Are there sections of London that are really that bad? NYC used to have "no go" sections but that's no longer true...although some neighborhoods are "safer" than others. Now the same can't be said for cities like Chicago or Detroit.
No it's usually absolutely fine really almost everywhere. Us Londoners mostly joke about it because it reinforces the stereotype of how bad it is. Literally everyone apart from everyone who lives there thinks it's nasty. It's really not. You can walk along quite happily in even the shittiest bits with an iPhone 10 slapped to your head and no one will stab you or try and take it. Opportunistic theft is relatively low and most of the people who get killed or stabbed are tit for tat private gang violence. There was a spate of motorcycle muggings in the last year but this was almost entirely down to 3 people apparently. They're just finishing off all the copycats now. Most people have silent respect for each other.
Edit: Genuinely you can sit in a greasy cafe in the East End of the city and have a millionare currency trader, homeless guy, foreign student, unemployed person and a muslim refugee sitting at the same table eating breakfast and talking candidly about life as if they've known each other forever. Nowhere else on this planet I've been have I seen that. People say it's unfriendly but I've only found it the opposite.
Couple of quick test gear related pictures as I'm still dead in the water here.
Worst illustration and explanation of point award goes to RSGB from the full license revision book ... doing the exam this week so having a quick scan...
I can see sooooo many things wrong there.
Shouldn't that work better if it were a feed thru termination?
Yes generally a good idea to use a through termination. The SWR is going to be shit on a T-piece though. Fine for audio. I can see the following things that are wrong with it however:
1. The T-piece is usually connected to the scope in the middle so it's the wrong T piece.
2. The T-piece indicated can't be plugged into the scope because the gender is wrong.
3. Through termination as mentioned is definitely better.
4. Don't connect the probe to the T piece, it's not a 50 ohm match to the DUT.
