A bit late to the disk drive party - but I've been pondering the question of will I share this...
Back in the 80's I was working for a company as an analyst/programmer after having spent 2 years as an operator on an IBM 370 system using 3340 disks. These disks always reminded me of the USS Enterprise.
They had the feature of integrated heads, so that each disk pack had its own set of heads. This avoided the problem of a head crash on one disk being propagated onto other disks and other drives by operators who were no diligent. The head assembly was protected by a plastic roller shutter which was drawn out of the way as the disk was loaded onto the drive. A large peg and locking mechanism engaged the head assembly. This peg was the actuator for a very grunty linear actuator that resided in the drive unit. A large electric motor engaged with a plate at the bottom which connected through to the spindle. The motor turned the platters and the linear actuator performed the seek motion of the heads.
Within the plastic casing, there was a metal frame upon which was mounted the spindle bearings and spindle as well as the heads and the tracks they would run back and forth over. This frame was supported by three rubber mounts - that were under tension. Yes, the entire platter and head assembly were
hanging by these three rubber mounts.
Over time, we had a failure of one of these mounts and the platter and head assembly no longer sat level - and so the drive could not load it. Being the creative guy that I was, I was able to work out a way to support the platter assembly from below while the drive loaded the disk. Once loaded, the mechanics of the motor and head driving units kept the disk held well enough to be used. The only thing that was done was an immediate copy off that disk - and then it was retired.
As my interests in all things electrical (I can't begin to tell you how many things people brought in for me to fix - from car cassette/radios to kitchen mixers) I was able to procure one of these and I went about the teardown exercise.
That was many years ago and I still remember some of the fun I had. The stuff the outer casing was made of was incredible. A full swing blow with a 21oz ball pein hammer just bounced off. There were platters, there were spacers and there were a lot of exceptionally well engineered heads - but after all was said and done over the years, there is almost no trace of this unit left.
Except for these:
These are the ball bearings that the heads ran on back and forth along the tracks.
