13573 on: July 23, 2018, 04:23:13 am »
I've spent too much time on this - especially for what it is.  Justification for efforts up to this point: Entertainment value for EEVblog members, but I have to wrap it up.
Artwork is done.  Just have to go through the production process.
Offline Brumby
« Reply #13574 on: July 23, 2018, 04:28:28 am »
The only way I could get it past SWMBO is if was income generating.  If I were to do otherwise, I might suddenly disappear...  :scared:
